Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: sempron 2200+ how to unlock?
    Jun 2004
    Indonesia - aren hill
    i have tried sempron 2200+
    SDA2200DUT3D
    BIXJB 0432CPMW lock multi
    with
    dfi ultra-al
    hynix-d43
    any bosy know how to unlock it?i already tried the L5 mod but no change....
    any comment?
    Nov 2002
    Malaysia
    If the Semprons are the same as the post week 39 2003 Bartons and Tbreds then if you have a NF2 board the L5 mod wont work as it only works on Via chipsets.
    Fused
    Dec 2003
    Malaysia
    if VIA/SIS chipset mod L5 and u can change multi with CPUMSR
    nforce2.. no body found it yet
    Jun 2004
    ok then L5 not working...i tried to conecct the L3 pin and hoping that i can get 11 multi by coneccting them all...but its still no result...
    any sugestion?
    Xtreme X.I.P.
    Nov 2002
    Shipai
    no hope... they are superlocked, no way to unlock them on an nf2 board...
    Feb 2003
    San Diego
    That's funny, they're the same thing as a thoroughbred.
    Take out your ex tonight... one bullet should do it.
    I've effectively killed my sig because it is no longer accurate. Oh well!
    A64 3200+ Newcie
    2x512 OCz PC3500 GX
    DFI NF3 250gb LPUT
    No Name 9700 that refuses to die!
    Jun 2003
    socket a sempron =
    Nothing but overpriced and underclocked thorton cores.
    Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
    Apr 2004
    just get a mobile barton ...
    Feb 2004
    waste of money... another plot from AMD trying to squeeze as much money from their old k7 core...
    Xtreme 3DMark Addict
    Sep 2003
    best thing he said! ebay that sempron, its just a locked crappy tbred and buy a moble barton and have fun!
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    Jun 2004
    i dont think its overprice in my country,it was even more cheaper than athlon xp.....
    i allready have a barton mobile....
    i just want to tried something new....
    come on there must be some thing that i can do to make it unlok.....
    Nov 2002
    Malaysia
    Yes buy a Via board! Thats all you can do!
    Xtreme Christmas Lighter
    Jun 2002
    Upstate NY, USA
    I'll be trying a 3100+ socket A once they are released. My bet is these will be the chips to get since they are more like the A64's little brother.
    Dec 2003
    Think again, the best thing you´ll get in socket A is a barton. We would be damn lucky if we ever get a 90nm 256KB socket A cpu.
    Jun 2004
    Cincinnati, Ohio
    Sempron Socket A is a super locked TBred well Thorton prolly in most cases who knows they might all be a mix bag of 256KB L2 cache chips rebandaged. Knock them all you will they tear the Celeron up and thats all they are meant to do.
    May 2003
    Edmonton Alberta
    Prehaps you should think again, the sempron 3100 is a socket 754 and has a integrated memory contoller like the a64's just with the 64 bit instructions turned off
    Oct 2003
    Massachusetts, USA
    Yes, the Sempron 3100+ is K8 based. No 64-bit and only 256KB L2 cache.
    The 2800+/2200+ are K7 based. TBred's basically.
    AMD XP-M 2600+ @ 2.4GHz (12x200) - 1.75v
    DFI NFII Ultra Infinity Rev. A
    2x1GB Crucial Ballistix Tracer PC4000 @ 400MHz 2-2-2-5 - 2.8v
    BFG 7800GS @ 475/1550
    OCZ Powerstream 600W (+3.6, +5.4, +12.6)
    Swiftech MCX462-V-->92mm Tornado-->MCX159-A
    nForce UDP 5.10
    Forceware 97.44 XtremeG
    Win XP Home SP2
  18. #18
    Feb 2003
    San Diego
    Get a KT880 board and you can probably unlock it hehe
    A64 3200+ Newcie
    2x512 OCz PC3500 GX
    DFI NF3 250gb LPUT
  19. #19
    Dec 2003
    And you then can tell me how will amd put a cpu with a integrated memory controller running in a socket A board, wich already has one. Among other architectural differences.
    Hey Kalway, how´s FSB overclocking in your a7v880?
    Does that board run 4 dimms nicelly?
  20. #20
    Jun 2002
    Upstate NY, USA
    This sure does look like a socket A 3100+...
    http://store1.yimg.com/I/buyxg_1807_44313129
  21. #21
    Feb 2003
    San Diego
    This board is really quirky. I needa get a barton to test it with because it doesn't play nicely over 200fsb with a 133 tbred. Perhaps a 166/200 fsb barton will play nicer.
    I even tried L12 modding it to 200fsb and it still wouldn't play nicely with the tbred. It detected the 200fsb default, but still wouldn't play nicely. Everything except 3d was stable. Hopefully some BIOS fixes will make it nicer.
    Since these are based on the thorton core, which is a hacked barton, they may play nicely. The board oc's to 230mhz fsb no sweat.
    A64 3200+ Newcie
    2x512 OCz PC3500 GX
    DFI NF3 250gb LPUT
  22. #22
    c[_]
    Nov 2002
    Alberta, Canada
    There is a 3100+ Socket A (based on AXP cores) and a 3100+ Socket 754 (based on A64 cores).. i've been away a week and even I know that!
    All along the watchtower the watchmen watch the eternal return.
  23. #23
    Dec 2003
    That´s either a fake image, or that´s something like a 2166MHz barton.
    I didn´t say there wasn´t a 3100+ socket A sempron.
    I was just saying you would never see a K8 running on a k7 board.
    Anyway i think the fastest things well see in socket A (unfortunatelly) is a overclocked mobile athlon XP.
    90nm shouldn´t come this way, but i sure like to get my hands on one. I was hoping a few months ago, that palermo was a 90nm Barton.
  24. #24
    May 2003
    Edmonton Alberta
    On the amd webpage i only found mention of a 3100 that was 754, if anyone can find the socket A one i would be interested to read about it
  25. #25
    Nov 2002
    Malaysia
    Where are you getting your information that 3100+ is Socket A as well?
    http://www.amd.com/us-en/Processors/..._11604,00.html
    The frequency of the 3100+ here would indicate it is socket 754 only. Are AMD releasing a socket A version in the future which is as yet unannounced and if so why would it be a 3100+ and not a 3000+?
