As you may know I've had this little CPU for quite a while now. First I got it up to 3063MHz (3DMark stable).. 3240MHz (sandra mem stable) using -25C coolant and Abit TH7-2 mobo. At that point the mobo was the limiting factor. After that w/ the P4T-E I was able to push it a bit farther but that mobo maxed out at 198.3FSB (3173MHz CPU). Once I killed the mobo I decided to try the P4T533-C model (which I'm using nowadays).
With the (turbopll modded) P4T533-C I've already got this CPU up to over 3.1GHz (it ran both SuperPi and PiFast at that speed) aircooled w/ Alpha PAL8942 + 68CFM delta (+12C ambient temp). Also ran some 3DMark at 3223MHz w/ vapophase cooler but the CPU speed was limited by R9700 as that card couldn't handle higher FSB/AGP speed.
Well yesterday I decided to put my Ti4200 (I've ran it at 200FSB w/ 2/4 AGP divider so it wont be the limiting factor) in and took the whole system out in the cold (it was +5C). Wanted to see how far I could push it using Pure aircooling methods
Was expectin like 3150MHz max and its needless to say that I was amazed when I saw it doing PiFast at 3201MHz aircooled!
PIC
Also ran SuperPi at 3193MHz... I think that it also ran it at 3201 but the result was the same.
PIC
Then some Sandra MEM goodness.. at 3297MHz aircooled
PIC
Was able to push it all the way up to 3345MHz (!) until it crashed (I had it at 3360MHZ but it crashed when I was saving the screenshot):
PIC
Today I installed the R404 vaporphase cooler on this thing and (once again) tried to find the limits of this little CPU. Well I was able to run some pifast runs at like 3350MHz or so and partial 3DMark benches at 207FSB but it wasn't very stable.. I got all kinds of random lockups and reboots. Also was unable to run PCMArk membench at anything higher than ~205FSB. Also at 211MHz FSB I got some artifacting already in Windows. I didn't get a single pifast calculation error so its quite obvious that the CPU isnt' the limiting factor here. So once again I need to find better mobo!damnit! hehhe.
Wonder if the IT7Max2 can handle these high FSB speeds![]()
ANyways.. this is what this P4T533-C could do:
Sandra MEM:
4413/4385 MB/s
WCPUID MAX:
3389MHz
Dinosaurs are chortling.
