Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Exclusive: Abit updates nForce2 boards, changes names and expands to 3 models
    Xtreme Legend MrIcee's Avatar
    Jun 2002
    Cambridge, NY
    Thumbs up Exclusive: Abit updates nForce2 boards, changes names and expands to 3 models
    Check it out here, more info here
    Based on the NVIDIA® nForce™2 SPP chipset, supporting the latest AMD Athlon XP CPUs with a 333MHz front-side bus, and featuring new dual 400MHz DDR memory controllers, ABIT's NV7-Series is multimedia perfection combined with advanced ABIT Engineering.
    Maximum Memory for Multimedia Applications
    Dual 400MHz memory controllers deliver up to a 50% increase in memory bandwidth, and optimized 128-bit architecture means reduced memory latency. Three DDR DIMMs allow support for up to 3GB of 333MHz or 2GB of 400MHz DDR memory, and advanced memory architecture provides the power to drive the latest 3D games and multimedia applications with unequalled smoothness and realism.
    ABIT Engineered for Performance and Stability
    Only ABIT allows for the Front Side Bus to be adjusted up to 237 MHz-at least 17 MHz higher than the closest competition. This overclocker friendly FSB is made possible through ABIT's use of a 5 bit Frequency ID (FID); other motherboards use a 4 bit FID. While others may offer higher voltage adjustments, only ABIT guarantees that all of our settings will work. Our ABIT Engineers are overclockers too, and have tested all the settings. The reason for this guaranteed overclockabity? ABIT's 3 phase power solution is back. This ABIT Engineered solution ensures more power to the CPU (up to 75-80 W v. 60 W with a 2 phase solution) while overclocking, providing rock-solid system stability. This means fewer crashes for ABIT users and higher overclocks. Finally, with ABIT's CPU H.T.P (CPU Hardware Thermal Protection) Technology for ABIT AT7-MAX2/KD7 and nForce 2 series motherboards, CPU burn-out through cooling malfunction is averted, ensuring your high performance ABIT motherboard won't crash and burn.
    JBELL
    Guest
    I soo want the new nFORCE!!!!
    and you need that link on the front page!
    Overclocking Guru
    May 2002
    SoCal, USA
    Looks like some interesting stuff coming up, this good take AMD up there with Intel as far as 3D
    OPP
    Nov 2001
    Wichita, KS
    What he said
    Sep 2002
    California
    Thumbs up
    Now let's hope the boards will arrive here next week!!!!
    I will keep you guys updated.
    NF7-S v2.0
    Thermaltake Xaer 6000
    Barton2500+ @ 2420 220Mhz x 11x
    Thermaltake Volcano 11
    ATI 9700 Pro AIW
    SB Audigy Plat.
    Inspire 5300 5.1
    2x512MB Corsair XMS PC3500 2-2-2-6
    HPT RocketRaid PCI card
    2x40GB Maxtor ATA133 Stripe 0
    2x45GB IBM ATA100 Stripe 0
    Plextor 20X10X40-12 DVD-CDRW Combo Drive
    Plextor 504A DVD+/RW
    Team #13285 <a href=http://folding.stanford.edu/cgi-bin/userpage?name=ABIT_Marketing><font color=#ff0000>My Folding Stats</font></a>
    <img src=http://www.abit-usa.com/images/folding.jpg>
    Xtreme AMD Fanboy
    Nov 2002
    Salem / Corvallis, OR
    To Abit Marketing
    A few questions if you don't mind:
    1. Will the NF7-S include the 4 mounting holes?
    2. How does its memory performance compare to similar NF2 boards (e.g. Asus A7N8X). At 166 FSB? 200 FSB?
    3. I've seen a 200 FSB jumper on the A7N8X. Does this denote that the nF2 is capable of either a 1/6 PCI divider or locked PCI? Speaking in chipset generalities of course. It is known that AGP speeds are lockable.
    4. Any word on pricing / availability?
    Thanks in Advance.
    We're all anxiously awaiting a viable option to via
    I am lame
    Dec 2001
    Originally posted by IFMU
    What he said
    fa sho!
    JBELL
    Guest
    Re: To Abit Marketing
    I hope so for my Qpower's sake!
    ditto
    I know on ASUS pci was locked .. would hope it was chipset standard
    5. Could you send TheNakedReview a review sample?
    Thanks in Advance.
    Sep 2002
    California
    All i know is no 4 holes is confirmed because the way the board is layed by the reference design of the nForce 2 chipset. I will have more updated information of your other questions when the production samples come in.
    NF7-S v2.0
    ATI 9700 Pro AIW
    SB Audigy Plat.
    Inspire 5300 5.1
    Xtreme Legend
    Jun 2002
    Hong Kong
    Smile
    I need some boards to test, or I am going to work for EPOX!
    DDTUNG
    Overclocking Guru
    May 2002
    SoCal, USA
    Yea, what ever happened to DDTUNGs Mobos
    OPP
    Jun 2002
    Ouetr Banks of NC
    Re: Exclusive: Abit updates nForce2 boards, changes names and expands to 3 models
    This item could be very interesting. Wonder if they are talking about AMD's "4 bit FID" Multiplier "ID" settings which are sent to the Northbridge via 4 "separate" FID pins to set appropriate system data/timings, as with 4 bits the max setting = 12.5X and AMD says all data beyond 12.5X stays the same. If so, how do they get the 5th bit info??...thru system/Multiplier interrogation??
    Or does this "FID" just apply to the FSB/Host Clock function, better "trimming/setting"...and have nothing to do with AMD's "FID"/Northbridge/sytem timings etc as speculated above??
    ABIT Marketing...can you explain??
    Thanks, John C.
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    any word on a working 1/6 pci divider?
    thats what I want the most...
    well, not really, but it sure would be nice.
    JBELL
    Guest
    if PCI is locked 1/6th dividers will not matter...
    Oct 2002
    UK
    Arrghhhhhhhhh! Nooooooooooo!
    I really need those holes. I Leadtek board has them. Might be able to find a pic if your intrested.
    JBELL
    Guest
    Concept and production most likely will vary .. HArry should have some definitew answers for us tomorrow or the next day...
    if you need water cooling and 4 hole boards are NOT availble... may I suggest this:
    SWIFTECH MCW372â„¢ Revision 2 Liquid Cooling Block This is a sweet little block that is just as good as it's bigger brother the SWIFTECH MCW462-Uâ„¢ Liquid Cooling Block but does not require the 4 hole to mount to the board!! The good guys at XTWERKS are the ones to talk t6o if interested!
    Oct 2002
    UK
    Thanks for the heads up but I just bought a watercooling setup that uses the mounting holes.
  18. #18
    Jun 2002
    Maryland
    I'm looking at getting a custom phase change setup built and no mounting holes won't do me any good... Argh!
    Antec TrueBlue 480
    Intel Core 2 Duo E6600
    Asus P5N32-E SLI
    ATI x1950xt 512MB PCI-E
    2x2GB G-Skill PC6400 DDR2
    2x74GB Western Digital Raptors in RAID 0
    2x36GB Western Digital Raptors in RAID 0
    Plextor 8X DVD Writer
    Sennheiser PC150 Headphones
  19. #19
    Jun 2002
    Denver, CO
    I have been waiting for this board and it looks great although I would like the option for 250-266fsb in there. I've seen other nforce 2 boards with the mounting holes. Please say this isn't true because it will definatley sway my decision about the board. I have to have the four mounting holes no exceptions for me.
  20. #20
    Jun 2002
    I think it has to do with how the PCB is layed. Space is at a premium around the processor, especially given the speeds at which these new boards operate.
    Set me free.
    A64 3200 @ 2250mhz (10x225 @ 1.6v) | Chaintech ZNF3-150 | 2x 256mb Corsair 3200LL TwinX @ 2.5-2-2-7-12-16 | 256mb Albatron 5950 VIVO | 80gb DiamondMax 9 | Pioneer 106 | APC 2200RMI3U UPS
  21. #21
    Oct 2002
    all the epox pics got holes, but im hoping abit comes through
    no holes = no buy for me
    a7n8x
    2400+
    2x256 corsair 3200c2
    BIG BLACK ANTEC CASE
    Water cooled
    tc4 - custom res and shroud by webmedic
  22. #22
    Nov 2002
    Southampton, UK
    Yeh, no mounting holes will be a bummer, im sure many buyers will be dettered and some may not even realise before buying
    Dave
    A64 @2720 w/ RBX, DFI NF4 Ultra, Radeon X800XL w/ Maze 4, Antec NeoPower 480, 1GB Geil PC4000, IIyama 19" monitor and maxtor diamondmax 80 + 30GB
  23. #23
    Jun 2002
    Austria, Europe
    I can't believe that ABIT would abandon the usual 4 holes. (though I saw the pics without them too)
    It would prevent me from installing my watercooling-rig.
    If ABIT will not change that, I will go with EPoX next.
    AMD Phenom II 940 black edition, DFI LP DK790FXB-M2RSH @ 240 x 15.5 | 4GB OCZ Platinum CL4 | NexXxos X² Highflow | 2x Eheim 1048 | Enermax EG701 | 2x WD3200AAKS Raid 0 | HD4870 watercooled | Win7 64bit
  24. #24
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    What does this mean? That boards will arrive that will be available to BUY? Or that sample boards will arrive that will be sent to reviewers?
    Thanks.
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
  25. #25
    Oct 2002
    Central PA
    To: Abit Marketing,
    So where do we stand, I have to build, when can I get one of the new N2?
