Results 1 to 17 of 17
Thread: Vdd question (Epox 8RDA+)
    Jun 2002
    Hello all.
    Let me fill you in on some background information.
    I picked up an AIUGB stepping 2400. When coupled with my watercooling setup (Cathar White Water CPU block, Ehiem 1048, High Quality Stubby Arse heatercore/shroud) and system (Epox 8RDA+ (C27), 256mb PC-3200 TwinMOS, Antec 550watt PSU) i was able to squeeze 2482 (12x 205) out of it at 2.025v prime95 stable. I have since gotten a classic model vapochill. Summer here has killed most of the high clock speeds, it was basically 25 USD + my old watersetup to go to this classic unit, and i couldnt refuse given it would hold the CPU temperature below ambient no matter what the air temperature was anyway.
    Going on, i got the classic unit vapo, and while setting up my system to recieve it, i cracked the processor not on the corners, but on the lower ridge of the CPU die. I set it up anyway, plugged it in, and got a post. I was able to clock the processor to 2400mhz @ 1.85v, and running a higher voltage made no difference to the CPU clock speed. Yesterday/lastnight, i left Sandra doing CPU Arithmetic via the Burn-in Wizard, with the CPU set to 10x 200 @ 2.075v. I woke up this morning, attempted to clock higher, and found it made no difference.
    I just plugged in my SMD grabber, with the Vdd dialed to 1.75v. I am now running 2482 (11.5x 215) @ 1.975v. My processor was unable to boot, let alone prime in windows at this speed beforehand.
    Can the Vdd affect CPU stability/overclocking?
    Nov 2002
    ShAkYgRoUnD
    I like the 2400/8RDA combo...
    ~~Stepper~~
    A Man of Wealth & Taste
    Outta my mind...back in 5 min
    www.spotajavacoffee.com
    X_Peed2400
    Epox-8r_Da
    Anorexic_TruePowDer 550waste of ca$h
    M_ax C_ooling X_pence462+/Semi_Smart Fan II
    2*512Mb Cors_hair X_tra M_oney S_pent PC3200c_a$200.00
    ATI Radiation8500
    Sin2k/MaXtor'd60giggleATA133
    Memor_XXX 4.8x2.4x4.8
    Every one of these parts has blown uP and been replaced!
    Nov 2002
    ShAkYgRoUnD
    I haven't done any mods...cause I can't see well enough to do em...
    ~~Stepper~~
    X_Peed2400
    Epox-8r_Da
    ATI Radiation8500
    Xtreme Mentor
    Jun 2002
    PA, USA
    Dang, I take it those screenshots are clear to you stepper? Blury as hell to me, lol
    E8600. EP45-UD3P. 500FSB 24/7. Still WinXP. Heatware
    Dec 2002
    Germany
    @ what vcore are u running?
    <img src="http://www.prometeia.de/3dmark.jpg">.
    My system
    Nov 2002
    ShAkYgRoUnD
    Well...when I hit the print screen button and then paste the shot in paint...I get a 2.5mb bitmap...which I can't post...so what U see is the result of reducing the size and changin it to a jpeg...if U'd like...I can send U the 2.5mb file...
    ~~Stepper~~
    X_Peed2400
    Epox-8r_Da
    ATI Radiation8500
    Nov 2002
    ShAkYgRoUnD
    2.1...I'd use the 2.2...but I've already hosed 2 bios chips doing that...I could get more outta it with the 2.2 vcore...but...what for...
    ~~Stepper~~
    X_Peed2400
    Epox-8r_Da
    ATI Radiation8500
    Xtreme Mentor
    Jun 2002
    PA, USA
    Nawww...I just thought you were using a windows accessibility option or something to counter your vision as you mentioned it wasn't so good. Just thought the pic kinda looked like when I look thru my wife's glasses
    Nov 2002
    ShAkYgRoUnD
    ^5...np...I am blind as a bat...blind in one eye...can't see out the other
    ~~Stepper~~
    X_Peed2400
    Epox-8r_Da
    ATI Radiation8500
    Nov 2002
    Plano, TX
    Stepper, very nice . How are you getting the 223 FSB without a voltage mod??? I haven't seen anyone near that high without it
    Epox 8RDA v1.1 | Athlon XP 2100+ AIUHB 0301 @ 2205 mhz (200x11) @ 1.8v | Radeon 9800 NP @ 378/324 | 2x256 MB of Corsair XMS PC3200 CAS2 | Maxtor 80gig 5400 HD | Linksys LNE100TX | SLK-800 w/42.5 cfm Sunon 80mm fan | Antec SX830 w/Antec SL400 PSU
    Nov 2002
    ShAkYgRoUnD
    Ya gotta understand...I don't run FRANK at those speeds...I jus set him uP at optimal settings jus to see "IF" he'll run there...this is a 'BIGG RICHARD' thing...an I've got really BIGG Feet...knowhatimsayin...a lot has to do with how I run Frank's hd...so as not to get corrupt files...runnin voltage that'll for sure roast the bios...turn off all the background BS...and hours and hours of twistin Frank's knobs...which he really doesn't like...I usually run Frank at jus ova 200fsb so as to be able to use the 3200's 400mgz...U know I've blown Frank's brains out twice...one thing that I'm not sure about though is...I got this chip from a dude that used it in a Prometeia ( READ FROZEN! ) so jus maybe this chip is a tad different from the run of the mill chips...who knows...
    ~~Stepper~~
    X_Peed2400
    Epox-8r_Da
    ATI Radiation8500
    X.I.P.
    Oct 2002
    Australia
    Bravo,
    If someone could answer the following questions then maybe it would shed some light on why your CPU can go faster when the Vdd is higher (even with a higher multiplier and lower FSB .. clarified via ICQ).
    1. The CPU uses several voltages not just Vcore. So what parts of the CPU use Vcore only?
    2. I suspect the ATGL tranceivers (FSB I/O pins) use a different voltage than Vcore as they are bipolar transistors not CMOS. So does Vdd affect the FSB I/O voltages?
    3. Does the PLL run at Vcore or some derivative of Vdd?
    Can anyone with some detailed info on the XP or NForce2 shed some light on this?
    Cheers
    CodeRed
    Jun 2002
    The plot thickens.
    I dialed the Vdd to 1.80v, and Vcore up to 2.15v, and left the CPU priming/using Sandra Burn in (CPU/Mem @ 12x 200). Got up this morning, and she is now prime95 stable @ 2499 @ 1.975v.
    My 5/12/3.3v lines are looking horrible however:
    12v = 11.49v
    5v = 4.73v
    3.3v = 2.86v
    What does the 3.3v line do? Im worried about it being so low.
    Set me free.
    A64 3200 @ 2250mhz (10x225 @ 1.6v) | Chaintech ZNF3-150 | 2x 256mb Corsair 3200LL TwinX @ 2.5-2-2-7-12-16 | 256mb Albatron 5950 VIVO | 80gb DiamondMax 9 | Pioneer 106 | APC 2200RMI3U UPS
    X.I.P.
    Oct 2002
    Australia
    Bravo,
    starting to get a few ideas. The XP model 8 has 3 voltages fed to it
    3.3V --> dont know what part of the CPU this feeds
    VCCA 2.5V ---> PLL & I/O
    VCORE 1.65V ---> guts of the CPU
    Maybe VCCA is controlled by or derived from the chipset voltage????
    Nov 2002
    Plano, TX
    Originally posted by Bravo
    The plot thickens.
    12v = 11.49v
    5v = 4.73v
    3.3v = 2.86v
    Bravo, if you have a nForce2 board, the 2.86 reading is probably your voltage to your memory, rather than the true 3.3 volt rail. I believe that is a problem inherent to nForce2 boards (at least if you are reading it anywhere in Windows (e.g., with MBM).
    Nov 2002
    Plano, TX
    Stepper, even for a BONZAI benchmark run, 223 without vdd mode is incredible! I doubt I could get anywhere even close (but I need to do some work on cooling the NB and SB!)
    Jun 2002
    Ar good.
    Set me free.
