Results 1 to 6 of 6
Thread: Overclocking and cold boot alarm although o/c infact stable.
    Nov 2002
    Kent, England
    Overclocking my xp2400+ causes the bios to alarm on cold boot. Its ok with a reset and maybe a soft off but and PSU off and it don't like it. A bios reset is in order here. This kinda puts a dampner on the overclocking fronts. It seems to effect the overclock which needs 1.925v rather than an overclock which needs 1.85v. I have the epox 8rda2c16 bios . Not only that it have seemed to frig over my router. I just twigged it was the router when I had a brainstorm and connected the ethernet directly to the cable modem and it worked. Then I unplugged the router, plug back in and reset it. Then after a reboot or two it works.
    I thought my win xp network settings were to blame. The root cause was overclocking and reseting the bios after it triggered an alarm. What gives?
    Nov 2002
    Kent, England
    I need a second opinion about this. Should I expect this kind of trouble from overclocking my CPU?
    Nov 2002
    Kent, England
    I read a thread on another forum about a similar problem and it suggested turning off the bios temp warnings. This has so far solved my problems. 2339Mhz with 22'c cpu temp watercooled.
    Xtreme Mentor
    Jun 2002
    PA, USA
    Yea, I have that same problem on my duallie. It runs stable, I think the temp sensor is faulty. I only get the alarm upon reboot, so if I shut down then power back up, I don't get it. This is with it disabled in the BIOS too. Good luck
    E8600. EP45-UD3P. 500FSB 24/7. Still WinXP. Heatware
    Dec 2002
    I get warm boot problems when running my KG7 RAID above 167FSB. I think its problem is the mem voltage as above 2.92 it does it.
    I can run it 2.85v but its unstable so I run it at 2.92v.
    Not bad for such an old board :p
    - LL V1000 - GA965P-DS3 - Intel C2D e6420 3.22GHz - 2GB OCZ 6400 Plat Rev 2 - GeForce 8800GT KO AC S1 - 500w Enermax Liberty -
    Xtremely slow runner
    Nov 2002
    I've had the same problem when i was running my board at 170MHz, i don't know if it's the ram (i'm using pc2100 at cas2) or the mobo. I personnaly think that the mobo can't easily handle such fsb
    The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
    Av by Frisch This is not a Lime tree
