Since this board only allows setting the Vcore to 2.0v(which only applies 1.95v on my board), I thought maybe people would be interested in coming up with this mod.
The chip used on this board is the IRU3055(data sheet). Now I think the pin we need to work with is pin 3(Fb). This looks to be the same sort of setup as the 8KHA+ Vmod located over at OCInside.com.
I think I'm on the right path... If I'm correct above, how do I know what value resistor to try? I see an 220k was used on the 8KHA+ but I don't have any idea if that will give me +.2v or +2v?
Like I said, if someone has any ideas, please do share.![]()
It's begging me for more
Can do 2070Mhz stable with 1,97 (thats 2 in the bios). 2100Mhz is what i need, more is also good ofcourse
DDTUNG??
Can you look at this once more? I can measure some things if that helps.. I really want this to work, but I don't know what to do..
