Ok, this is uber-beta... but I thought I would share with other people.
Here's the file: http://www.maximumoc.com/files/Mbm5.exe
Please do keep in mind, very beta, it may not even work for you. I will try it as soon as I reload my OS.
This is the email:
Code:
Hello all (again on BCC)
1st of all thank you for the scanner test results I have gotten yesterday
and today. They all where perfect but they also all showed a big speed
diffrence in the smbus when there are a lot of devices. This would seem to
indicate that running mbm at 1 second interval will not be the smartest
thing to do, although time will tell I am sure.
Included is MBM 5.2.2.0 and I would like to ask you all to not yet send it
around or post it, there have been a lot of changes in this version (see the
readme file) but for all of you I suspect only the NForce2 mathers :)
You can simply install this MBM over your current version and all your
settings will be saved, I also asume you all know how to set MBM up.
A thank you of course goes to Nvida for their help on this and to Dickie
Tsang who has been testing all my builds before they went out to you all.
Please let me know how MBM works for you and if you do then please include
an MBM system info together with your board type.
As soon as I have enough positive replies I will make this a public version.
thank you all for testing
Regards, Alex
