Results 1 to 16 of 16
Thread: X800-PRO to X800XT softmod beta
    Xtreme X.I.P.
    Nov 2002
    Shipai
    http://www.xtremesystems.org/modules...rder=0&thold=0
    according to 3center.org NGO has a beta of a softmod in their latest 1.5c catalyst drivers!
    http://www.3dcenter.org
    Im NGO-Treiber 1.5c für die ATi Radeon-Serie befindet sich laut den Programmierern die Beta-Version eines Radeon X800 Pro -> XT-PE Soft-Mods
    According to the writers of the ATi Radeon series NGO drivers ,the NGO driver version1.5c includes the Beta-version of a X800 Pro -> XT-Pe Soft-Mod
    so a softmod IS possible after all? ive heard of it before but it didnt work because of the rage theater chip?
    Dec 2003
    Louisiana
    Interesting. Let's hope it works for those guys who don't have laser cuts.
    Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
    Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
    HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
    Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
    And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
    Mar 2004
    Toronto, Ontario Canada
    What bout FX6800 softmods?
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    doesn't work for me.
    but then again, thats got to be the worst softmod I ever tried.
    it doesn't have a ATI2Mag file so they want you to download the catalyst 4.6 and take that one...
    then even then it just wants you to install the ATI cat and not this one, and when you do try to run it manually, well, it's still just the plain old X800 Pro...
    no softmod of anysort.
    Nov 2002
    Juneau Alaska
    ok, I tried again using the dos way and that did nothing...
    on top of that, it tells you to manually do the mod after this supposedly does it.
    this thing doesn't seem to do anything more then rename the driver, but then again, thats not really anything new.
    Xtreme X.I.P. Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    No such thing as an FX6800, just GeForce 6800...
    System
    ASUS Z170-Pro
    Skylake i7-6700K @ 4600 Mhz
    MSI GTX 1070 Armor OC
    32 GB G.Skill Ripjaws V
    Samsung 850 EVO (2)
    EVGA SuperNOVA 650 G2
    Corsair Hydro H90
    NZXT S340
    Xtreme X.I.P.
    Nov 2002
    Shipai
    im sure it does more than rename the driver LOL
    they never claimed this beta softmod would work! they just mentioned that they are working on it and that it looks promising.
    thx for testing the drivers and sharing the results!
    Nov 2002
    Juneau Alaska
    someone else with the more experience with NGO drivers should give this a shot, cause its entirely possible I am doing something wrong.
    theier readme file afterall is just the default ATI readme, so it's misleading.
    theres no real instructions that I can find on how to do this mod.
    Feb 2004
    Re: X800-PRO to X800XT softmod beta
    so a softmod IS possible after all? ive heard of it before but it didnt work because of the rage theater chip? [/B]
    I'll give it a shot, my pro actually has the rage theater chip So maybe I'll have a little more luck
    Intel i7 920 D0 @ 4.3 GHz
    EVGA X58
    6x 2GB OCZ DDR3 @ 1720mHz
    2x ATI 5870 X-Fire
    2x OCZ Vertex 120GB SSD - Raid 0
    1x 52" Samsung LCD 120Hz - 1920x1080
    1x 26" Samsung LCD - 1920x1200
    Heatware: 54-0-0
    Apr 2004
    Germany
    some ppl over at the 3dcenter.de forums tested the 1.5b drivers without any success. but somehow i doubt that a softmod is impossible, it's just like with the 9500np and 9800se ... in the beginning, there was a softmod. the rest is history
    IRC Operative
    Aug 2003
    Tampa, Florida
    this is a beta, which means its not finished, patience is a virtue (cough)
    CPU:
    Intel i5 750 @ 4200mhz 200x21 1.344v
    Cooling:
    Corsair H50
    Mobo:
    Gigabyte P55-US3L
    Memory:
    4GB Corsair XMS3 9-9-9-24
    GFX:
    ASUS HD5850 850/1200 1GB
    Feb 2004
    what is this softmod "supposed" to do exactly. Unlock the 4 extra pipelines? Or just make it show up as a x800xt pe, which a bios flash would do anyway (or does to mine anyway).
    EVGA X58
    2x ATI 5870 X-Fire
    Heatware: 54-0-0
    Apr 2004
    Germany
    of course it's supposed to unlock the 4 extra pipes, just as the mentioned 9500np and 9800se softmods did. for "just make it show up as a x800xt", you can just edit your driver's .ini
    Feb 2004
    yea thats what I figured. Just read that it wasn't supposed to be able to do that. Of course it was on another board that I saw that so I should have know better
    Almost done with the download, so we'll see what happens
    EDIT:
    Tried it out. When it goes to install the driver, it tells me its not compatible with my display driver For some reason I've had that problem with all of the ATI drivers
    EVGA X58
    2x ATI 5870 X-Fire
    Heatware: 54-0-0
    Xtreme X.I.P.
    Nov 2002
    Shipai
    what do you mean?
    Apr 2004
    Germany
    Originally posted by saaya
    what do you mean?
    ack, i mean "in the beginning, there was a hardmod" - my fault
    what i was going to say:
    when these cards were released, there were hardmods first and rumours about a possible softmod. both cards "got" their softmods later, so why not again with the x800 series?
