Results 1 to 18 of 18
Thread: OCZ pcXX EB vs EL?
    Aug 2003
    Denmark - Aarhus
    OCZ pcXX EB vs EL?
    Heya.
    I´ve been reading up on these "EB" threads the past few days and I must admit I´m very tempeted by them.
    At the moment I have Mushkin special 2-2-2 that can bench at 240fsb 1:1 with 2.8v!! Pretty amazing!
    My problem is that I need one gig of ram.
    My question is what´s the diff between "ordinarey" EL optimized kit from OCZ and the new EB stuff?
    I can see that the price diff. is almost 90$!
    So please enlighten me
    DFI NF4 SLI-DR (bios 510-3 FIX) - 3000+ 0516 CPGW - 1GB G.Skill LE 440 - 4x36GB Raptors Raid 0 - NQ 500w - Zalman 7700AlCu -Dell 2001FP
    Known as Ø on tweak.dk and ø27 on overclocking.dk
    3DM 05
    3DM 03
    3DM 01
    Mar 2003
    Denmark
    would go for the EB stuff.. seems to pack out some punches.. although I dont know how the onb. memory controller would act with these different chips..
    "M-I-A"
    Aug 2003
    Denmark - Aarhus
    takker bias It´s just that the price diff. is pretty stiff i believe but from what I´m hearing the way to go is EB! right?
    A second qustion - is the EB3200 so much lousier than the EB3700? it seems like everybodies is aiming for the 3700EB?!
    3DM 05
    3DM 03
    3DM 01
    Xtreme X.I.P.
    Nov 2002
    Shipai
    eb > el
    eb runs 3-2-2 wich is almost as fast as 2-2-2 because of some tweaks
    el runs 2-3-2 afaik. i think the eb is faster than the el at the same mhz
    Aug 2003
    Denmark - Aarhus
    right-on seems i´ve overlooked the diff in Trc - guess i´ll try out 1gb of pc3200EB - hopefully they´ll give me around 240-250 1:1 - right?
    3DM 05
    3DM 03
    3DM 01
    Jan 2003
    Tallinn, Estonia
    You should go with the pc3500EB if your looking for 250Mhz
    Aug 2003
    Denmark - Aarhus
    yeah well it´s cause i can get the 3200EB for at reasonable price
    3DM 05
    3DM 03
    3DM 01
    Feb 2004
    Denmark
    Hi all
    first sorry for the bad english
    i just got some Mushkin 3200 Special 2-2-2 Dual Channel 2x512
    1 of the bloks had a defekt.
    Now i will send them back and get other ram
    my mothermoard is the asus K8V Deluxe my cpu is af amd 64 3200+
    will the bedst be to get the
    1024MB kit DDR PC-3500 Platinum EB - OCZ
    or a new set of
    1Gb kit DDR PC-3200 Special 2-2-2 Dual Channel - Mushkin
    Xtreme Enthusiast p4z1f1st's Avatar
    Feb 2004
    y not the 3700EB ?
    or do you mean, they are good for people who want >250MHz and he would save some money by buying 3500EB ?
    ----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
    ----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
    ----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
    ----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
    ----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
    ----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
    ----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
    ----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
    AMD Fanboy
    Jan 2003
    San Luis Obispo, California
    price.. the 3700 got VERY expensive.
    i got 512 for 164, then a week later it was over 180 for that same 2*256 kit. $195 for 2*256 is a little high. and its about double that for a gig.... nearly 400? neg.
    Dell Studio XPS16... no desktop
    yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
    Aug 2003
    Denmark - Aarhus
    yeah ram prices have sky-rocket lately - unfortunately!!
    3DM 05
    3DM 03
    3DM 01
    Dec 2003
    Germany
    i just received my PC 3500 Dual Kit 1024MB today for P4C800E
    250MHz 3-2-2-5-4 prime stable with only 3,0V !
    More seems to be unlikely because of memory controller
    Xtreme 3DMark Addict
    Sep 2003
    another thing I want to clear is, ras to cas on the EB ram doesnt matter? because I was sure as heck that it does matter. pc3700eb does about 250fsb average but 3-2-3-6 and the 3 in ras-cas hurts performance bad over it being a 2, is that correct?
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    XS Intel News & D²OL enhanced
    Nov 2003
    Netherlands
    yes but CAS doesnt matter
    Memory Addict
    Aug 2002
    Brisbane, Australia
    personally i'd go for the PC3700EB for potential to go >250mhz 2.5-2-2-6/8 to 3-2-2-8
    Feb 2004
    Sweden
    If you look in local forums you get BH-5 cheaper than PC3700 EB
    Opteron 165
    Dfi NF4 Expert
    4x1 1GB twinmos PC 3200
    XFX 7900GT 550/1500
    Sep 2003
    thats what I told him. he thinks none of the timings matter, I told him it being cas3 doesnt matter but the ras-cas of 3 hurts it bad but he keeps saying it dont matter! sandra shows little bandwith difference but youll lose big performance in 3dmark and games though
  18. #18
    Jan 2003
    Tallinn, Estonia
    The OCZ EB will run with trcd of 2 on 95%+ of the sticks so what are you complaining about?
