Page 1 of 11 1234 ... LastLast
Results 1 to 25 of 263
Thread: EPoX 8KDA3+ Vmods (Dimm + Vcore)
    May 2003
    Holland
    Smile EPoX 8KDA3+ Vmods (Dimm + Vcore)
    I just got this motherboard ant off course i want to mod the hell out of this thing
    I got some high resolution pix of some chips of wich i think have somthing to do with the Vdimm and Vcore
    Ill post them later tonight .
    I Hope you guys can help me
    Cpu: Core i7 930 @ 4.5 Ghz 1.4V (24/7)
    Mainboard: Classified E760 @ B3 X58 + EK Waterblock
    Memory: 6GB Kingston Hyper @ 2150Mhz 8-8-8-28 -> 1.72V
    Graphics Card: HD5870 + EK-Waterblock
    Soundcard: Auzentech X-Fi Forte
    Boot HDD: WD Velociraptor 300 GB
    Stuff HDD: 4x 1TB Samsung HD103UJ @ Raid5 (Perc 5i + 512MB)
    PSU: Corsair 1000Watt Modulair
    Water Cooling Setup: WC Setup --> Swiftech Apogee XT / Black Ice 360 GTX / 3x Triebwerk TK-122 / 2x DDC 355 Plus + XSPC Dual Top / EK-Spin Bay Reservoir
    All build in a Corsair Obsidian 800D
    May 2004
    Perth, Western Australia
    have you looked at motherboardFAQs?
    your sig says it is fully modded ?
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
    May 2003
    Holland
    Your right
    Forgot to correct that
    May 2003
    Holland
    Ok i figured out the Vcore mod !
    Put 50 k VR to pin 10 of the ISL6569CB on the top of the board.
    Jul 2003
    The Netherlands
    Figured out the Vdimm mod tonight together with smokey. Use a 20K vr on pin 6 of the TR9202 chip located in the right upper corner.
    May 2003
    Holland
    Its RT9202 :P
    And YoupY
    Jul 2003
    The Netherlands
    Will you post some pics here Smokey.
    Resized please....
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    do u mean 8RDA3+ cuz the 8KDA3+ isnt out yet, only reviewers have em
    how the hell did u get one?
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Xtreme Mentor
    Nov 2002
    Delaware USA
    They arent here in the USA yet. Epox comes out in europe always early for purchase.
    Looks like "the" board to get!!!
    Dont even ask where i've been!!!
    Xtreme Mentor
    Nov 2002
    Delaware USA
    Re: EPoX 8KDA3+ Vmods (Dimm + Vcore)
    what's the stock voltages on this board max out @. Epox was always generous on their voltages in the past.
    Xtreme Mentor
    Jan 2004
    yah this board looks awesome
    Jul 2003
    The Netherlands
    Hmm, I doubt it.
    The board hasn't a decent multi control as far as I know. Most of the multi's won't work AFAIK. And biosses aren't very stable atm.
    Also there isn't any room for attaching watercooling to the chipset, which get's pretty hot.
    One positive thing about the board is that it get's it's mem voltage from the 5V.
    I'm waiting for the MSI nf3-250.
    Yes I know what MSI usualy stands for. Not to good, It has a working multi control (only integer numbers), and it has holes for attaching wc. Also the bios has HTT upto 300 wich may be updated to 350 or higher.
    And standard mosfet cooling is on the board (dunno if it's because they get really hot, or just in case there is some serious tweaking to the board is expectd).
    Also standard voltages are higher then on the epox board....
    Let's wait what the future brings. I'm expecting this board next week. Will post some Vmods when I find them, unless somebody beats me to it
    Xtreme Mentor
    Jan 2004
    Hmm, I doubt it.
    clockgen, clockgen, and clo.... wait good point about the holes by the nb
    May 2003
    Holland
    Well as is promissed the pix of the mods
    I got this mobo from a shop here in the Netherlands wich had them for a day or 2 (only 20 available).
    Vcore mod !!! :
    Information about the Vcore mod for the EPoX 8KDA3+ :
    Voltage Regulator Chip : ISL6569CB
    Pin to mod : Pin 10
    Pot Type: 50 k (i was out of 50 so thats why i used a 100 k )
    Here are the nice High Resolution Pix !!
    http://www.voidyourwarranty.nl/image....vcoremod1.jpg
    http://www.voidyourwarranty.nl/image....vcoremod2.jpg
    VDimm mod !!! :
    Voltage Regulator Chip : RT9202
    Pin to mod : Pin 6
    Pot Type : 10 k
    And also for the Vdimm mod some nice High Resolution Pix :
    http://www.voidyourwarranty.nl/image....vdimmmod1.jpg
    http://www.voidyourwarranty.nl/image....vdimmmod2.jpg
    http://www.voidyourwarranty.nl/image....vdimmmod3.jpg
    http://www.voidyourwarranty.nl/image....vdimmmod4.jpg
    @ YoupY
    Im a beta tester for EPoX with biosses and the newer betas are realy good !!!
    HTT @ 350
    Full Working MP Control (already worked perfect with 1st release bios)
    The only thing is the max working HTT thats something they are working on.
    I cant run over 300 HTT not even @ 8X MP.
    But thats only a temporarily thing because the support of EPoX Rox
    Im very pleased about this board because it runs frikkin fast and extremly stable
    And this motherboard can work extremely well with BH-5 Sticks (512 MB) and it can run @ 2-2-2-5 1T timings @ 240 + FSB.
    That is something i havent seen any other A64 board do !!!
    Im very and i mean very satisfied with this board !!!
    Jan 2003
    Dayton Ohio
    Thanks smokey!! I think ill be getting this board whenever it comes to the US
    I need to find a freakin 50k vr though
    May 2003
    Holland
    Your welcome m8 let us know the results
    Aug 2003
    Marseille
    hello
    is your 3200+ a CG or C0 core ?
    does in the epox bios the possiblity to choose betwenn 1T and 2T ?
    thanks
    i2600K / P67A-UD5 rev 1.00
  18. #18
    Jan 2003
    Dayton Ohio
    Im pretty sure you can run 1T
  19. #19
    May 2003
    Holland
    Yep i always run 1T works like a charm
  20. #20
    Aug 2003
    Marseille
    can you run synch (1:1) with your 2x512 on epox ? more than 240
    your answer can permit me to buy this MB
  21. #21
    May 2003
    Holland
    Yep
  22. #22
    Jan 2003
    Dayton Ohio
    why does it say the mem size is 256 in that pic? Bug or not your 2x512?
  23. #23
    Jun 2004
    Sydney, Australia
    Hi, what is the highest stable FSB, given that the MP is low enough to keep the CPU stable
    Cheers
  24. #24
    May 2004
    how are the standard cores and how far u could go with no modding ?? i gonna buy a new a64 system in about 2 weeks i dont really know which board i will purchase yet
    Newcastle 3200+ destroyed
    DFI Lanparty UT destroyed
    Geforce 6800 GT
    Adata Vitesta 4000
  25. #25
    May 2003
    Holland
    That run is done with my extra memory wich i have
    2x 256 MB PC 3200 Kingston Valuream BH-5
    The new biosses wich are going to be released shortly have Vcore up to 1.85
    Till there is a new bios that fixes the 295 HTT + bug i cant take full advantage of this board.
    The board can run max HTT but when it loads windows its running the good mp but the default FSB/HTT .......
