Page 1 of 9 1234 ... LastLast
Results 1 to 25 of 201
Thread: I did X800Pro Pipes mod..but one problem.
    Banned
    May 2004
    Korea
    X800Pro pipes mod, but
    3DMark GT4 mother nature become not better...
    I am finding this problem, I don't Know a reason yet
    =blueremy=
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    ummm, 70.3 ----> 85.1 is an improvement
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Feb 2004
    BG
    May 2004
    대한민국 강원도 원주시 Wonju, South Korea
    I believe I am not alone in saying... WTF.
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    2x8GB Avexir Raiden DDR4-3000 15-15-15-35
    Gigabyte Aorus 1080 Ti @ 2076/1500(6000)
    512GB Samsung PM961 + 840 Pro 256GB + some TBs
    Corsair AX1200i
    X-Star DP2710LED @ 110Hz + 40" Samsung TV
    CPU and GPU under water: 9x120 rad + 3x120 + 3x120
    ...and an HTC Vive!
    Apr 2004
    Germany
    can you give me a link to the pipe mod you have done or can you make a photo, please? i carnt find a understanding guide.
    Intel Pentium D805 Dual Core @ 3.5Ghz 1.5Vcore Aircooled
    ASUS P5WDH Deluxe
    2x1024 MB DDR667 CL4 MDT
    XFX 7900 GT Vivo M520 @ 590/1600
    2x WD360ADFD Raptor
    1x 160GB Samsung
    c[_]
    Nov 2002
    Alberta, Canada
    Yes, link to mod plz.
    All along the watchtower the watchmen watch the eternal return.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Welcome to XtremeSystems
    Everyone has been looking for that mod, link please.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Banned
    May 2004
    Korea
    I'm sorry,.....mod guide link not exist.
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    wasn't that already tried and discovered not to work? Did you just connect those points? Did you do something special, or did other people do something wrong?
    If theres a definitive way to get it working I'm gonna head to newegg.
    For those of you about to post:
    Apr 2004
    Germany
    @blueremy:
    Why you have 10602 Points at 3DMark03 with 16 Pipes and detected as X800XT Platinum ?? Right, it must be 12 Pipes at X800 Pro and why you have at ATI-Tool default 526/573Mhz Clock shown???
    Do you flashed the Bios to X800XT and is run the 2.0ns Ram then problemless at 573Mhz or you change the Ramclock in Bios before flashing? I wanne edit the X800XT Bios clocks but radedit 1.102b dont like this Bios and i found no other Bioseditor?
    Because in all X800Pro reviews the Rams runs maximum 530MHz, so 573Mhz is not possible to boot, i think. Alot of strange thinks
    From what manufacturer is your Card and bulk or retail? (ATI, Sapphire, Powercolor...?)
    ASUS P5WDH Deluxe
    2x WD360ADFD Raptor
    1x 160GB Samsung
    Banned
    May 2004
    Korea
    First shot and second shot is X800Pro @ XT 16Pipes mod 475/450 shot.
    3rd shot is 16pipe mod overclock 603/598 shot.
    X800Pro default 9200 points.
    c[_]
    Nov 2002
    Alberta, Canada
    what are the rest of your system specs?
    Sep 2003
    i take it u need to flash the card with an xt bios shut down then mod the card then boot it back up?
    Apr 2004
    Germany
    blueremy: And do you flash it and make an vmod?
    I dont think that the 2.0ns Rams run @ 573Mhz without an vmod.
    And whar manufacturerer is your card , sapphire, powercolor, ati???
    ASUS P5WDH Deluxe
    2x WD360ADFD Raptor
    1x 160GB Samsung
    Sep 2003
    mine is ok for 600mem out the box with a 80 mm blowin on it, core max's around 576 (stock all)
    Banned
    May 2004
    Korea
    My X800Pro card is no vmod 567/580 stock all,
    no 16pipes mod 617/603( X800 silencer cooled, pencil vmod),
    16Pipes mod 603/598( X800 silencer cooled, pencil vmod)
    Apr 2004
    Germany
    And what manufacturer is your card , sapphire, powercolor, ati???
    ASUS P5WDH Deluxe
    2x WD360ADFD Raptor
    1x 160GB Samsung
  18. #18
    Banned
    May 2004
    Korea
    Sapphire.
  19. #19
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    so what exactly did you do to unlock the other pipelines?
  20. #20
    Apr 2004
    Germany
    he have post the picture. you must connect the 2 golden points (red line)
    ASUS P5WDH Deluxe
    2x WD360ADFD Raptor
    1x 160GB Samsung
  21. #21
    Mar 2004
    I just tried this and I cant get it working. My card is still recognized as a pro even after I flash the bios with the one from ocfaq.com. Anyone fancy uploading a bios taken direct from an x800xt card for me
  22. #22
    Apr 2004
    Germany
    do you delete/reinstall the driver after all?
    but if the pipes are damaged so you must have some artefacts....with what material you connect the golden points?
    ASUS P5WDH Deluxe
    2x WD360ADFD Raptor
    1x 160GB Samsung
  23. #23
    Dec 2002
    sandusky ohio
    Please tell me someone is trying this right now. I want to give it ahot when i get home from work. what do you use to connect the bridge? wouls a small copper wire taped down work?
    E8400@ 4.0
    SUNBEAM|CR-CCTF
    ASUS P5Q PRO
    4GB G-Skill
    MSI HD 4850
    Vista 64bit
  24. #24
    Mar 2004
    The sapphire bios wont flash with flashrom 2.37. It comes up successfull but the device ID stays as 4a49 and doesnt go to 4a50. blueremy what did you use to flash your bios?
  25. #25
    Mar 2004
    I used the old defogger silver conductive paint, seems to have gone between the 2 points ok. Is that good enough to bridge the gap like it was with the old athlons?
