..anyone figured out how to get it to work yet??
I`ve seen my chip run over 3GHz, but without the PCI\APG lock..
Is there a BIOS or anything that will do what we want??
www.bleedinedge.com
bios 1005.021
it's never fast enough!
Sweet!!!
Thanks a ton man!! I`ve never been able to run this good 1:1.
Who says tight timing are what`s needed for bandwidth??
Check it out...with a 1gig kit OCZ PC3500EBs
Wow, insane bandwidth!!
Level 80 UD Death Knight on Murmur (Beta)
A8V 2.0 OR 1.02?
bewteen the 4 and 5th slots it says A8V rev 1.02Originally posted by AcUaViVa
A8V 2.0 OR 1.02?
Wow... and you are sure the locks are working now with tht bios?
How would I tell??
I crap out at about 249-250fsb 1:1, but I was thinking it was the memory seeing as how it`s only PC3500.
The world`s only triple phase-changer PC in one case.
they are working
you wouldn't get that far w/out locks
rukee you oc by bios or by clockgent?
this week i have a 3500+ and a a8v 1.02 like you
but my memory its adata 4000
you think tat i can hit 250 1:1 ?
2.5-4-3-10 1T
thanks
I boot at 220fsb, then use the setfsb to bump it up from there.
whats the difference between 1005.020 and 1005.021?
im testing the 1005.020 now, locks works amd seems rock stable at 2600Mhz still on air
never used 1005.020, just used the 21 variant. Heard the 21 was better, but I have no basis for comparison.
My locks work. Too bad my memory won't scale as high as Rukee's.
After testing both I have to say the 1005.020 is much more stable, and faster the 1005.021.Originally posted by JNav89GT
.... At least on my A8V v1.02![]()
hrm
I'll have to give it a go![]()
This is just getting crazzy!!!
Can this be PC3500???
I can`t believe it!!
1005.020 cant oc from bios to 250 fsb?
I can on mineOriginally posted by AcUaViVa
Awesome results Rukee![]()
u running those EBs with 2,8 vdimm ??
I duuno what they are at, I have the voltage set to 'auto'Originally posted by Blaster
I can on mine
updated screenshot....I can`t believe it myself!!![]()
damn can you hit 8k in sandra
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
what`s the highest anyone has seen??
...is this it??
Outstanding Rukee![]()
Can you run some Super Pi for Us?![]()
4930K@5.2GHz/ASUS RIV BE/G-Skill 16GB/4x EVGA GTX 780Ti Classified Kingpin Edition with EK-WB's/4x Rosewill Hercules 1600W PSU's for GPU's/Thermaltake 1200W for MB/Cooling: CPU-Vapo, MB/GPU: A/C Conversion Chiller
I wish I could run SuperPi there! :p
It`ll run Sanda at 262 and 01 at 259.
Strange is it scores the same in SuperPi @ 235 (32secs) as it does at 248fsb (32secs). What would the bottle neck be there??
superpi's scores have a pretty large spread from point to point as far as mhz and fsb go.
{2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
well rukee
i have the same bios but...
you can change de multiplicator of your cpu?
your oc is made with set fsb ?
you cant put up the vcore by bios?
