Results 1 to 12 of 12
Thread: prob w/ nf7
    Nov 2002
    Wellesley, MA
    prob w/ nf7
    I have two probs w/ the new nf7 (non -s) that i have:
    1) it will not do high FSB's. I do not know what exact FSB it will not boot into windows but it will boot into it at 166mhz, but not at 180, 190, and 200. I have corsair xms 3200 ram that i am positive will do 211fsb with only 2.5v. I have tried all of the voltages on the ram and northbridge. it is not a question of my cpu being stable cause my 1700+ will not do 7x200.... it will post, but not go into windows
    2) i can not use a USB keyboard and Mouse together. i had the same prob w/ my old 8rda+ . i ge a motherboard resources error in windows.
    CPU=1700+ Tbred B
    512mb Corsair XMS 3200 Cas 2.5
    Albatron turbo gf4 non oc
    audigy in slot 4
    integrated sound, cpu thermal throttling disable in bios.
    -2600 mobile AQYHA 0346 XPMW Y @ 2600mhz 1.9v (hits brick wall after this)
    -Water Cooled- Dtek Spiral and Dtek NB Block, Ehiem 1250, Dtek Rad... around 43C Full Load
    -DFI Infinity
    -2x256 Twinmos BH5
    -Geforce FX 5900 XT
    Nov 2002
    MA.
    I use an adapter for my usb keyboard myself...... never even bothered to try and use both at the same time.
    Zen2 Has brought AMD back!
    Nov 2002
    Wellesley, MA
    A usb/ps2 adapter? it doesnt work w/ the MS Natural Pro Elite probably cause there is a built in usb hub.
    I have narrowed down the issue. I am able to run any fsb i want using the 11.0x and 11.5x mults. Anything under that, i can not run a SINGLE MHZ above 166mhz and boot into windows. seeing how my cpu maxes out at 11x180, this is not good. all i have to say is WTF! abit needs to come out w/ a bios to fix this unless someone else knows something...
    -DFI Infinity
    -2x256 Twinmos BH5
    -Geforce FX 5900 XT
    Nov 2002
    Wellesley, MA
    this is crap i still cant get it to work w/ mults 8.0-10.5x i even changed my ram from 1x512corsair xms 3200 cas 2.5 to 2x256 winbond pc3200 and i still have the same friggin prob!
    -DFI Infinity
    -2x256 Twinmos BH5
    -Geforce FX 5900 XT
    Nov 2002
    Canby, OR
    i believe this is a known problem with the NF7 motherboard.
    there might be some answers in here:
    http://www.xtremesystems.org/forums/...&threadid=6934
    Nov 2002
    Wellesley, MA
    that is w/ 333fsb cpus. i dont need to cut a bridge cause my CPU is 266mhz and thus should work 100% fine
    -DFI Infinity
    -2x256 Twinmos BH5
    -Geforce FX 5900 XT
    Nov 2002
    Canby, OR
    i know there is another similar thread around here. the problem has to do with low mults and high FSBs. they get into it a little in the thread i linked.
    Overclocking Guru
    May 2002
    SoCal, USA
    Aug 2002
    weird never had trouble getting high FSB with multi under 11
    Intel Core i5 2500k @ 4.7GHz
    Gigabyte Z68X-UD3H-B3
    8GB Corsair DDR3-1600
    MSI GTX 680
    XFX 750W Black Edition
    Corsair Carbide Air 540
    Aug 2002
    screenshot at 10.5
    MSI GTX 680
    Dec 2002
    N kali
    yeah i had the same problem with my NF7, my XP1800 would do 1.8ghz without a hitch at 100 and 133 fsb. But can barely do 1.5ghz at 166+ fsb. I rma'ed it twice for other problems i've been having with it. allstarshop finally decided just to give me a refund. Kimberley from allstarshop said they were going to pull the NF7-S off there shelves because of the volume of RMA's there getting for bios failures. so bust out my trusty kg7 again. If i were you i would try to get a refund and wait for the rev2.
    Nov 2002
    Wellesley, MA
    guys i figured it out w/ help of OPP... disable APIC and then reinstall windows and everything works great!
    -DFI Infinity
    -2x256 Twinmos BH5
    -Geforce FX 5900 XT
