Page 1 of 4 1234 LastLast
Results 1 to 25 of 79
Thread: AN7 vdd-mod?
    Mar 2004
    AN7 vdd-mod?
    The dfi vdd mod didn`t work for the an7.
    Xtreme Mentor
    May 2003
    Engineering Lab - NCSU
    Well, I have not worked on an AN7....but I will see what I can dig up on it.
    Please post a pic of the area around the AGP slot.
    I like my women the way I like my processors...naked.
    I am not the HellFire that writes bios files. I work strictly on voltage modifications.
    Xtreme Cruncher
    Aug 2002
    Michigan
    I'll get some pics for you in a min.
    Xtreme Mentor
    May 2003
    Nice..thanks.
    Xtreme Cruncher
    Aug 2002
    Michigan
    Check out the pics in this thread. http://www.xtremesystems.org/forums/...*&pagenumber=6
    I gotta upload these pics I took cause they are friggin huge but kinda crappy(light source sucked). I'll throw up the links to them shortly.
    Xtreme Mentor
    May 2003
    It will take time to look thru that thread and figure out what is going on.
    It is either pin #2 or #6...but not sure which at this point. It all depends on which pin is the error amp for the Vdd circuit.
    I will also need someone to take some resistance and voltage readings once I get a nice high res pic of the area around the AGP port and that LM358 chip.
    I am heading to bed for now and will check this thread first thing tomorrow morning to see if pics are available and to read that thread over.
    Xtreme Cruncher
    Aug 2002
    Michigan
    Man these pics are crap! Here are a couple of around the AGP slot. 2048x1536 res
    http://linxworld.org/nickpics/AN7.JPG
    http://linxworld.org/nickpics/an72.JPG
    I will get better ones sometime today for sure.
    Mar 2004
    Mar 2004
    *PUSH*
    Nov 2002
    Earth: The Insane Asylum of the Universe
    Now is this for the Northbridge? I know I'm a total n00by when it comes to voltmods. I was able to copy the one for the 8RDA+, awhile back, but had to look at the pics a few times. I'll definitely be watchin'.
    Xtreme Mentor
    May 2003
    Whats on that 8 legged IC (4 legs per side) between the FETs and the capacitors that are under the AGP slot?
    Also, could you post a more broad picture so as to include the NB in it?
    Nov 2003
    cairns > australia (ex-germany)
    linky to a preview page with a bunch of pics i took this afternoon. the ic you're looking for is displayed in this picture. i didn't insert it here for its 2048x1536 and would blow some people's bandwidth. all pics available as thumbs are 800x600 - if you need any one of those in a higher resolution, pm me and i'll put 'em up. only 2 pics at the bottom of the page (text links have full rez - i can go higher if need be)
    anyway, what i make of the ic you're looking for is this:
    1st line: LM358
    2nd line: 34M (got some logo on there aswell)
    3rd line: D3EX
    cheers
    sky / s!p - we are oldskool, dammit.
    May 2004
    Germany
    What's the difference between VDD and VTT anyway??
    I think i'm searching for a VDD-Mod for Abit AN7.
    Xtreme Cruncher
    Aug 2002
    Michigan
    Sorry I've been gone so long, sick like a mofo. Anyhow I'll take some pics right now.
    Xtreme Cruncher
    Aug 2002
    Michigan
    Urgh... I just remembered I let me sister borrow my cam and she wont be back for 7 days.
    Xtreme Mentor
    May 2003
    Vdd is chipset/nb voltage, and Vtt is to be 1/2 of Vdimm.
    Someone please take a voltage reading on pin #1 and #7 and let us know which is the Vdd reading? Obviously compare that to the setting in bios and reading in bios to make sure you arent reading AGP voltage.
    May 2004
    Germany
    Thx for answering my question. I have a nice Multimeter and can read voltages, but i'm not sure where to read. Where can i find pin #1 and pin #7? Can i hurt my mainboard by doing that?
  18. #18
    Fused
    Dec 2003
    Malaysia
    Have u guys figure it out yet... ?
    If havent... measure all the voltages spot that i shown in this pic.. i need all voltages...
  19. #19
    May 2004
    Germany
    Here are all voltages you wanted. The box shows the voltages of the LM358 in the middle of the picture.
    http://dekal.kalytta.com/images/abit.../an7%20(1).jpg
  20. #20
    Xtreme Mentor
    May 2003
    The readings on pins #2 and #3 make me think this is either the AGP or Vdd voltage.
    Jump in bios and change the settings for Vdd to see if the voltages change on those pins and on the FET leg where you got the same reading.
    Let me know what you find out.
    I would wager a guess that this is Vdd and not Vagp as the Vagp is usually around 1.5-1.6v stock.
    Set the Vagp to 1.5v if possible and Vdd to something like 1.7-1.8v to see where you can match those readings on the LM358 and the FET leg.
  21. #21
    Fused
    Dec 2003
    Malaysia
    Cheers
  22. #22
    May 2004
    Germany
    First, i have measured all voltages with 1.60 VDD. Then i have tried the pencil trick, but it don't work for me at all. Maybe i need other pencil? I used one with HB 100. But anyway, it must suceed, because i have penciled it maybe 5 times again without sucess. Always i have measured the same voltages.
  23. #23
    May 2004
    Germany
    And here is the new picture.
    <img src="http://dekal.kalytta.com/images/abit%20an7/an7%20(2).jpg">
  24. #24
    Fused
    Dec 2003
    Malaysia
    should be the same as DFI vdd mod..
    both board use LM358
  25. #25
    May 2004
    Germany
    It seemed it can't be used for AN7, tictac.
    How can i increase voltage of the right fet in the picture without damaging mainboard?
