Just so you all know the item labelled as AGP voltage in bios is actually the chipset voltage. Raising this to 1.8v from the 1.5v stock will give you a considerable boost in memory speed.
Figured this out last night and it took me from DDR472 100% stable in windows to DDR485 100% stable in windows.
I believe its labelled AGP voltage as its altering the northbridge (AGP and MEM controller) voltage. Well its the only rational explanation I could come up with.
Anything above 1.8v makes little or no difference for me. The heat output of the northbridge is substantially higher. Im using an IT7 northbridge heatsink with the Epox 40mm fan. The base of the heatsink is pretty warm, but nothing to worry about.
PiLsY.
