Results 1 to 24 of 24
Thread: EPOX 8KDA3+ with A64 3400+ OC
    May 2004
    Taiwan
    MOBO: EPOX 8KDA3+ nForce3 250GB
    RAM: A-DATA DDR500 512MB*1 D5 1T
    VGA: MX-440 64MB 4X
    HD: WD-360GD*2 SATA RAID0
    PSU: ENERMAX 350W
    COOLER: HYPER6+3000RPM
    CPU: A64 3400+ CG stepping L2 1M
    vcore 1.7v my bh-5 can't run 220fsb 2-2-2-5 up so I used a-data 512mb ddr500 at 2.8v 5-3-4-2.5 Timing
    Nice chip! and nice overclock on air too.
    These cg clawhammers seem to clock nice and hold temps very well on air.
    Some bh-5 @ 5-2-2-2 cmd1 1:1 would add about 400mb/s to your bandwith at that cpu speed with 10 multi.
    Here is bh5 compare for you:
    You have a good overclock for 3400+ on air! Too bad you cant get your bh-5 to run....whats the problem? Need more vdimm?
    Are you trying bh-5 with one stick or two? 256 or 512?. I am very interested in that epox board and you got me wondering if it has issues w/bh-5.
    Oct 2003
    Scotland
    Very nice clocks, I have a 3400+ CG coming tommorrow so I hope I can get the sort of results you're getting, despite my MSI Neo Plat being a finicky bugger, lol. I'm looking forward to having an 11x multi to play with.
    Your bandwidth seems quite high too considering you're running Adata at relatively slack timings, I get about 3500/3500 running OCZ EB at 3-2-2-11 timings, 1T command rate.
    Another question, seeing as the 3400+ CG runs the memory controller at a native 2T, do you have an option in your BIOS to enable 1T, and if so does the CPU handle 1GB RAM running at 1T better than the CO steppings?
    And also, is that OC PRIME95 stable? And just to add another annoying question to the list, what's the max FSB you've been able to get with that 3400+ and the Adata, I presume it's the PC4000 Vitesta?
    Sorry for all the Q's, I always get excietd the day before a new CPU arrives, and we have a fairly similar rig.
    May 2004
    Taiwan
    I try 256mb on 8kda3+ one and two stick the same! maybe need vdimm mod !
    Jun 2004
    Stepping? Week? Where did you get that nice chip?
    May 2004
    Taiwan
    May 2004
    Taiwan
    cpu speed with 9 & 8 multi
    Xtreme X.I.P.
    Nov 2002
    Shipai
    very nice! especially the temps! what cooler is that? do you have a pic of it or a link to it?
    29°C case and 32°C cpu, thats really nice! even for idle
    and a small question
    what is this? ^^
    Xtreme X.I.P.
    Nov 2002
    Shipai
    oh, and WELCOME TO XTREMESYSTEMS
    Jan 2003
    Macomb Twp MI
    Yeah no .. My 3400+ CO on water with the same motherboard is reading around 48-50C in the bios idle.. DOnt make any sense!
    Running now, http://www.evga.com/forums/tm.aspx?m=693435
    Intel 3960 @ 5Ghz
    Asus Rampage IV Extreme
    QuadFire 7970
    X-Fi Sound Card
    16GB G.Skill 2133Mhz DDR3 Quad Channel Ram 9,11,10 @ 1.65v.
    3 Acer 23" 3D Ready LCDs
    2x Ultra X4 1600 WATT P/S 's
    MM Extension Ascention UFO Case W/ Top of the line Water cooling. Dream build!
    Feb 2004
    Paris
    on his 1st post there was "HYPER6"
    8Days/8Wr
    *OverClocking-Masters.com 3D Team
    Cooling Caskad'Chill : concept by mister, made by Skirms&Pgeo.
    1700+ Cpu-Z SS 3227Mhz/SD 3700 Cpu-Z SS 3704Mhz/E6600 Cpu-Z SS 5104Mhz
    E6600 Results : 10.09s Pi 1M / 714 CpuMark / 3DM2001 : 68061 7900GT air / 76280 7950 Gx2 stock cooling
    Aug 2003
    orange county
    that epox app is terrible. the temps and voltages are so off. if you check the voltages with a meter you will see what i mean. the voltage readouts in the bios are completely off also. most of the time they read higher in bios and when you log on to windows they drop.
    this board needs some sort of a droop type mod. when load is applied the vcore will jump anywhere from .05 to .1, making the board more stable under load than at idle. it has something to do witht the new nf3 250 chipset and cool and quiet.
    Feb 2004
    Qk do you have vcore droop, thats the one bad thing that I have heard about this board.
    May 2004
    Taiwan
    no i don't vcore droop
    you go and see...
    http://www.coolaler.com/ipb/index.php?showtopic=17635
    http://www.coolaler.com/ipb/index.php?showtopic=17379
    http://www.coolaler.com/ipb/index.php?showtopic=17205
    Feb 2004
    Cant see anything on those pages, perhaps you have to log in or something?
    Xtreme X.I.P.
    Nov 2002
    Shipai
    ©êºp¡Aµo¥Í¿ù»~¡I_Õ_Y±z¤£½Tª¾¦p ó¨Ï¥Î¬Y¶µ¥\¯:banana:¡A©ÎªÌ¤£ª¾¹D¬°¦ó±z·|±o¨ì¦¹¿ »~°T®§¡A½Ð¸ÕµÛ¬Ý¬Ý»¡©úÀÉ®× ¥H¨ú±o§ó¦hªº¸ê°T¡C
    ¶Ç¦^ªº¿ù»~¬°¡G
    ±z¨S¦³Åv__Æ[¬Ý¸Ó¥DÃD
    Jun 2002
    Glendale, CA
    yeah in another lang.
    | Intel i7 3770K | Custom H2O | Gigabyte z77x-ud5h | 16GB Samsung | GTX680 | 240g Mushkin Deluxe |
    -METALLICA-
  18. #18
    I am Xtreme
    Feb 2003
    Netherlands
    Damn, 2,65 Gig on air!
    My 3400+ CO core does 2.53Gig SuperPi stable on air.
    Are those CG cores really that much better?
    What about this 2T command?
    Is there any possibility to disable this? (Codered's A64 tweaker prog?)
    Btw, nice OC, both qk4722 and k|ingp|n.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
  19. #19
    May 2004
    Taiwan
    Originally posted by saaya
    oh sorry i forgot
    M/B ¡GEPoX 8KDA3+S754(NFORCE3 250)
    MEM ¡GG.SKILL TCCD 256mb
    VGA ¡GMX
    HDD ¡GMaxtor S ATA 6Y060M0 X2 Silicone 3112 RAID 0
    POWER: DELTA 350W + CWT 550W
    OS ¡GWIN XP PRO SP1
    CPU COOLER:water cooler
    CPU¡GS754 3700+
    VDIMM2.8V
    G-SKILL TCCD can run DDR650 8-4-4-3 Timing up at 2.8v
    by Taiwan coolaler
  20. #20
    Mar 2004
    Toronto, Ontario Canada
    Originally posted by qk4722
    oh sorry i forgot
    VGA ¡GMX
    OS ¡GWIN XP PRO SP1
    CPU¡GS754 3700+
    VDIMM2.8V
    by Taiwan coolaler
    no way, these are the same chips used in the CorsairPC3200XL sticks, and i've NEVER seen a review that had them even come close to this speed...
  21. #21
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    holy , thats with 2.8v???/???
    pump a little more volts into those puppies
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
  22. #22
    May 2004
    Taiwan
    ok!!!
    CorsairPC3200XL TCCD run DDR520 discontinue at 2.8v
    by ¨g¤Ö
    CPU 3.0EE(ES)
    M/B IC7-max3
    MEM A-DATA TCCD PC4800(ES) 512MB 2.8v
    by Taiwan johnnyliu3377
  23. #23
    Jun 2004
    TAIWAN/Taichung/Houli
    TCCD !
    QK Team2005
    未經QK Team同意禁止轉載.複製.修改文字.圖片等低能行為 。
    本サイトに掲載する一切の文書・図版・写真等を、手段や形態を問わず複製、転載することを禁じ ます。
    The copyrighted works contained in this information service shall not be copied, reproduced, varied, altered, modified, adapted, distributed, performed and displayed in any form without the written permission of the copyright owner.
  24. #24
    Jan 2003
    NYC
    wow, where can i buy this ram in the states? or can i?
    May 30th, 2007
    Quote Originally Posted by Haltech View Post
    Ive alrwady predicted that within 3 years, Sony will be purchased and liquidated.
    i7 920 D0 @ 2.8ghz // GTX 670 // Rampage II Extreme // 14GBs DDR3 // 550w PSU // corsair H100i // Corsair 800D
    i7 3770k stock // Maximus V Gene // 16GB @1600 // OCZ z850 //
    i7 3930k @ 4.5ghz // 780 SLI // P9X79-E WS // 16GB @ 1600 // AX1200i // and a horrible swiftech h220 // Carbide Air 540
