Results 1 to 14 of 14
Thread: EPoX 8RDA+ and internal diode?
    Oct 2002
    Germany
    Hi,
    I just want to know whether the EPoX Board is able to read out the internal temperatur diode of the Athlon XP?
    If so,is it possible to read it out with MBM?
    Sep 2002
    Nottingham, England
    I have an 8RDA+ and according to Epox Tech Support it reads temps from the terperature diode on board the CPU.
    I don't use MBM5 so i can't really help you with that.
    "There is only one thing better than having a linebacker in your office, and thats having two linebackers in your office"
    12.7Ghz folding for XtremeSystems
    Nov 2002
    I know it at least uses it for the cpu shutdown feature. Here is how I have my MBM5 setup
    CPU:winbond2
    Mobo: WinBond3
    Seems to be exactly like BIOS.
    xp2100+@2550mhz 2.03v 210fsb
    Abit nf7-s v1.2
    ATI R9700
    2x512mb Cprsair pc3500 c2
    Dual Channel!!!!!WOOT
    SATA raid on 80gig maxtors
    highest 3dmark 19300
    3dmark2k1
    Jun 2002
    chicago
    It does not read the internal diode for monitoring, only for shutdown. The temp you see in BIOS and in MBM reads from a thermistor that is actually in the ZIF socket under the pins. It's a stupid place for it.
    Cursed be the ground for our sake. Both thorns and thistles it shall bring forth for us. For out of the ground we are taken for the dust we are and to the dust we shall return
    Heat
    Nov 2002
    Plano, TX
    man, that's a bummer. The one thing I didn't think to check on before I ordered one today. D*mn, I just assumed ~every~ new motherboard these days would read off the diode
    Are you sure SPQQKY?
    Epox 8RDA v1.1 | Athlon XP 2100+ AIUHB 0301 @ 2205 mhz (200x11) @ 1.8v | Radeon 9800 NP @ 378/324 | 2x256 MB of Corsair XMS PC3200 CAS2 | Maxtor 80gig 5400 HD | Linksys LNE100TX | SLK-800 w/42.5 cfm Sunon 80mm fan | Antec SX830 w/Antec SL400 PSU
    hwbot crew
    Jun 2002
    Belgium!
    @brainstorm: i believe spqqky is right, the necessary components to read out ondie temp, are removed on the 8rda+
    By the way, isn't it obvious? Those temps on my 8rda+ are WAY too low to be true.
    HTPC (win xp): Turion MT-30 @ 2Ghz | NF4 | XFX 7900GT | 26" TFT
    Development (mac osx): Macbook Pro | Core Duo 1.86Ghz | 1.5GB DDR2
    Sep 2002
    Portugal
    And with a prom they are too high
    Jun 2002
    Slovenia
    Epox remove support for reading internal diode after 8k3a board, they got too manny stupid emails and quiestions from folks that don't have a clue, about why there temps were sudenly so hi, and all they did was changing the mobo
    That's why I'll never sell that mobo, it is one of the very rare mobos that read internal diode.
    Jan 2003
    Seattle, WA
    Was the internal diode temp the temperature that you would find in the Bios? I always thought that my cpu temp was colder then it really was because I could run some fairly high voltage around 1.95V to 2V with it overclocked my xp1600 at around 2gig and it wouldnt' really go above 40-41C. When the cpu got to around 40C it seemed to get unstable so I thought maybe it was actually higher. Sadly i had to send it back cause it stopped working for the 2nd time and I got a 8RDA to replace it. Thanks for any info.
    Antec TruBlue 480W - Epox 8RDA - XP2100 'B'@12x220mhz=2652mhz@1.85V Max: 2800mhz@2.125V
    2x256mb PC3200 Twinmos 3-2-2-2 -
    WD 120gig/80gig 8MB Cache Maxtor 30/20gig 7200rpm
    Radeon 9500 Pro & 9700 Pro
    3dMark2001:15756
    MCW50-T, 2xD-Tek Procore Combos, Hydro L30, 2xYS-Tech 120x38mm, Nexus Fan Controller, 10ft Clearflex60 1/2in, Swiftech 1/2in F&B kit, Pump Relay Switch V2
    Dec 2002
    Anyone have any idea what Winbond 1 temp is? It was reading about 12C-17C but after a bios update its gone to reading around 5C. What exactly does this temp sensor monitor?
    Jun 2002
    Slovenia
    On air ? Basicaly the way to know you have temps. measured with internal diode is this. In mbm you set interval for sensor reading to 1sec. and then you go from idle to max load. if the sensor read internal diode it will jump almost the same second to 4-5 °C (water cooled) . On the other hand in socket diode is much slower so it wont show any quick changes of temperatures.
    Btw for 8k3a in mbm for reading internal diode you have to choose Winbond Diode 2 for cpu sensor. And one last thing this wasn't working with from first bios release it was implemented a little later, but if you have any bios later then the best one 2815 it will work
    Oct 2002
    FL, USA
    yea I get one temp sensor on mine too that is like 12c...I think its a flaw because there is no way anything in my case is that cold.
    Jan 2003
    Seattle, WA
    Yes it was on air. SLK-800 with 80mm tornado. I also had AS3 on it. Do you think those were the right temps?
    3dMark2001:15756
    Nov 2002
    Plano, TX
    I hadn't actually seen any temps from 8rda's posted, so I didn't know. Oh well, I've lived without on-die temps since my celly 300A, I guess I can live a few more years without it...*lol*
