Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: Some P4G8X bandwidth lovin!!!
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    Needed some register tweaks but here you go..dual ddr400.
    Unbuffered.
    Nov 2002
    Boston/NJ
    wow
    Abit Is7-E
    P4 2.0A @ 3.2 160FSB with 1.63V
    2x256MB HyperX 3000
    Sapphire 9800 Pro
    Maze 3 / Maze4 GPU/ 6x11 Heatercore/ Hydor L30
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    How does 3dmk run?
    Awesome!
    C
    Dec 2002
    Crunching Seti
    I think I just soiled my undergarments.......
    Prometia Lian Li PC60, Enermax 550w, ASUS P4T533 + VRIMM MOD
    P4 2.8 @ 3569mhz (unheard of 170 FSB), 2 x 256mb Samsung PC4200 RDRAM
    Inno Geforce Ti200 (620/325) + Impending Voltmods
    48x Liteon CDRW, Liteon DVD, 2 x 120GB Maxtors, Firewire
    3D Mark 2001 SE - 14160
    http://service.futuremark.com/compare?2k1=5456616
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Very nice
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Sep 2002
    Milan
    why?
    you have already the best for bandwidth. You have already the vrimm mod and ... forget buffered memory benchmark.
    W/ some PC1200 you will score the same w/ unbuffered benchmark. But w/ PC1200 stick PC1333 will be easy @2.57v.
    Ciao
    Jan 2003
    Holland
    Thats some insane mem benchmark result...
    Dec 2002
    detroit
    thats what i call some luvin. is it stable?
    E4300|IB9|Ultra-120 Extreme
    the jedi master
    Jun 2002
    Remember its using a Mobile P4which defaults to a 12multi so 200fsb is a dead easy overclock..and yes it is stable to the point it is boring!!!
    Xtreme Mentor
    Nov 2002
    Delaware USA
    Man let me drop my pants and and look at those pics again. Better than intenet :banana::banana::banana::banana:.
    Sure wish my FKng board would ship i ordered 2 months ago. With the order still active.
    Dont even ask where i've been!!!
    Oct 2002
    Field of Battle
    I saw Ga-8INXP back in-stock at Newegg for about 10 minutes yesterday. I was ready to buy one but waited for my wife to leave the room (hehehehehe) and 5 minutes later....they were gone!!! Grrrrrr.
    AND TEDINDE---- What do you think of your Vapo PE, what do you use for gpu cooling(edit**I see MCW 50-T...works well?) and do you think Prommy would have gotten you a stronger oC?
    C
    Sep 2002
    Dallas Tx
    Got my 8INXP at Fry's
    Their on line store show to have em in stock also.
    http://outpost.com/
    Sep 2002
    Dallas Tx
    bigtoe
    What kinda CPU performance you getting from that P4 mobile??
    the jedi master
    Jun 2002
    Same as a normal P4..its just the board will not clock past 200fsb...thing is its a lot faster than a p4 clocked to 2.4 with a 133 or 166fsb as the cache and the memory are running much faster.
    Hardware Redneck
    Nov 2002
    Yep...you in essence have early springdale right there.
    DC board at 200FSB, and a 2.4/800 chip. The only thing you're missing is Hyperthreading.
    Damn...Sprindale and those new 800 FSB with Hyperthreading chips...going to be hella sweet
    Sep 2002
    Dallas Tx
    OK you've thrown me for a loop here, on the P4 moble defaults to 12x??
    This means it's a 1.2GHZ P4 moble
    Aug 2002
    Melbourne Aus
    nah, p4 mobile can change their multipliers when battery is low..
  18. #18
    the jedi master
    Jun 2002
    On an ATX board there is no way to get it into performance mode so we are stuck at 12 multi.
    http://www.vrforums.com/showthread.php?s=&threadid=5763
  19. #19
    Sep 2002
    Dallas Tx
    Thanks thats a good thread.
    I noticed in that thread you showed a pic of the 8INXP's f2 BIOS loaded into modbin6, showing thew max fsb to be 355??
    Was that after you moded it?
    The 8INXP I have shipped with the F3 BIOS and only goes upto 200 fsb??
    Not that I have a proc that'll do 200fsb, but you never know what will turn up
  20. #20
    the jedi master
    Jun 2002
    no that is what the bios says,,unmodded!!...wait for the 800fsb NW"C" to arrive and im sure we will see a bios upgrade for over 200 then.
  21. #21
    Sep 2002
    Dallas Tx
    bigtoe
    Have you got your 8INXP in yet??
  22. #22
    the jedi master
    Jun 2002
    nope...but I may have found one...will see if its avaialable tomorrow and with luck i will have it on weds.
  23. #23
    Sep 2002
    Dallas Tx
    I'm interested to see which you like best, the Asus or the Giga Byte.
    Thus far I've had no issues with the 8INXP to 180fsb
    Wish I had a CPU that would go higher.
    But they are comeing in April
  24. #24
    Jun 2002
    Ohio, U.S.A.
    Sucks man... Where did you order it from?
  25. #25
    Jan 2003
    if your in the uk ill cry
    cant get hold the board
    Si
