Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
Thread: A7N8X Hidden BIOS option
    Jan 2003
    Exclamation A7N8X Hidden BIOS option
    'CHIP Voltage Control'
    it's disabled by default
    adjustable up to 1.8v
    the sucker
    the guys over nForcersHQ are doing some bios moddin'..
    could it solve the 200MHz limitation?
    Dec 2002
    United States
    Hmmm, sounds interesting. Yeah, I bet it could easily solve the 200MHz FSB problem . Anyone with a A7N8X wanna test it out?
    - Radea
    -Specs-
    Outdated Crap.
    Jan 2003
    Sweden
    They are testing it... we're all waiting up tonight for results. :-)
    I can test it as soon as my extra BIOS chip arrive, it's late...
    Jan 2003
    Sweden
    Here's the modded BIOS that allows chipset Voltage control!
    http://www.nforcershq.com/forum/viewtopic.php?t=3972
    Nov 2002
    MA.
    Awesome if it works out for you guys with this mobo!!!
    Zen2 Has brought AMD back!
    Jan 2003
    Sweden
    No report on raised FSBs yet, but the BIOS definitly works at least.
    Nov 2002
    MA.
    Well it will be awesome for ya's if it turns out to help raise the fsb... there are a few guys that can raise theirs without this mod, they may even get better results.
    Dec 2002
    i downloaded it, didnt flash it yet, i got a history report due friday and i want a working comp untill then
    Unoriginal Macho Energy
    Dec 2002
    I flashed to it. I was at 200 before and I'm still stuck at 200 dual sync. I have it at 1.8 too...
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Jan 2003
    I am using it now (1.8v). 3dmark still unstable but I can run prime95 at 200fsb which I was unable to do before.
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    I will test this in a bit... I'm hooking up my pelt to my mobo tonight. Waterproofing it right now (waiting for it to dry).
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
    Jan 2003
    raising the chip voltage doesn't make any difference.. at least for me
    Dec 2002
    United States
    Well thats not fun . I wonder if the option actually works? Maybe its hidden because its not actually operational atm?
    - Radea
    -Specs-
    Outdated Crap.
    Jan 2003
    yeah.. maybe.. but lucky ppl who own the 'miracle' board that can run over 200MHz claimed that it works.. 225MHz!
    now lets see the what 'Platinum Plus' can do with his a7n8x
    Jun 2002
    OOO baby, I can't wait. I'll be doing it today. I had to let the liquid electric tape dry last night, and the fumes got to my head (so I didn't put my pelt on the chipset). I WILL do that today though for sure. Gonna shoot for some horrendously high fsb speeds.
    Jan 2003
    No love for me either but since its there, hopefully Asus will open it up in thier future bios release.
    Nov 2002
    Canby, OR
    i believe epox said they will be adding an option like this, but it requires pcb changes. figures.
  18. #18
    Nov 2002
    I flashed with this new bios, and also tried the max of 1.8, and it did not give me access to any additional performance FSB multiples. I'm still stuck at 3dMark of 18,201
    • A-64 3500+ (NewCastle w/ stock retail cooler)
    • Ultra X-Connect 500 PSU
    • OCZ EL Plat Rev-2 (2x512) DDR 400 (PC 3200) Dual Channel Kit
    • MSI Neo 2 Platinum (S.E.'s BIOS 1.C3 Standard-using default settings)
    • X-800XT PE
    • Audigy 2 X-Fi Fatality
    • Seagate Barracuda 160GB x2
    • Plextor PX-712A DVD Burner
    • Windows XP Pro SP2
  19. #19
    Dec 2002
    IMHO the Asus has a disadvantage in relation with the Abit and EPoX Board.It uses the older 2-Phase voltage regulation which isnt so good.Abit and EPoX make some time now use of a 3-Phase VR what is fundamentaly better for overclocking...
    But i hope im wrong for you guys
    bye
    Crozet
  20. #20
    Jan 2003
    Manchester - UK
    I'm gettin confused
    I thought that the main problem with overclockin this board was dependant upon which capacitators it had.
    i.e - the Nichicon boards being the ones you could heavily increase the FSB, and the Rubycon boards being the ones that become unstable at 200FSB and above.
    Is this not entirely correct? I didn't think that bein able to increase coltage on a Rubycon would make any difference.
    My board has Rubycons and I'm stable at 190. Not tried to increase voltage or do any other mods until my crystal orb arrives and memory coolin kit.
    I'm interested in knowing the score though!
    I wish I didn't know now, what I didn't know then!
  21. #21
    c[_]
    Nov 2002
    Alberta, Canada
    I wonder if the dead A7N8X issue is related to the Rubycon caps dieing..?
    All along the watchtower the watchmen watch the eternal return.
  22. #22
    Jan 2003
    Manchester - UK
    Oh no! Please don't say that. I got rubycons. I hadn't heard of any dying, just that they couldn't be pushed as far as the Nichicons. I'll keep a look out. I've only had the board a week so I may try and blag a refund/exchange yet
  23. #23
    Jan 2003
    Sweden
    Originally posted by Another User
    I'm gettin confused
    No, plenty Rubicon owners have reported good overclockings, including 220+ MHz.
  24. #24
    Jan 2003
    Does this mod works? I am stuck in 192FSB too. Anyone get any improvement, please post.
  25. #25
    Jan 2003
    Sweden
    What mod? The capacitor issue is because boards are shipping with different capacitors, but my conclusion is that it doesn't matter.
