Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: 8RDA+ Bandwidth Goodness, Tweaks, etc.
    Jun 2002
    Eagle River, AK
    Ok guys, This is the place to post your results of bandwidth goodness, tweaks, chipset Vmod, etc. with the 8RDA+. This is an effort to keep all the discussion unrelated to Vmods out of the Vmod forum and consolidate...
    I'll start off with some mild bandwidth at 218, Cas2, 4-3-2. I noticed that setting the Trp to 2 made a huge difference in the Float score..
    DFI NF4-SLI Expert
    3700+ CABGE 0515SPMW @3.2ghz (291x11) 24/7
    Prometeia Chilled!
    7800GTX Watercooled
    TwinX1024 XMS4400C25
    WD 74gb Raptor
    Dell 2405FPW
    www.LATENIGHTBOYS.com
    Sep 2002
    Boston, MA
    229x10, 5-2-2-2 timings. VDD @ 1.85v, VDimm @2.9v
    The VDD mod was excellent, and the only way to get tight timings at high FSBs for me was to set at 6-3-3, then burn-in for a few minutes and go to 5-3-3, to 5-2-2 and I've got it to 4-2-2 just not stable enough to pifast. Setting to Aggresive gives about 20 more points too The PCmark is not too high because it tests video and I'm using a ti4200 @300/600.
    XP2400+
    Abit NF7 2.0 Vmem and VDD modded
    256MB Kingston HyperX PC3500
    Sapphire 9500np (Vref, Vmem, Vddq, Vcore modded)
    Fully Phase Change cooled
    Jun 2002
    Eagle River, AK
    I've matched your sandra, however, this is at 4-2-2-2 timings, VDD @ 1.97v!, Agressive CPU. Looks like going with the 4 instead of 5 for Tras is worth about 4mhz fsb.
    DFI NF4-SLI Expert
    Prometeia Chilled!
    7800GTX Watercooled
    WD 74gb Raptor
    Dell 2405FPW
    Sep 2002
    Boston, MA
    I knew it...The 4 Tras does help, but I know for a fact my sandra scores are lower than what they should be. Look at my float score and look at yours (100MB/s difference)...something is a bit off and I dunno what it is. Also my estimated max bandwidth is higher too, I have no clue what happened there
    XP2400+
    Jun 2002
    Dual bank bushboy. It does wonders for Float
    Set me free.
    A64 3200 @ 2250mhz (10x225 @ 1.6v) | Chaintech ZNF3-150 | 2x 256mb Corsair 3200LL TwinX @ 2.5-2-2-7-12-16 | 256mb Albatron 5950 VIVO | 80gb DiamondMax 9 | Pioneer 106 | APC 2200RMI3U UPS
    Jun 2002
    Eagle River, AK
    Dunno if it makes much difference but that is with Sandra 2003.
    ..and yes, Dual Bank/Channel. CPU@~2600mhz also.. my friggin screen was flashin quite a bit @ 225, even with the 1.97Vdd. I'm thinking at this voltage I need some watercoolin on that Nbridge..
    DFI NF4-SLI Expert
    Prometeia Chilled!
    7800GTX Watercooled
    WD 74gb Raptor
    Dell 2405FPW
    Sep 2002
    Boston, MA
    Oooh I thought it was only single channel. That's very impresive 225mhz DCDDR. All this time I've been comparing float to dual channel thinking mine was off :p
    XP2400+
    Xtreme Christmas Lighter
    Jun 2002
    Upstate NY, USA
    Here's my current dual channel high...
    (anybody else think Sandra is only testing one channel?)
    Oct 2002
    Yup it is Sandra doesn't recognise dual channel memory at all yet.
    Jun 2002
    SC
    227fsb but score a little lower 6/2/2/2 at 2.9v 9x227fsb
    dual channel
    http://www.geocities.com/winxp/8rda2...?1041579486234
    DFI Infinity, XP2500 M, 3-256meg sticks Twinmos PC3200 bh-5, ATI 9800np,
    HPT raid card, 40 an 80 gig WD hd, Enermax 431, Win2000
    Heatware
    Jun 2002
    Earth/France/Corrèze
    226.99 x 11.5
    timing: aggressive 2,2,2,7
    dual channel synchro
    vdd 1.87v air cooled
    v-ddr 2.88v
    http://membres.lycos.fr/ftpad/images/record-1e.gif
    learn A.K.A JP
    Jun 2002
    Eagle River, AK
    What is the deal with the ram timings on this board... At 217fsb, I went from cas2, 4-2-2, to 3-2-2, and saw no difference in sandra bandwidth... The change from 4 to 3 being the Tras.
    Additionally, I see some of you running 2,2,2,7 while others are 6,2,2,7... (last two threads)..
    So are you guys just quoting your timings backwards? I always quote in the order they appear in bios.. Tras, Trcd, and Trp..
    Just curious as I'm trying to find the best aggressive timings right now... just dinkin around..
    DFI NF4-SLI Expert
    Prometeia Chilled!
    7800GTX Watercooled
    WD 74gb Raptor
    Dell 2405FPW
    Sep 2002
    Boston, MA
    I haven't tried going from 4 to 3, but I did notice a significant change in 5 to 4, in 3dmark too. I'm impressed with how tight I can run timings at such high FSBs...I remember my IT7 that didn't allow me to run 2-2 timings at all! And as a result...15k with a ti4200
    XP2400+
    Jun 2002
    Eagle River, AK
    I haven't tried going from 4 to 3, but I did notice a significant change in 5 to 4, in 3dmark too...
    That's the only change I noticed too.. Going from 5 to 4.. 4 to 3 didn't do jack!
    DFI NF4-SLI Expert
    Prometeia Chilled!
    7800GTX Watercooled
    WD 74gb Raptor
    Dell 2405FPW
    Nov 2002
    Wellesley, MA
    does the prob still exist where you lose massive bandwith using mults under 10.0?
    -2600 mobile AQYHA 0346 XPMW Y @ 2600mhz 1.9v (hits brick wall after this)
    -Water Cooled- Dtek Spiral and Dtek NB Block, Ehiem 1250, Dtek Rad... around 43C Full Load
    -DFI Infinity
    -2x256 Twinmos BH5
    -Geforce FX 5900 XT
    Sep 2002
    Boston, MA
    Yes, but for people with Tbred Bs, it shouldn't be a problem It's a real problem for lower clocked CPus though unfortunately...Again, a BIOS fix is needed.
    XP2400+
    Jul 2002
    Maryland
    Wierd
    Here's a PCmark run at 220 5 2 2 2
    http://service.futuremark.com/compare?pcm=972895
    Sandra at those settings
    I knew where I was when I wrote this...
    I don't know where I am now.
    GB P35-DS3R q6600@3.15 Kubuntu Linux
    Asus P5B-DLX q6600@3.0 Ubuntu Linux
    GB 965-DS3 e6420@3.2 Gentoo Linux
    Asus Commando e6420@3.2/1950XTX Winders/VMWare/Kubuntu
    MSI Neo2 Plat Opty170@2.8 Debian Linux times 2
    IMac 2ghz c2d OSX 10.4
    Xeon Dualie 3.2Ghz Ubuntu 6.10 times 2
  18. #18
    Jun 2002
    Eagle River, AK
    Tried 4-2-1 timings and it wouldn't even go into bios.. must not like the 1!
    DFI NF4-SLI Expert
    Prometeia Chilled!
    7800GTX Watercooled
    WD 74gb Raptor
    Dell 2405FPW
  19. #19
    Jun 2002
    SC
    I dd a little checking with my thermal probe this morning after thinking about RichBa5tard mobo dieing from chip overheating from vdd mod. Mine is set to 1.84v, I have 2-60mm fans one blowing in area of mem an one lower blowing in area of southbridge with heatsink on it. I disconnected the fans to make it easier to check temp on the 3037 an the small one just to the left of the 3037. Booted up an started prime figuring putting a load on system would give me a more accurate temp reading of chip temps. Without fans 3037 42C, small chip to left 58C, prime ran for about 10 minutes an errored this is at 10x205fsb 2.77v to mem. Yesterday had no problems running prime, so what is going on here. Started prime again an 5 minutes error again. Reconnected fans an check temp running prime again check temps 3037 32C small black chip to left 38C an prime running now for about 3hrs an no errors. So cooling this area made a diference.
    Just rechecked chips an 3037 30C an chip to left 33C now.
    Heatware
  20. #20
    Jun 2002
    Upstate NY, USA
    Good work WinXP!
  21. #21
    Jun 2002
    hello,
    yes, it' s 7,2,2,2
    t ras / t rcd / t rp / cas
    learn A.K.A JP
  22. #22
    Oct 2002
    Germany
    PCMark sandra follows...
  23. #23
    Dec 2002
    Germany
    Mhh, Sandra detect only one Channel?
    Why do E7205 get over 4 GB/s wit FSB lower than 200 MHz?
    <img src="http://www.prometeia.de/3dmark.jpg">.
    My system
  24. #24
    Oct 2002
    Germany
    tada
  25. #25
    Jul 2002
    Norway
    That is because the P4 uses Quad channel FSB, and the Athlon only DDR. I wont do the math for you, but i hope you get the picture
    Intel i7 3930K C2 @ 4700 mhz (100 x 47) 1.4v
    EK Supremacy/EK XTC 420+280/EK DCP4.0/PrimoChill 1/2 ID 3/4 OD
    Asus Rampage IV EXTREME
    16 GB G.Skill RipjawsZ @ 2400 CL10-12-11-1T
    Zotac GTX670
    Antec Quattro 850W
    Intel 330 180 GB + Micron C400 128 GB
    LD Cooling PC-V7 B/R
