Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Thread: Step by Step VDD mod 8RDA+
    Nov 2002
    Could you guys make a step by step vdd mod guide. I am confused on what to buy at the RadioShack. Links would be great as well. I would like to not solder but if its necessary then what the hell. I heard SMG grabbers are not a good perminant solution. I just put a P$ HSF on the chipset so cooling is taken care off. Please post pics of how urs turned out.
    .EDIT IMPORTANT: For clarification here it is. The yellow cable is hooked up to the middle pin on the vr and the black cable is hooked up to the outer pin on the side with the adjustment screw. If u do it this way then turning LEFT gives more resistance and LOWER (safe) voltage and turning right give high voltage. If u don't have a multimeter u can hook it up as I did and turn all the way to the left (counterclockwise) to achiev a neutral setting to start out with. I think this is info that ppl were most confused about.
    Here is my complete mod
    All works well. I am now running 210mhz rock solid at 1.74vdd. It is red in the boot up health but i don't think that matters.
    xp2100+@2550mhz 2.03v 210fsb
    Abit nf7-s v1.2
    ATI R9700
    2x512mb Cprsair pc3500 c2
    Dual Channel!!!!!WOOT
    SATA raid on 80gig maxtors
    highest 3dmark 19300
    3dmark2k1
    Jan 2003
    Arizona
    Alright here it is step by step:
    1. First you need your materials: i used this pot from radioshack http://www.radioshack.com/product.as...Fid=271%2D342, you also need either smd grabbers (which you can't get locally at radioshack) or tools for soldering, and finally a heavy gauge wire (ie battery leads but it really can be anything). Also I would HIGHLY suggest getting a digital multimeter so you know exactly how much resistance you are giving the voltage regulator before you start it up the first time.
    2. Once you have your tools in order you need to set up your pot. The wire that you will solder to PIN 1 will be attached to the MIDDLE pin of pot. The grounding wire that you will solder to pin 4 OR any ground (ie case) will be attached to one of the other pins on the pot. So now you should have two wires, both of which are soldered onto the pot, one in the middle and one on one of the ends.
    3. At this point i would test the pot and set it for your desired setting. About 740~750 Ohms should give you about 1.8 v for the chipset. So take your multimeter and measure from one wire to the next (making sure to have it set on OHMS first). In order to adjust that little knob get a mini screwdriver or a razor and turn it while measuring either clockwise or counter-clockwise to get your desired resistance.
    4. Once you have the resistnace dialed in its now time to do the actual mod. I would suggest against using smd grabbers as in my limited experience they are very hard to use and will not stay on and if you really want to, you can always take off the mod by heating up the solder and pulling it off. Anyways onto the mod. The chip you are looking for on your board is labeled, IOR 3037A. It is located between the first dimm slot and the nb and will have a large coil just south of it and one to the left. Here is a pic for a more visual representation: .
    Ok now we have found where we are going to attach the mod. The first pin counting from left to right is where we want to attach the wire from the MIDDLE pin on our pot. At this point you can either solder or using an smd grabber. If your going to try soldering, i would suggest going very slowly as the pin is very small and very close to other pins that you could short out by soldering. Don't panic though if you do get solder on lets say the 2nd pin just heat the solder up with your iron and try and move it over/clean it up with something disposable (ie paper tower or tissues). Moving on, the ground wire, the wire attached to one of the ends of your pot now should be attached to either pin 4 or to any part of your case. Personally i attached my ground to the case by use of a screw (ie you unscrew it a little bit, shove the bare end of the wire into the gap and screw down till tight).
    5. At this point the mod is essentially done. Here now are a few pics of the finished mod just to give you guys an idea: and another pic here:
    That does it for the mod. All thats left now is to turn on your computer and let her rip with those high fsb's! Hope this little guide helps any newbs out there like me. And btw if you ever feel like adjusting your vdd voltage again its as simple as turning the nob on your pot but be careful to do it slowly. On a pot like the one i have above this is not so much of an issue but still don't just go blindly turning without abandon.
    edit -- eh whoops the pics aren't workign so i had to remove them. You can get the pics i was using over at http://www.hardforum.com/showthread....5&pagenumber=1 . Scroll down and you will see the pics of the finished mod.
    New Rig
    e6600 week25 a2 w/ Ninja Plus
    2x1gb Team 667 3-4-4-8
    ASUS P5B /w Thermalright hr-05 on nb
    XFX 7900gtx
    160gb Dell "raptor"
    Wester Digital RE2 2x500gb (WD5000ys)
    Plextor 755sa
    Antec NEO HE 550watt
    Lian Li PC-V880
    Nov 2002
    the pic u linked to shows the left pin being connected to the outer pot leg and the right pin connected to the middle !?!?! I have everything to mod i just need verification that i will use the correct pins. Also how should i turn the pot to attain no v change. I want to start out with a neutral setting and then increase voltage.
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
    Jan 2003
    Arizona
    You can do it the way in the pic, its just you can not attach the wires at either end. In order to attain a neutral setting you will have to measure the resistance. For simplicity's sake just make sure the pot is set to 1k ohm when you put it in your comp. AFter that you can adjust it accordingly.
    New Rig
    XFX 7900gtx
    160gb Dell "raptor"
    Plextor 755sa
    Lian Li PC-V880
    Nov 2002
    I did the mod. My first soldering job ever and it worked!!!! I will not get a multimeter so can I use the setting it came at. Is there a rule such as all the way to the right or left will give me 1kohm? I don't want to dish out the money for a meter just for this mod.
    Thanx =)
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
    Jan 2003
    Arizona
    Turn it clockwise as much as you can and you should be fine as this increases the resistance. The only way you can be 100% sure is with a mulitmeter but turning it clockwise should be effective. Once you start it up the first time you can then turn it down and watch you voltage change in bios.
    New Rig
    XFX 7900gtx
    160gb Dell "raptor"
    Plextor 755sa
    Lian Li PC-V880
    Nov 2002
    Thanx Professor. It seems ur the all knowing in this thread LOL. Hopefully I will boot it up today. I need gaskets for my swiftech pelt before satrat. I will also mod my r9700 since i kinda like this new soldering skill i just picked up. Its really fun. On to mod everything in my puter. heheh
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
    Nov 2002
    I picked up a multimeter from RS and i am trying to set my resistor. I set the meter to the 2k range and I get a reading of 0.072 does this mean 720ohms or is this actually 72ohms. If i turn left or counterclockwise the number goes up. This doesn't make sense as u said that all the way to the right is the highest resistance. So what should my LCD display if I want lets say 720ohms ~1.85v right?
    I am almost sure that 0.072 means 72ohms.... When i desoldered the pot from the board it read .268 i set it to .780 and found the max to be 1.032. That makes sense its a 1k pot. Here is a new question. Should the resistance change after i solder the pot to the board. If so all is good if not then i must have fugered up on soldering to pins 1 and 4. I hope it is meant to change when connected. Pls anwer asap if u can.
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
    Jan 2003
    Arizona
    hmmm thats odd but it depends on where you were trying to measuer it after you put it on. YOur reading before of .720 is accurate and you should base it off that unless you somehow cut the wire or possibly got too much solder on? I am really not sure why the reading would change but as long as you set it before you solder it on it should be ok.
    New Rig
    XFX 7900gtx
    160gb Dell "raptor"
    Plextor 755sa
    Lian Li PC-V880
    Nov 2002
    Do u think the mod is done good? Can u check if urs shows the correct resistance at the pins?
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
    Oct 2002
    Hey just a quick question, will a fixed 730Ohms resistor be ok to use with this mod? That should be enough volts but not too much right?
    Cheers
    Jan 2003
    Arizona
    Yeah that should give you 1.84ish depending on what your initial voltage was.
    New Rig
    XFX 7900gtx
    160gb Dell "raptor"
    Plextor 755sa
    Lian Li PC-V880
    Jan 2003
    Netherlands
    On my pot, when I use the left and middle pin I have to turn it all couterclockwise to get 1K, and when I use the right and middle pin I have to turn it all clockwise... Isn't this the case with all pots?
    I wouldn't risk using it without a multimeter, it is set the wrong way (close to 0 Ohm) you'll give a LOT of voltage to the NB I'm afraid...
    EPoX 8RDA+, VDD mod, modded NB & SB cooling, and one less mosfet :P
    2500+ AQUCA 0308 Barton @ 2365 MHz (11x215)
    512MB Corsair XMS 3200 C2 Pt + 512MB Twinmos/WInbond 5ns @ 430 MHz 5-2-2-2
    Prolink GF4 Ti4200 @ 320/575, modded GPU & mem cooling
    Oct 2002
    This is why using a fixed resistor is a wise move instead
    Jan 2003
    Arizona
    Yeah thats how i think it. From what i have read a pot works by moving resistance on the pins from one end to the other. So one end will be at 1k ohms and the other at 0. Then as you turn the pot they equalize and it shifts the other, sorta a slider effect.
    New Rig
    XFX 7900gtx
    160gb Dell "raptor"
    Plextor 755sa
    Lian Li PC-V880
    Nov 2002
    I can verify that as turning to the right gave me almost 0ohms so without the multi i would be really screwed. Any word on measuring resistance with the pot soldered to the board. I'm really iffy about booting up my board, but i have time couse i have to wait for parts.
    Did i screw up the mod.
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
    Jan 2003
    Arizona
    Well like i asked before where are you measuring the voltage for this? As long as you measured the resistance through the wires before you put it on and it was good then, I see no reason why there should be any discrepancy before or after. Perhaps someonelse may be able to help?
    New Rig
    XFX 7900gtx
    160gb Dell "raptor"
    Plextor 755sa
    Lian Li PC-V880
  18. #18
    Nov 2002
    University of Pennsylvania
    is it safe to turn while its hot?
  19. #19
    Nov 2002
    Supa MAn: YES
    I did test befor and set it accordingle. Just worried that it gives me different reading when soldered to the mobo. Oh well i'll live with it.
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
  20. #20
    Oct 2002
    South Suburbs of Chicago
    Thumbs down WRONG!
    You're lucky he got a multimeter and didn't listen to you, he would have smoked his board!
    If you turn the pot all the way clockwise then you will see the full resistance of the pot between the middle pin and one of the outer pins (safe). The other pin will be a DEAD SHORT (0 OHMS!) to the middle pin, which is the way he had it hooked up at first (transistor BBQ).
    The resistance on the pot reads differently after it's connected to the board because you are reading not just the resistance of the pot but also resistance (and capacitance) of the mobo circuit connected in parallel to the pot. If you don't change the pot and disconnect one of the wires, you'll see the same reading you had before you installed it. All normal.
  21. #21
    Nov 2002
    Thanx for confirmtion i posted pics up above
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
  22. #22
    Oct 2002
    Nice job PJ!
    You might want to put some electrical tape on those bare connections (and the live unused pin) on the pot, that's what I do. It would suck to have a connection touch something it shouldn't (like back of vid card).
  23. #23
    Nov 2002
    Originally posted by Spartacus
    Nice job PJ!
    Speaking of my vid card check this out here
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
  24. #24
    Nov 2002
    Sticky?
    Abit nf7-s v1.2
    ATI R9700
    3dmark2k1
  25. #25
    Dec 2002
    Jersey City, NJ USA
    what kind of soldering iron do I need? I saw a 30 watt one I thought of picking up. It is a straight jobber not shaped like a gun. Is this ok to use? Also what kind of solder do I need? I saw some really thin kind. Can you reccomend the right size? Also where can I get those wires. When at Rat Shack I looked for 9volt battery leads but they had none. Is any wire ok? What gauge is correct?
    Also I had picked up a micro size 1k pot
    Is this ok to use, Or should I just return it to get the 1k 15 turn?
    I am really sorry for all these questions.
    I really appreciate anyone who takes the time to answer these questions!
    Couldn't figure I am a noob when it comes to v-mod's huh?
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
