Results 1 to 20 of 20
Thread: Which HD:s can go above 210 fsb?
    Nov 2002
    Sweden
    As the title sais...
    Whats the answer to this question?
    Xtremely Pale
    Dec 2002
    new jersey
    im not sure if its so mutch the the hard drive that will have problems as it will be the southbridge pci controler. i my self am concerned about this problem so im curently experimenting with a scsi 160lv fiberchannel drive and a controler card thats on its way.
    so ill post if it solves my problem.
    Dec 2002
    B.F.E.
    I have read that Maxtor higher end drives stand up well to higher fsb.
    I read elsewhere that it does make a difference if you are running a RAID or not, and what the controller is. One thread I read, stated that the 8mb buffer drives crapped out more often at higher fsb speeds than the 2mb buffer ones did.
    What mobo you using btw?
    A7V8X KT400
    2400+ AIUCB 0240 @ 2.3GHz
    PNY Ti 4400 -=14,396Marks=-
    MSI Ti 4200 8X/128DDR -=13,520Marks=-
    1x512 Geil DDR 2700 -- 2,2,2,6,1T
    True550 PSU
    Nov 2002
    Back in London
    Got an oldish samsung 40gb that works a treat, my amd system (kx7) was fine all the way to 222-225fsb which was simply the boards limit, depending on what sort of day it was having...
    ]JR[
    Dec 2002
    Chesapeake, VA
    maxtor or wd... using same title?
    In the works...
    Aug 2002
    if you're talking about IDE drive then Seagate Barracuda IV is one of them, if not the best. it never held me back @ UDMA mode
    2600k @ 5.0Ghz 1.54V, Giga Z68, Zotac GTX680 AMP!, Patriot 1066Mhz 8GB RAM, Custom water, Silverstone 1000W, HAF932
    Jun 2002
    Get an IDE RAID card--I hear these hold out longer than the onboard RAID controllers.
    Oct 2002
    UK
    Hey borg bob nice to see you on xtreme
    Kosmos
    I think you need worry more about 2 things....
    PCI bus speed, and is the ram fast enuff not to give cache errors...
    210fsb is np on some mobos no matter what the HDD...
    I use a silicon image raid card with 2x80gb maxtors in raid 0 and am yet to have a hd error that wasnt memory related...
    It is by caffeine alone I set my mind in motion, it is by the beans of Java that thoughts acquire speed,
    the hands acquire shaking, the shaking becomes a warning, it is by caffeine alone I set my mind in motion.
    My OCHW ReviewsPrometeia Cooled XP2700+ @ 13x211mhz 2.75Ghz Epox 8RDA+ 2x3500xms Corsair Cas2
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    The Promise PCI cards Ultra DMA100 or 133 can handle the first one about 48MHz PCI speed and the second one ,over 55MHz PCI Speed...
    INTEL PWA FOR EVER
    Dr. Who my arss...
    Nov 2002
    Sweden
    Im using a ga-7vaxp card and 8 mb cache wd HD:S, i know it aint the mem crapping out...
    When i bought the HD:s everybody kept praicing them... but now when im been running them for some time, im getting pretty anoied... They are realy holding me back... and i don't feel like buying new HD:s either, cause the wd:S are realy great for storage and moving stuff around...
    So the reason i asked bout high fsb hd:s is just for getting the maximum out of my cpu, and do some benching
    Sry for bad english... im having a couple of beers with my friends
    Nov 2002
    Sweden
    Sounds like it will be a maxtor hd for benching
    Dec 2002
    Chesapeake, VA
    For christmas I am trying to get a new harddrive and a raid card for overclocking. Can anyone suggest to me a good raid card? promise, hi point? what model?
    In the works...
    Dec 2002
    Seems like the onboard promise raid will crap out as low as 38mhz PCI
    Nov 2002
    Sweden
    yup it will... and it suxxx0r
    Dec 2002
    North Adams, MA
    i have a POS maxtor 10gig ata66 running on the ide channel of a at7 max board with the fsb @ 200mhz (50mhzPCI) and she is running without a glitch, still awating my 80gb seagate cuda4...
    i desided to put a heatsink on the southbridge cause she was getting a lil tosty
    AMD Opteron 165 Dual Core * CCBWE:06/04:TPMW
    DFI Lanparty SLI-DR
    2x512 OCZ PC3200 Gold VX
    XP90c (for now)
    Ati X1900XT
    Hitachi Deskstar 250GB SATAII
    Sintek 500W single rail SLI Modular PS
    Gigabyte 3d Aurora Black Aluminum Case
    Viewsoinc VX922 19" 2ms LCD Monitor
    Xtremely slow runner
    Nov 2002
    What about the card with pci lock, is there a problem on the ide channel?
    The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
    Av by Frisch This is not a Lime tree
    Nov 2002
    Sweden
    Gonna try chilling the southbridge too, guess it wont help though...
  18. #18
    Dec 2002
    North Adams, MA
    might not help, but it sure wont hurt, personally i dont like to have toasty bare components, as with anyhting elese, heat compromises stability
    DFI Lanparty SLI-DR
    XP90c (for now)
    Ati X1900XT
  19. #19
    Nov 2002
    Sweden
    yah thats 100% true!
  20. #20
    Sep 2002
    NY
    I was worried about this Before I bought 4 of these for a RAID 0 Array... On My New Prome/Lian-Li Project. I had a post up, to which several people replied, positively...
    On that, I bought one to test, and confirmed it's ability to withstand the FSB speed I required... Then I bought the other 3...
    WD1200JB SE.... @ 219 FSB With no problems...
    RoydRage
