Well since uber bios did now't.....................................
I'm strugglingnot got suitable tools micro grabbers are too big
been trying for past couple of days to get a good mount point/correct mount point.
but for those intrested plug in CM3708 into google or whatever
download the data sheet then see if you can get it modded
Look near your AGP slot for a 16 pin IC small un if you measure
the voltages you will see 1.6v +- a bit uneffected by AGP bios
voltage changes.
Not sure if I am modding the correct pin I'm using a cap I think
links to pin 11(VFB) but I am either shorting or linking to wrong
part, voltages jump to 2.2 -- 2.3v PC Boots but locks at bios did
manage 1.9xx Volts runs for 10-20 sec then locks.
MOD IT AT YOUR OWN RISK BUT I AM SURE ITS THE CHIPSETS VDD
