Results 1 to 11 of 11
Thread: DIY Mach 1 socket A mounting kit
    Aug 2004
    i'm going to acquire a mach 1 soon and it ownt come wit ha moutning kit and i don't want to apy $100 for one so anyone know if you can build one yourself?
    2500M @ 2875 mhz 250 x 11.5
    2-2-2-11 Mushkin Black Level 1 @ 3.3v
    9800 pro w/ removed shim 490 core/407 mem w/ modded vga silencer
    DFI Infinity NFII
    Lian Li Pc-65B
    Samsung 710T(no ghosting!)
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
    May 2004
    Tucson, Arizona
    yeah, its simple and will prob cost u like 20 bucks, get two peices of plexi glass, drill in the appropriate holes, get those long screws and the hand adjustable nuts(dunno if they're really called that) pick up some dense foam or neoprene
    take a look here:
    http://wwww.vr-zone.com/?i=230&s=1
    that should help u
    Aug 2004
    thanks!
    DFI Infinity NFII
    Lian Li Pc-65B
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
    Aug 2004
    so i could just put neoprene o nthe back and use it as a backplate? and just use plexi and nuts to hold down the evap head?
    DFI Infinity NFII
    Lian Li Pc-65B
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
    Aug 2004
    i don't have the backplates or anthing its just the mach1 and nothing else so do i actually need any parts of the kits or can i do all of it myself?
    DFI Infinity NFII
    Lian Li Pc-65B
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
    Apr 2004
    Is there anyone that still sells the mounting kits?
    Pentium D 930 @ 4.0ghz / Intel 975XBX / 1GB Geil Ultra Series PC-6400 3-3-3-8 / eVGA Geforce 8800GTS @ 620/930 / SB Audigy 2 ZS / Maxtor SATA 250gb / FPC Modular Antec 550w TruePower / Lian-Li PC60 / Vantec Nexxus Rheobus
    Aug 2004
    yea people still sell them but they're liek $100.... so i'd really like to save that money if possible
    DFI Infinity NFII
    Lian Li Pc-65B
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
    May 2004
    Tucson, Arizona
    u can do it all urself, everyone here who's made their own phase change units did it...so have confidence my friend :P
    ew
    *slaps mouth
    i think those words are too mature for a 17 year old hehe
    Aug 2004
    soo instead of having that plastic bracket in the front u think i could just put neoprene and dielecric grease instead ?
    DFI Infinity NFII
    Lian Li Pc-65B
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
    Nov 2003
    Boston, MA
    eh...
    1/4" aluminum plate with socket holes and mach 1 hose cutout > mach 1 evaporator head > 1/2" neoprene around the cpu socket with dielectric grease under it ( dielectric grease on the board, cpu pins, etc) > 1/2" neoprene behind mb with dielectric grease > 1/4" aluminum plate with socket holes (tighten down with threads and hexnuts)
    Or you can substitute the 1/4" aluminum with 1/4" acrylic.
    Aug 2004
    thanks i understnad now
    DFI Infinity NFII
    Lian Li Pc-65B
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
