Results 1 to 12 of 12
Thread: Poor memory bandwith on my Asus KV8 SE Deluxe (3200+ newcasttle)
    Aug 2004
    I have 2x512 Adata PC4000 on my ASUS K8V SE Deluxe. Currentrly it“s running at 442mhz 2.5-4-3-5 (no PCI/AGP Lock available) and it only gives me about 2700Mb/s on sandra“s mem buffered test.
    Is it normal that poor result? I don“t know how to better those results until I change this board with the DFI but here in Spain I“ll have to wait for it.
    I know the 3500/3700EB are better but will I be able to get a decent bandwith with this mem on the DFI?
    On my old P4-2.8C on the AI7 i865 it gives me around 4800Mb/s without overclock so i think the memory is OK but since I got the 3200+ and the asus I have too poor results.
    I know the timings of my mem are a bit slow but 2700mb is TOO slow in my opinion. I sopose that I won“t know if it works better on the DFI lanparty UT until I have it but I don“t understand how a common kingston value ram at 400 scores better on a friends Epox nforce3 250gb at default speeds than mine on an asus (via) at 442mhz. Timings are more relaxed on mine but it“s running at 42mhz more, so it should be compensated.
    SiSoftware Sandra
    Benchmark Results
    RAM Bandwidth Int Buffered iSSE2 : 2781MB/s
    RAM Bandwidth Float Buffered iSSE2 : 2782MB/s
    Int Buffered iSSE2 (Integer STREAM) Results Breakdown
    Assignment : 2748MB/s
    Scaling : 2746MB/s
    Addition : 2824MB/s
    Triad : 2806MB/s
    Data Item Size : 16-bytes
    Buffering Used : Yes
    Offset Displacement Used : Yes
    Bandwidth Efficiency : 79% (estimated)
    Float Buffered iSSE2 (Float STREAM) Results Breakdown
    Assignment : 2747MB/s
    Scaling : 2744MB/s
    Addition : 2832MB/s
    Triad : 2808MB/s
    Performance Test Status
    Run ID : BOURCH on sƔbado, 03 de septiembre de 2005 at 14:23:22
    Memory Used by Test : 511MB
    NUMA Support : No
    SMP Test : No
    Total Test Threads : 1
    SMT Test : No
    Dynamic MP/MT Load Balance : No
    Processor Affinity : No
    Page Size : 4kB
    Use Large Memory Pages : No
    Chipset 1
    Model : ASUSTeK Computer Inc Apollo K8HTB CPU to PCI Bridge
    Front Side Bus Speed : 2x 222MHz (444MHz data rate)
    In/Out Width : 16-bit / 16-bit
    Maximum Bus Bandwidth : 1776MB/s (estimated)
    Logical/Chipset 1 Memory Banks
    Chipset 2
    Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
    Front Side Bus Speed : 2x 888MHz (1776MHz data rate)
    Maximum Bus Bandwidth : 7104MB/s (estimated)
    Logical/Chipset 2 Memory Banks
    Bank 0 : 256MB DDR-SDRAM 2.5-4-3-3CL 1CMD
    Bank 1 : 256MB DDR-SDRAM 2.5-4-3-3CL 1CMD
    Bank 4 : 256MB DDR-SDRAM 2.5-4-3-3CL 1CMD
    Bank 5 : 256MB DDR-SDRAM 2.5-4-3-3CL 1CMD
    Channels : 1
    Bank Interleave : 4-way
    Speed : 2x 221MHz (442MHz data rate)
    Width : 64-bit
    Maximum Memory Bus Bandwidth : 3536MB/s (estimated)
    Features
    MMX Technology : Yes
    SSE Technology : Yes
    SSE2 Technology : Yes
    SSE3 Technology : No
    EMMX - Extended MMX Technology : Yes
    HTT - Hyper-Threading Technology : No
    What“s wrong with my config?
    Aug 2004
    Inverness, Florida
    I dont know man but that is a very look score..
    But AMD does like a 1:1 FSB/DDR ratio for the best performance most of the time.
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    1TB HDD + 2TB Ext + 1TB Ext
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    2GB+1GB G.Skill DDR2
    320GB HDD
    ATI HD 2600 Pro 256MB
    16GB iPhone 3GS
    GamerTag: ugp
    GamerTag: SadisticPuppets
    Aug 2004
    Inverness, Florida
    See here is mine at 215 (DDR430) @ 2.5-3-3-7 @ v2.60
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    320GB HDD
    16GB iPhone 3GS
    GamerTag: ugp
    Mar 2003
    Denmark
    tried enable 1t?
    Although I dont know if the option is present on VIA chipsets..
    "M-I-A"
    Aug 2004
    bias_hjorth, isn“t this 1t ??
    If it isn“t i“ll try that.
    ugp, mine is 221FSB 1:1 ratio. That“s why I am so confused about the poor result
    Aug 2004
    I thougth the 1CMD = 1T
    Since bias_hjorth post I've been trying with multiple bios configurations until i´ve tried disabling 2T command that was set to Auto. Now I only have 3100mb/s aprox. Altough that is not a good score, it looks much better
    Thank you all
    Aug 2004
    Inverness, Florida
    Well I have been able to hit higher then 215...I have done 225 but because of the crappy motherboard I have it doesn't supply enough voltage for the CPU to remain stable...
    If you have PC4000 you should be able to run it alot higher then 220 right? It is 250 by default on the bus right?
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    320GB HDD
    16GB iPhone 3GS
    GamerTag: ugp
    Aug 2003
    Chicago InsaneTek.com
    P4= Dual Channel
    A64 754= Single Channel
    P4>A64 in Sandra.
    Aug 2004
    Inverness, Florida
    Yeah it is single channel because the memory controller is onboard with the CPU itself. THe new 939s are going to be Dual Channel as well. And they are going to kick Intels Ass!
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    320GB HDD
    16GB iPhone 3GS
    GamerTag: ugp
    Aug 2004
    My problem is that i have a via MB that hastn't pci/agp lock, so my SATA raptor doesn't support more than 220 fsb. If I try to go more than 222fsb win dlls get corrupet and I have to reinstall win (I hate reinstalling win). I'm waiting for the DFI. Then I'll be able to push the AMD and the memory modules at least 250
    May 2004
    Sweden
    It really looks like some 2t bandwiddt with those numbers...
    Make sure u got 1t... else i got no clue what it could be~.
    Aug 2004
    Yes, on #6 I posted that I had 2T enabled and that I went from 2700 to 3100 mb/s disabling it. Now the only thing I hate is the AGP / PCI limitation. I can only continue waiting for the arrive of the the nforce3 DFI. But it'll take some weeks until we can order it here in Spain :'(
