What do I use to check the # of pipes being used.
I did the mod and need to see if it's working
OPP
OPP
Cool. How do you do that mod?
You can use RivaTuner or ATiTool.
i think ati tool for overclock and you need to flash the card...
i wish i get 400$
Israeli Defence Force
Pentium 3 800@900 / TT Volcano 7
Gigabyte 6VTXE-A
384MB Ram PC100 (Hynix,Micron)
Radeon 9700 Pro 392@360
You could just run the 3DMark2001 Fillrate tests before/after as well. You will know if its working
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
There has to be somthing that shows it.
Other then the fonominal scores I'll be getting
OPP
and you can check if where are 16pip or still 12pip with aida32...
Gigabyte 6VTXE-A
ATI tool should definetely show it... at least those screens prove it...
Please give me a link to ati tool...Originally posted by bachus_anonym
thanks
Gigabyte 6VTXE-A
You'll find it here.Originally posted by TommyW
thanks
Damn, It didn't work
I guess I'll try close the bridge again.
OPP
Isn't there 2 bridges. If so, I wonder if it makes a difference which one or if you have to close both.
Bummer..... I figured you'd get it :P
double check the connection, OPP.... make it work, damn it
There are 2 bridges, only one is cut. I tryed closeing the one, maybe I didn't get contact.Originally posted by pkrew
OPP
Its either that or the guy was jerking our chain. Could also be that it depends on who makes the card. I'm not sure why that would make a difference though.
come on opp, give us something to dream of!
CPU:Intel i5 750 @ 4200mhz 200x21 1.344v
Cooling: Corsair H50
Mobo:Gigabyte P55-US3L
Memory:4GB Corsair XMS3 9-9-9-24
GFX:ASUS HD5850 850/1200 1GB
itd be soooo sweet if you could get that to work
Give us non-ub3r rich folk some hope that the X800 Pro will kick (more) arse!!
Any news on the 6800 GT's BTW???
The new gt version is faster then the uktra? or its in the between 6800 and the ultra?
Gigabyte 6VTXE-A
Its in between 6800 and Ultra
Ultra 400 Core 550 (1100) Mem
GT 350 Core 500 (1000) Mem
both have 16 pipes and gddr3
Two successes:
Phemo - http://www.phemo.pwp.blueyonder.co.uk/xt3.jpg
3DMark2001SE Before - http://service.futuremark.com/compare?2k1=7844376
3DMark2001SE After - http://service.futuremark.com/compare?2k1=7864146
3DM03 Before = 10934
3DM03 After = http://service.futuremark.com/compare?2k3=2577914 12075
Chris_UK - http://www.andovernaturalproducts.co.uk/working.JPG
3DM03 Before = 11800
3DM03 After = http://www.andovernaturalproducts.co.uk/working1.JPG 13487 ( 630/585 )
bad luck opp, try again
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
Here is what Phemo tried:
" know the first thing you'll ask is how I did it. Well, I got a very sharp knife and scraped off my previous conductive paintwork, then I used the knife to scrape away at the two points - we are using the right points after all. I scraped them away until there was some bare copper exposed, bright copper instead of the usual dull, then re-did the paint job, booted Windows up and ran ATITool, she now apparently has 16 pipes"
yeah it works, let the fun begin
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
