Page 1 of 12 123411 ... LastLast
Results 1 to 25 of 296
Thread: Util to edit the 6800 bios's?
    Jun 2004
    Anyone made or know of a Util to edit the 6800 bios's. I'd imagine it would be a pretty simple VB program now that the locations of the main values are known.
    Anyone?
    X2 3800@2.7ghz|8800 GTS |BallistiX 2Gb@270|DFI NF4
    Jun 2004
    Germany
    I will release such a tool soon.
    Jun 2004
    Ah thought you might
    You managed to find things like fan speed, mem timings etc?
    Jun 2004
    Woow that is very good news :-)
    Been looking for that as well!
    Jun 2004
    Germany
    I have no idea about fan speed, my card doesnt even have a fan anymore lol.
    I added editing memory timings but only for 5700/5900 class, i dont have a 6800 so i cant test if the values i look at are right.
    Well here it is, a easy to use BIOS editor for new gen nvidia cards!
    http://home.graffiti.net/omniextreme/oee10.zip
    Supports editing Speed and Voltage settings on 6800/U, 5900/U/XT, 5950U, 5700/U. Timings on 5900/U/XT, 5950U, 5700/U.
    Better use an fresh unmodded BIOS, a previous modded BIOS may not have correct voltage display.
    Maybe not all BIOS are read correctly so dont cry plz. But thats also written in the program. Tell me what doesnt work and your BIOS and i can look if i can fix it.
    Esp. would be nice if some 5700 owner could give feedback, it looks like some 5700Us can even have up to 1.5V
    I hope that will make ppl happy who dont like hexeditors and save some time
    Jun 2004
    Will it be okay if I host it on my site?
    http://www.mvktech.net
    Thanks,
    Mavke
    Jun 2002
    Austria, Europe
    Is it possible to edit 2D speeds in bios?
    AMD Phenom II 940 black edition, DFI LP DK790FXB-M2RSH @ 240 x 15.5 | 4GB OCZ Platinum CL4 | NexXxos X² Highflow | 2x Eheim 1048 | Enermax EG701 | 2x WD3200AAKS Raid 0 | HD4870 watercooled | Win7 64bit
    Jun 2004
    Germany
    Thanks,
    Mavke
    Sure you can. But lets wait untill tommorrow maybe someone finds a heavy bug and posts it.
    5700 and 5900 yes, 6800 i dont know are there cards which use a 2d speed?
    All i read from ppl is that the 6800 have the same speed in 2d and 3d.
    Jun 2002
    Austria, Europe
    uhm,...I mean the "throtteling speed". Where is the throtteling speed set? In the bios I assume.
    Would it be possible to stop the downthrotteling by setting this speed to the same as 3D speed?
    I tested your editor. I think it doesnt show the voltages of modded bioses accurately. It only shows 1.4V max. in bioses which set 3D voltage to multimeter-approved 1.5V.
    Jun 2004
    Germany
    Throttling speed is labled 2D/3D in my editor. And 6800s use their stock speed as throttling from what i heard.
    Yeah thats what i wrote above.
    Jun 2002
    Austria, Europe
    Ah. OK, but on my GT I am not able to change the 2D/3D clockrate setting. Only the 3D.
    Jun 2004
    Germany
    With the stock speed i mean the 3D setting. The value you enter there should be the one your card throttles back to.
    Feb 2004
    Ireland
    Thumbs up
    Great stuff xtremetheme, this will be a very popular tool.
    Thanks for sharing it .
    EDIT:
    There appears to be a bug in the program for 6800s, the 3D speed shown is actually the 2D speed.
    'Detonator' has reported it on OcUK and I've noticed it too.
    Posted by Detonator
    There is a bug in this tool,actualy if I do a 450/1250 bios, editing a 425/1200 bios and flashing the card ,after the bot the coolbit show 450/1200 2D so far is ok , but on D3 still 425/1200 seem like dont take any effect on D3.....Some one should tell xtremetheme about this bug.. I dont have any account on Exstrem forum and I cant contact him....
    My BIOS shows up as 400/550 in the editor, but that's my 2D speed, my core is actually at 425 3D default.
    P5W DH | E6600 | 2Gb Geil | 8800GTX | Audigy 2 | Enermax 500W | 2407 A04
    Aug 2002
    Utah
    I love it..! Thx
    Jun 2004
    Germany
    Ah thx for reporting. Can you send me your BIOS and tell me what card the other guy has?
    Jun 2004
    Okay I have done that :-)
    OmniExtremeEdit FX v1.0 - At mvktech.net
    Let me know when new version come out :-)
    And then I will add them as well. If you want to host em direct on my site let me know as it can be arranged as well.
    Feb 2004
    Ireland
    Here's my Club3D Ultra BIOS:
    http://www.handspun.utvinternet.com/daniel/CLUB3D.ROM
    (425/1.1 3D - 400/1.1 2D)
    I don't know what card 'detonator' has
    EDIT:\
    Noxis' modded (+0.1v) BIOS shows as 1.4v with the tool, but Noxis says he tested it with a multimeter and it is definitely 1.5v.?
  18. #18
    Jun 2004
    EDIT:\
    Yep definitly 1.5v (well 1.52v as it floats up) my card does 470mhz core with it, so unless its some kind of super GPU i got in there...
  19. #19
    Jun 2004
    EDIT:\
  20. #20
    Feb 2004
    Ireland
    Noxis, could you please make a 425/1.2 1.5v BIOS?
    3DMk03 froze in Nature at 450 core (@ 80c+), so I don't want to try the 450/1.2 1.5v BIOS until I've checked temps at 425 with 1.5v.
  21. #21
    Jun 2004
    xtremetheme I am sure is going to shake the bugs pretty quickly, best to wait for that
  22. #22
    Jul 2004
    Xtremetheme, the stock 6800GT bios's show up with 1.4v under the 3d settings, not 1.3 like stock.
    I uploaded the stock BFG6800GT rom in case you didn't have it.
    Attached Files Attached Files
  23. #23
    Jun 2004
    Germany
    EDIT:\
    Thx, but like i said previously modded BIOSes may not show correct voltage. Use a fresh BIOS.
  24. #24
    Jun 2004
    Germany
    That is correct because the BIOS says the card will have 1.4v in 3D.
    1.3V is for the throttling.
    Have you measured the values using a multimeter?
  25. #25
    Feb 2004
    Ireland
    Ok, but what about setting the 3D speeds?
