Spent some time playing with my 3700EB modules in the last few days....
well my sticks aint the best clockers arround
max i can get them is 242mhz @ 2.5 2 2 5 (8) pat enabled, turbo, infinity, 64ìsec
At first they only liked mos of the settings to auto except 2.5 2 2 5 (4)
did some burning in etc and now i can see they can cope with all the other settings enabled
the prob is that the sticks wont respond to voltage at all
i am pushin 3.05V which is the lowest my board can do (Vdimm modded)
i am testing with memtest 95 and prime
from 3.05 to 3.35V I DONT GAIN even a SINGLE MHZ
thats with 2.5 2 2 5 always
i have taken their heatspreaders off and used 2 delta fans 40mm and coolermaster ramsinks to cool them
i tried last night dimm slot 3 and 4 which were worse giving me 4 errors in memtest at the fsb of 242
seen a mates sticks do 252 prime stable and memtest stable at the same timings and voltage.
if i try cas 3 and keep the other settings the same i DONT gain any extra mhz either...
even if you do try 3 2 2 8 still nothing
i slackened the timings to 3 3 3 8 and they did go higher(didnt find max)
any idea why they dont scale up with voltage + why do they not gain any extra mhz with cas 3 from 2.5?
My board is the asus P4C800E Volt modded
NB cooled with TT tiger 1 cooler
VAGP 1.75V iirc
cpu my 2.8M0 or the 3.2C i got a few days ago(been testing with both)
