Results 1 to 22 of 22
Thread: DDR333MHz @ DDR490MHz
    Mar 2004
    HELLAS
    Talking DDR333MHz @ DDR494MHz
    Hello to everybody,
    At September 2003 I bought a NoName 512MB PC2700 DDR333MHz with Infineon chips. Five months later I started the burn-in of that module. I burn-in that module for over 500hours and take me about 3 months to finish it. The maximum voltage I gave to that module was 3v, from 2.5v (default). Now I buy a P4 3.0C and I start the burn-in again using 1:1 dividers on my Abit IS7-e. I don’t know if that is a record or impossible to do it on a NoName memory module, but I’m surprised from that memory…
    I cool the memory using the Tt Alu Heatsink and a Tt SmartFan2 8cm…
    Until now the rock stable result are the following:
    Finally, but with some errors at, MemTest+ 1.20…
    Now I try to "catch" the 500MHz… (sorry for my bad English)
    Jul 2004
    Argentina
    o_o whoa its some kinda strange that that memorys could get that fsb...
    2008 Rig:
    Intel Core 2 Extreme QX9650 - 4 GB OCZ Reaper HPC DDR3 1333 - EVGA 9800 GX2 KO 1GB - EVGA 132-CK-NF79-A1 790i Ultra SLI - Cooler Master Cosmos 1000 - Cooler Master Real Power Pro 1250W - WD Caviar SE16 WD6400AAKS - Tuniq Tower 120 - Dell SP2208WFP
    2006 Rig:
    AMD Athlon 64 3800+ X2 @ 2600 mhz - Asus A8N-SLI Platinum - OCZ 2*1GB Gold GX XTC PC4000 - OCZ Powerstream 520w - Gigabyte 7900GT 256 mb - Western Digital 250 GB Sata-2 16mb - Western Digital 200 GB Sata 8mb - Sound Blaster X-Fi Platinum - Zalman 7000-cu Led - Thermaltake Tsunami Dream - Vantec Nexus NXP-301
    Nov 2003
    Nice oc, sometimes you can get lucky with the generic mems. Could you give us a picture of the heatsink attached to the memory?
    Fastest A64 3400+ in the world running at a nice 3359.59mhz:
    http://valid.x86-secret.com/show_oc?id=18225
    Jul 2004
    Sweden
    245 Mhz is really good for one who is 166 @ stock....
    Mar 2004
    HELLAS
    I use the following heatsink, but i put AS Ceramique.
    http://www.thermaltake.com/support/i...emory/op01.htm
    A photo from PC Wizard 2004....
    Sorry for the bad photo, but my camera have only 1.3megapixel....
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Nice work dmylonas....
    Keep going and maybe you can reach DRR500.....
    E8400 4400(Q814A015 Wafer **91)@1.296 Vcore
    Q6600 (L733B458)@4054 1.5 Vcore
    ASUS P5Q Unmoded - 2X2 GB Corsair Dominator 8500
    Blaster AUDIGY 2
    Sound Blaster Megaworks Speakers 2.1 250D THX / 300 WRMS
    ATI 4850 512MB @750/1150 Stock cooling
    LG W2600HP-BF 26" Wide TFT Monitor (S-IPS)
    System Cooled by ThermalRight Ultra 120 Extreme
    System Powered By OCZ 600W
    Limits do NOT exist
    Mar 2004
    HELLAS
    I'm back again... After a lot of burn-in.... My module run at 243MHz rock stable with 2.9v...
    Mar 2004
    HELLAS
    My module can run at 247MHz - DDR494Mhz but after 1 minute in MemTest+ 1.20 it give me a lot of errors...
    I will continue the burn-in tomorrow morning.... Now i go for
    Apr 2004
    there where no fast internet is
    nice oc but do you sure thats no 6a chips or relabeled bh5/5 ?
    Pentium M 755 @ 2,3Ghz
    DFI 855GME-MGF
    2x 512MB Infineon 5-C
    3x 160GB Samsung SATA
    Hercules 9700 Pro
    Lian LI PC6070B
    Ein Elch ist der, der guckt wie ein Elch
    c[_]
    Nov 2002
    Alberta, Canada
    try 3-4-4-8
    All along the watchtower the watchmen watch the eternal return.
    Jul 2004
    Central USA (Indiana)
    that is some damn fine work, DMylonas! I used to have some generic PC2100 that did ~DDR440 w/ 2.9v. Didn't ever find out what chips were in them before I sold the suckers.
    Apr 2004
    too bad it's still in single channel.
    A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
    c[_]
    Nov 2002
    Alberta, Canada
    single channel is only 5-10mhz faster, if you are lucky.
    Jan 2004
    Manchester (UK)
    Worth a go though
    How is the fan held over the ram? maybe I can do that with my OCZ EB when I get it, to cool it well with a 80mm fan. I would be trying for some high fsb.
    May 2004
    Club DFI Fanboy-in-Chief
    You want crazy RAM ?
    Here : -
    - 9.5 x 261 (2476 MHz), 10 3 3 3 3 - Dual, 3900 - 3600 MB/s
    - 10 x 258 (2577 MHz), 10 2 2 2 3 - Dual, 3900 - 3600 MB/s
    - 10.5 x 248 (2600 MHz), 10 2 2 2 3 - Dual, 3750 - 3450 MB/s
    - Everyday use : 10 x 256 (2556 MHz)
    - Athlon XP-M 2400+ IQYHA 0346 on DFI Infinity A+ (BIOS 12/31 - Nvidia 4.27)
    - (1 x 256) Twinmos PC2100 and (2 x 256) OCZ PC3700-EL
    - Voltages : 2.0-core / 3.1 to 3.3-dimm / 1.8 to 1.9-dd / 1.6-agp
    - Delta 38 x 80mm on SLK-800-A + 10mm spacer - 32-50C Idle, 37-53C Stressed
    - Powercolor Radeon 9800 XT at stock (Cat 4.8), 3DMk 01/03 - 18,500 and 6,500
    May 2004
    Tucson, Arizona
    holy crap that's nice
    Jul 2003
    Eastern USA
    Here : -
    cant see that picture nomatter what i do with it.
    EDIT: got it. for those that cant view it, go to this:
    http://www.bbpix.com/pix/264.jpg
    then delete the /pix/264.jpg part to bring you to:
    then hit back. that SHOULD let you view the picture.
  18. #18
    Mar 2004
    HELLAS
    She has the following chips....
    Originally posted by STEvil
    try 3-4-4-8
    When i change the 5 to 8 the mobo gave me a lot of stupid beeps....
    Originally posted by Bennah
    Worth a go though
    I have tape him on the psu to mobo main cable...
  19. #19
    Jun 2004
    i had a single 512meg dimm of samsung pc2700 that did 240 on my nf7-s 2.0 at 3.0vdimm. i thought it was odd at the time. I believe it would even 3d bench at 230mhz 11-3-3-2
    I5 2500k@4.7ghz--Asus P8Z68-VGen3--4x4gb Gskill Ripsaw 1600 --EVGA GTX570--Crucial m4 128gb SSD--Corsair TX950w--Corsair H100--Corsair 800D
    Scores are all 4+years old. updates soon.
    All scores are outdated
    24/7 3dmark06 6841
    24/7 3dmark05 13357
    24/7 3dmark03 22979
    Very Mild 3dmark01se 55225
    24/7 Aquamark 3 136020
  20. #20
    Mar 2004
    Miami, FL Usa
    here are mines Bt-5
    Mb : ASUSP4C800 DELUXE Intel i875 Fully moded
    P4 : 2.4M0ht @ 12*284 5:4 Dual Channel
    DDR : 256*2 pcr3200 2-3-3-6
    VGA : Ati Radeon9800xt 450/390
    Case : ThermalTake XaseR III
    P4 Cooling : SP-94 + 92*92 Vantec Tornado
  21. #21
    Mar 2004
    HELLAS
    "MkzK" your module is PC3200 DDR400Mhz.... The 260MHz - DR520MHz, are good.... Can you reach the 300MHz - DDR600MHz with that module?
  22. #22
    Mar 2004
    Miami, FL Usa
    i ll try their best.. until now thats what they can do i tryed 1 stick and it could make 270 fsb but reboot after a few seconds.. i ll try a better cooling they just have a heatspreader that i took off my old corsair ddr500 (they sucks hard)
