Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Got my 2100+ TBRED-B AIUHB today from newegg...
    Dec 2002
    Tempe, AZ
    and i'm currently sitting at 2.275ghz in windows, 1.7v, idling around 32C
    Alpha 8045 with a 40cfm fan, and around a 21C ambient temp
    this chiip has a lot more to go..
    and my 3dmark last i benched, was a 10747
    too bad this chip isn't unlocked by my motherboard... i'm stuck at 13x multiplier...
    anyone know how to unlock these?
    NF7 | Mobile 2400+ | 256MB Twinmos PC3200 BH5 | 9800 PRO | 23384 6989
    MY HEATWARE
    Jan 2003
    Seattle, WA
    Got mine also. 0301. I'm doing 2385 at 1.9v with an slk800 and 80mm tornado. I'm not sure if it will do it with lower volts. Just stuck it there to see how it will do Running some prime95 right now. Running at 35.5 so its kind of warm but will see how it does.
    Antec TruBlue 480W - Epox 8RDA - XP2100 'B'@12x220mhz=2652mhz@1.85V Max: 2800mhz@2.125V
    2x256mb PC3200 Twinmos 3-2-2-2 -
    WD 120gig/80gig 8MB Cache Maxtor 30/20gig 7200rpm
    Radeon 9500 Pro & 9700 Pro
    3dMark2001:15756
    MCW50-T, 2xD-Tek Procore Combos, Hydro L30, 2xYS-Tech 120x38mm, Nexus Fan Controller, 10ft Clearflex60 1/2in, Swiftech 1/2in F&B kit, Pump Relay Switch V2
    Nov 2002
    California
    Can we see screen shots??? I would love to see them
    Abit IC7 @300FSB Bios 28
    P4 2.4C@3.6Ghz
    ATI 9700 Pro @ 445/710 Vgpu modded
    Corsair XMS PC 3500 256mb x2
    Liteon 52x24x52 CDRW
    WD 40GB 7200RPM x2
    Enermax EG465P-VE(FCA)
    Chevy Chevette Heater Core
    MCW50-T
    Eheim 1048
    Prometeia Mach I
    Lian Li PC65B
    Dec 2002
    Tempe, AZ
    here is what i'm at right now...
    i just bumped down to 166 cause the 1/5, 2/5 multipliers come in... i used 13x175 to bench..
    gonna open up the doors downstairs here to the 10F winter air....
    lol
    MY HEATWARE
    Jan 2003
    Holland
    i am trying to sold my 2400+ (week44 auigb) that has maxed out 2,8ghz on my 8rda+, hope my 2100+ week 50 auiHb does beter just as by you guys:p
    Nov 2002
    Mountains of N. AZ.
    Hey Stang,
    if you want to unlock the mults for access to 12.5 and below, I highly recommend the pin trick - works very smooth!
    Check out shuki's link below...
    I'm running at 2275 (12.5x182) right now
    1.65 vcore
    kx7-333
    samsung pc2700 (2x256) 2.5-2-3-1, fast cpu decode 2.85 vdimm
    mem bandwidth: 2726mb
    cooled w/ sk6 & 33 cfm papst, AS3 - load about 54 deg C.
    Still haven't been able to break the 2300 mhz barrier, but I'm gonna do some ductwork to the cpu and see if that will help.
    2.5 ghz 250 HTT
    Winnie 0449 CHBBD MPM stock HSF 1.4v
    9NDA3j rev 2.1 2/15/05 bios
    2gb Corsair TwinX XMS @ 2.5-3-2-7, 2.6volts.
    eVGA 6800GT @ 380/1.06 stock
    Jul 2002
    not so holy land
    okra, have a look here Hopefully my xp2100 b will be here next week to pop in my kx7
    Jan 2003
    Holland
    okra what kind of processor you use? i think its a 2400+ am I right?
    Dec 2002
    Tempe, AZ
    i dont' know why, but i can do 160fsb before the 1/5pci divider, and all's ok, but i can't do 185 and greater....
    maybe i should get to the unlocking soon...
    btw, here's some more screens @ 2.34ghz...
    MY HEATWARE
    Jan 2003
    Hawaii
    I just got my 2100+ (also from Newegg, along with a whole bunch of other goodies ) yesterday evening. A week 49 AIUHB. I haven't really had a chance to overclock it yet, but it looks promising so far. BTW Stang_Man, what was your week #? I'd assume it's the same, but I'm just wondering.
    Nov 2002
    Mountains of N. AZ.
    Loaded :
    no, it's a 2100+ b core from newegg. 02/48? Aiuhb - it's the one in the pic on the egg.
    Shuki :
    that way seems much easier! LOL
    thanks for the linkage bro!
    2.5 ghz 250 HTT
    Dec 2002
    Tempe, AZ
    AIUHB 0301
    MY HEATWARE
    Jan 2003
    Holland
    okra thats great only @1.65Vcore and not even cooled whit wc or prom/vapo
    Nov 2002
    Mountains of N. AZ.
    yup, it's a "poor man's" overclocker, LOL
    2.5 ghz 250 HTT
    Dec 2002
    Tempe, AZ
    i just tried to unlock by connecting the 5th L3.... and... no go..
    i also tried doing the zif socket with the little piece of wire, and i couldn't get my cpu in, so i just said screw it.. i used a piece of an ATA/100 cable like SPQQY did..
    MY HEATWARE
    Nov 2002
    Berkeley, CA - USA
    Originally posted by Stang_Man
    AIUHB 0301
    Stang_Man,
    What voltage at 2.34ghz?
    Got the same chip tonight - will test tomorrow
    --fibo
    Epox 8RDA3G+ v2.0
    AXP 2100 "B" (11.5 x 200fsb) - 2.3GHZ
    ATI Radeon XT800 XT (Omega Cat 5.8)
    3x512MB Corsair XMS 3200 3-2-2-5 @ 2.77v
    SLK-800 w/ SmartFan II
    Windows XP Pro w/ SP1
    2 Seagate Barracuda 120GB 7200rmp 8MB
    1 LiteOn CD/RW - 1 Pioneer DVD
    Anix Platinum XP Case modded
    Dec 2002
    Tempe, AZ
    Originally posted by fibonaccov
    Stang_Man,
    --fibo
    1.95 volts
    good luck
    MY HEATWARE
  18. #18
    Dec 2002
    Any ideas which is better for OC, a AX 2100+ AIUHB 0248 or AX 2100+ AIUHB 0249 or maybe a later build, like 0301 or 025x ?
  19. #19
    Dec 2002
    Germany
    Wanna sell it? Tell me details!
    <img src="http://www.prometeia.de/3dmark.jpg">.
    My system
  20. #20
    Jun 2002
    A fair few people have said the earlier ones are better, some have said the later ones are not as good. Then again a few have had good results with the later ones.
    There is in a sense a correlation between good cooling the right voltage and compatible hardware and not to say the least, good luck.
    Hope this helps,
    They will fall at his feet....... But eBay @ZZHOLE still ripped me off!
  21. #21
    Jan 2003
    Holland
    sorry I saw a lot of people don`t hit high on that 2100+ so I don`t take the change anymore.
  22. #22
    Dec 2002
    I don't want to take chances either, this is why I was asking which is better.
    I have a friend that owns a computer shop and I can get whichever build date I want, but until I know I get a good OC for sure, I won't get any.
    He only tried one 2100+ AIUHB 0249 and he hit 2300MHz at 1.70V easy.
    But the rest of the CPUs we cannot touch unless I buy one, because it's not very fair selling used and heavily OCed CPUs to people after that, is it ?
  23. #23
    Jan 2003
    Holland
    wel why not, most of the people even don`t know wat OCing means, if he knows whitch cpu clocks good you must buy it or I thing your a bit crazy.
  24. #24
    Dec 2002
    That's exactly it, we don't know which one OC's best so the only way would be to test them all, and he didn't agree to that. If we fry or brake any of the CPUs, it's out of his pocket, so....
    Anyway, that's why I am trying to find out if there's a rule to tell which code/color OC's best.
  25. #25
    Jan 2003
    Holland
    if you only get 1.75V to the chip nothing would die en you know enough to find out witch wan hit the most.
