Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: Radeon X800 Pro Pencil Voltage Mod
    Jan 2004
    Just like the pencil mod for the 9800XT
    "Locate the resistor as shown above and start to pencil it slowly, a few strokes should be sufficient to increase the VGPU from 1.31v to 1.4v. I have tried higher voltages but i have found that any voltage higher than 1.45V seems to be a little too much and the card will start artifacting during benching. Therefore i have left the VGPU at 1.4v which is pretty sufficient for air cooling."
    Dec 2002
    sandusky ohio
    Anyone try this yet...... I am thinking about it but want to see a few results from some people on this forums before i try.
    E8400@ 4.0
    SUNBEAM|CR-CCTF
    ASUS P5Q PRO
    4GB G-Skill
    MSI HD 4850
    Vista 64bit
    Dec 2002
    sandusky ohio
    ok i tried it.... default vgpu 1.4 max overclock 510
    vgpu 1.88 max overclock 618
    37c idle 48c full load.
    pretty happy with 618/585
    E8400@ 4.0
    SUNBEAM|CR-CCTF
    ASUS P5Q PRO
    4GB G-Skill
    MSI HD 4850
    Vista 64bit
    Mar 2004
    I had a quick question. What are you supposed to pencil? the white line around it, in the fashion pointed out by the green line? or am I wrong here.
    Dec 2002
    sandusky ohio
    basically along the side of the resistor on the pcb.... you want the graphite to make a connection between the ends.
    E8400@ 4.0
    SUNBEAM|CR-CCTF
    ASUS P5Q PRO
    4GB G-Skill
    MSI HD 4850
    Vista 64bit
    Sep 2002
    Dallas Tx
    Humm...that VRzone article says the default core voltage is 1.31. I just measured mine with a Fluke 88 and it's 1.4v default ??
    Are theise cards comeing with different core voltages ?
    Dec 2002
    sandusky ohio
    yes. mine was 1.4 by default also
    E8400@ 4.0
    SUNBEAM|CR-CCTF
    ASUS P5Q PRO
    4GB G-Skill
    MSI HD 4850
    Vista 64bit
    Mar 2004
    where is the check point?
    Edited: That's alright, I found it.
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    Wow, nice OC with the mod I got to try it on mine, are you using a waterblock to get those temps? My max OC was 560 stock.
    Feb 2004
    Wow, very nice o/c
    I think I'm going to have to give this vmod a shot myself
    Btw, my vgpu was 1.41 stock also, so I think that article just had a typo
    Intel i7 920 D0 @ 4.3 GHz
    EVGA X58
    6x 2GB OCZ DDR3 @ 1720mHz
    2x ATI 5870 X-Fire
    2x OCZ Vertex 120GB SSD - Raid 0
    1x 52" Samsung LCD 120Hz - 1920x1080
    1x 26" Samsung LCD - 1920x1200
    Heatware: 54-0-0
    Feb 2004
    well I got the core up to 625 with 1.71vgpu..about 37c load.
    Might go a littler higher on the gpu later...reall need to vmod the memory though. I'm maxing out at 573
    For you guys that have done this mod and use ATI Tool...have you noticed a Vgpu drop when your using ati tool...particularly when its doing its "heat-up". My Vgpu drops almost .1 and I'm wondering if my PSU is crapping out, or if thats normal
    EVGA X58
    2x ATI 5870 X-Fire
    Heatware: 54-0-0
    IRC Operative
    Aug 2003
    Tampa, Florida
    mighty expensive gfx card to be slapping voltage too :o
    CPU:
    Intel i5 750 @ 4200mhz 200x21 1.344v
    Cooling:
    Corsair H50
    Mobo:
    Gigabyte P55-US3L
    Memory:
    4GB Corsair XMS3 9-9-9-24
    GFX:
    ASUS HD5850 850/1200 1GB
    Nov 2002
    meh... if the cooling has been improved its par for the course
    I wouldn't overvolt a stock cooled card at all.
    Nov 2003
    VIENNA
    are you guys giving it up to 1.71 in air? cause the article says you shouldnt put more than 1.4v on air..
    Overclocking made in Austria
    Evil Kitty
    Jun 2002
    Detroit, MI
    I'm putting 1.7v to it under water/80w pelt cooling. I wouldn't dream of that voltage on air cooling. Not to a $400 card anyway
    9900k @ 5.1Ghz
    Asus Maximus Hero XI
    32GB (8 x 4) Gskill @4000
    Strix 2080 Ti OC
    OS & Apps: Samsung 970 Pro 512GB
    Games: Samsung 970 Pro 1TB
    Storage: Crucial M500 2TB
    Seasonic Platinum 1000W
    Phanteks Evolv X
    Feb 2004
    That article also says that 1.3 is the stock voltage... and its not. He also said that hes getting artifacts at that voltage which is why he stopped.
    I'm on water and my load temp hasn't gone over 35c, and no artifacts. I know quite a few people that have been running 1.7+V since the cards came out, so I'm not to worried. Besides, weres the fun in leaving it stock?
    EVGA X58
    2x ATI 5870 X-Fire
    Heatware: 54-0-0
    Jun 2004
    hrmm my x800pro vivo modded to 16 pipes only has 1.32v. but this core also doesnt want to do more than around 510 after the mod and did 517 before.
    I5 2500k@4.7ghz--Asus P8Z68-VGen3--4x4gb Gskill Ripsaw 1600 --EVGA GTX570--Crucial m4 128gb SSD--Corsair TX950w--Corsair H100--Corsair 800D
    Scores are all 4+years old. updates soon.
    All scores are outdated
    24/7 3dmark06 6841
    24/7 3dmark05 13357
    24/7 3dmark03 22979
    Very Mild 3dmark01se 55225
    24/7 Aquamark 3 136020
  18. #18
    Jul 2004
    I have seen some people on forums point out a certain resistory for the vmem mod to pencil in, but none have worked. I tried the exact resistor and it didn't change the voltage for the mem from 2.0v. Does anyone know which resistor to shade in for a vmem mod? Thanks.
  19. #19
    Banned
    Mar 2004
    Huntington Beach, Ca
    If you read the guide, it clearly tells which resistor to outline...
  20. #20
    Jul 2004
    that resistor doesn't work. if you would have read my post you clearly would have seen that. I was wondering if anyone knows the correct resistor to raise the voltage b/c that one does not work on my powercolor x800 pro vivo.
  21. #21
    Aug 2004
    TasMania
    Have a look over here http://www.techpowerup.com/articles
  22. #22
    Sep 2003
    London
    I don't believe there is a working pencil vmem mod
  23. #23
    Nov 2002
    Earth: The Insane Asylum of the Universe
    Quote Originally Posted by GregUMR
    If you're sure you're looking at the right resistor, R1597, just draw on top of the resistor itself. I couldn't get mine done drawing on the PCB either. Same card Powercolor VIVO. Using an Alpha PAL HS, and slower Delta 80mm fan, I have mine @ 1.52v, for 560/580 very stable. Stays under 50C, so I might end up trying for more sometime.
    "I got a fever, and the only prescription, is MORE COWBELL" **I can't afford a sig, all my money's in hardware.**
  24. #24
    Nov 2002
    Hey guys, what kinda voltage are ya using to get 600/600 ish clocks? I'm using 1.6v now, and still maxing out @ 580/590 stable. Not stock cooling, I'm using an Alpha cut down to fit, and more air than most folks would consider sane. Temps are never higher than 52/35.
  25. #25
    Mar 2004
    Whats igpu ?? vr-zone says 500k or 50k poti and Techpowersay 250k poti ???
