Page 1 of 3 123 LastLast
Results 1 to 25 of 65
Thread: 6800GT core-clock locked ?
    Nov 2002
    Hamburg/germany
    Angry 6800GT core-clock locked ?
    hey guys, i have a big problem with my 6800GT, the core will only @ 365MHz memory @ 1150MHz
    i heard on the new GT's is the core-clock locked ?!
    new bios or is this core shitty ?
    Xtreme X.I.P.
    Nov 2002
    Shipai
    def try a new bios!
    what manufacturer?
    Nov 2002
    Hamburg/germany
    Point of View
    Xtreme 3DMark Addict
    Sep 2003
    thats a good clock, yours was speedbinned as not making ultra clocks
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    Xtreme X.I.P.
    Nov 2002
    Shipai
    well there are cards out there that run 470+ with the same cooling (evga 6800 ultra extreme edition) and i cant really imagine that some gpus clock to almost 500 and his doesnt even reach 400.
    it could of course be, but 365 sounds a bit weird to me. i think its oc protected somehow.
    stephan, can you get some additional card cooling and see if it has any efect on the max oc? if you can get 370 with better cooling (cold air from ice cubes or fresh air from outside) then its not a lock.
    do you have a waterblock you could use?
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    have you tried giving it a voltage boost yet?
    For those of you about to post:
    Xtreme Mentor
    Nov 2003
    New-Brunswick, Canada
    Yea, its deffinitly not normal. Did you checked if your HSF is attached properly?
    And what is it doing when you go over? Crash? Aritfacts? Wierd screen?
    Jun 2003
    sounds very much like an oc lock. Ive heard of GT's doing 410(not much, but way over 365) stock.
    Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
    Nov 2002
    Hamburg/germany
    i pulled the room-temparature from 26°c. down to 15°c.
    no effect
    Xtreme X.I.P.
    Nov 2002
    Shipai
    hummmmmm thats weird indeed.
    id say its a lock then... did lardarse reply yet?
    Aug 2002
    virginia beach
    maybe you just got a bad card? personally never heard of Point of view.
    msi k8n neo2 plat
    3200+ winchester (10x262)
    bfg 6800gt
    pdp pc3200 xbl
    thermalright xp-90 w/7v tornado 92mm
    Xtreme X.I.P.
    Nov 2002
    Shipai
    i did, they were the first to release 6800u cards and the first to sell them.
    May 2004
    This is gonna crap then..
    Xtreme Team D²OL
    Nov 2003
    Melbourne
    Maybe try the 6800 Ultra bios??
    Lardarse had someone mod the 6800 ultra bios a few weeks back.
    The modded bios is somewhere in these forums.
    Just search up Lardarse & you should be able to find the bios.
    Make sure you back up your bios first & then flash.
    Hopefully it's just a bios lock.
    Cheers,
    Minnyboy
    Cheers,
    Minh
    Mine:3770k @ 4.6Ghz @1.25v, Corsair H80, Asus SabreTooth Z77, 4 x 4GB Corsair Vengeance 1600C8, XFX 7870DD, Corsair HX850w, Sandisk 240GB Extreme SSD, Corsair Graphite 600T
    Kids: 2500k @ 4.6Ghz @1.368v, TRUE120, 2 x 4Gb Corsair Vengeance 1600C9, Gigabyte Z68X-UD4-B3, Gigabyte HD6870, Sandisk 240GB Extreme SSD, 850w Thermaltake 850w PSU, Antec P182 Case
    Kids2: i3 3225, 2 x 4Gb Kingston HyperX 1600C9, ASUS P8Z68-M PRO, Sapphire HD4870 1GB, 128GB Samsung 830 SSD
    Server: Core2Quad 9450, 2 x 2Gb Kingston HyperX 1066, 2 x 2Gb Corsair XMS1066, Gigabyte EP45-DS5, Corsair HX650w, OCZ 120GB Vertex 2E SSD, WD 1TB Black, 2TB Seagate 5900rpm, 2TB Seagate 7200rpm
    Jan 2004
    somewhere in Massachusetts
    noooooooooo...
    I was going to go 6800 GT over X800 in hopes of better OC scaling... but....
    Sep 2003
    if it was clocked lock, it would not overclock 1MHz, if you try to overclock and click apply, the clock sliders will just jump back to stock. I speak from experience with my fx5200 that I needed to use coolbits hack to oc. probably just got a not so great overclocker. if you must have more oc, just sell yours and buy another, I went thru 6 ti4200s
    Mar 2004
    Germany
    Where did you get the card form?
    Still waiting for my PoV 6800GT
  18. #18
    Xtreme X.I.P.
    Nov 2002
    Shipai
    there are also locked cards that let you oc ~10mhz and then start to artifact like crazy or crash.
    im also speaking out of expirience, had a 9600NP and a 9100, both from club3d, and with a new bios the cards oced fine.
  19. #19
    I am Xtreme
    Aug 2003
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  20. #20
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Originally posted by afireinside
    :P
  21. #21
    Sep 2003
    then he could try flashing the bios, if this doesnt help then id ebay the card for one thats not locked
  22. #22
    Xtreme Mentor
    Nov 2003
    Yeah, theres more then one kind of lock.... Its probably a BIOS hack that they made, so at the first MHz bump, its unstable since the BIOS dont support it. And probably he needed more then 1MHz before that the unstability was visible.
    And why did you got 6 TI4600's?????? that quite dum, instead of buying one top notch card.........
  23. #23
    Xtreme X.I.P.
    Nov 2002
    Shipai
    yeah maybe they set the max clocks a bit higher at 365 because of termal throttling? the gpu adjusts its core freq afaik, could be that it accidently sets it to a few mhz above the default clock for a part of a sec sometimes, and to provide full stbility they set the lock to 365mhz to prevent the card from gwtting unstable or crashing.
    6 ti4600 cards? who do you mean?
  24. #24
    Xtreme Mentor
    Nov 2003
  25. #25
    Xtreme X.I.P.
    Nov 2002
    Shipai
    just like he explained, he sold his g4ti and bought a new one hoping it ocs better, sold that one again and bought another. he didnt buy 6 cards at the same time
