Results 1 to 2 of 2
Thread: Could this spell the end for VDIMM mods? OCZ DDR Booster Voltage Diagnostic Device
    Jan 2003
    Link
    _____________
    Description
    _____________
    With Powerclean Technology™ and Digital LED Readout
    OCZ DDR Booster Voltage Diagnostic Device with Patented PowerClean Technology™ allows users to supply cleaner power to their memory modules, resulting in more stable memory. Additionally, users are able to view memory module voltage with the digital LEDs on the DDR Booster, allowing simple and inexpensive troubleshooting of the memory modules. Each OCZ DDR Booster allows VDIMM adjustments up to 3.9V and is compatible with most DDR1 motherboards.
    Specifications
    _______________
    Patented PowerClean Technology™ allows for better power filtering
    Fully adjustable VDIMM control up to 3.9V
    Digital LED VDIMM readout updates three times per second
    Compatible with most DDRI motherboards
    Easy to install, easy to use
    Powered by computer power supply
    Fits in 184 Pin DIMM slot
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    This is being discussed in another section of the forums - Xtreme Overclocking. Go here if you wanna talk about it.
