Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Yay, fedex came!
    Nov 2002
    Earth: The Insane Asylum of the Universe
    Talking Yay, fedex came!
    Brought me my mobile Athlon64. The full code is AMA3200BEX5AR 9818xxxxxx0194 CAAPC0405TPMW I'm gonna fire it up VERY shortly. I have the Albatron K8X800 Pro II here, but I already have my RMA placed, and ordered up an Abit KV8 Pro, which DOES have the K8T800 Pro chipset. BTW, yep, those are at newegg. I'll be awhile, for a nice clean OS install, & making sure I have drivers, etc. Plus I'll be taking my time installing the chip & heatsink, since it's a bit different from what I'm used to. Later.
    Feb 2004
    Nashville
    You realize that at this time the KV8pro doesn't have agp/pci locks
    Feb 2004
    i believe amaXXXXXXX is desktop replacement, basically a lidless a64, amnXXXXXXXX is the actual mobile 64 as shown on amd's tech docs
    rig: dual opteron 244's, msi master2, 2x512 mushkin 3200, 9800pro
    Dec 2003
    Louisiana
    Yep, KV8 Pro doesn't have AGP/PCI locks, and yep, that's the DTR chip. They still O/C better than desktop chips, though.
    Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
    Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
    HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
    Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
    And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
    Nov 2002
    Roger that, but it's GOTTA be a simple BIOS update needed. (?) I'm not sure I can put it together today, my Alpha PAL8150 didn't come with the backplate, and I'm not too sure of the plastic one that came with the mobo.
    Feb 2004
    Nashville
    I hope you're right. If they do get it fixed, I may go for one, but concidering VIA's past history of locks, I'm going to wait and see.
    Apr 2004
    Berkeley, CA
    needs more thermalright.
    Xtreme 3DTeam Member
    Jan 2004
    Dresden
    i'd say get rid of cpu and mobo and wait for LV Mobiles and the newer revision of the via chipset, which does have a pci lock (or better go with nforce3 250, via sucks ... my opinion )
    Nov 2002
    LOL! Actually, the folks who reviewed the Alpha compared it to the Thermalright, and it was only 1c cooler on one test. Otherwise an even tie. This isn't the all aluminum one. Found some machine screws that'll work, and even tho there's no newby insurance, the core of the chip is HUGE, so I'm fairly confident. Just torqued it down nice & slow, kinda like on a Radeon core, once ya remove the shim.
    Sep 2003
    NY
    Cool...I was very excited when fedex delivered my 3400+ and fx-51. Best of luck
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thing is why would Abit fix the KV8 Pro right this moment ? if they did it would outsell their flagship KV8 Max3 which costs more ??
    Oct 2003
    VA
    The KV8 Pro is lacking many of the features found on the KV8 MAX3. Also, Abit likely will introduce a KV8 Max3 with the K8T800 Pro chipset, being that both chipsets cost the same and are perfectly compatible with one another. One should expect all Abit boards with this chipset to have AGP/PCI lock.
    Dec 2002
    Jersey City, NJ USA
    so this mobile chip is better than the desktop A64's? Do they have all the multi's available?
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
    May 2004
    The dogg pound, Denver CO
    From what I hear they run a slight bit cooler probally because of the direct contact with the core and have a slight OC advantage, but they are basicaly the same other than the core cover. Same adjustable lower multipliers. I may pick one up here soon just for the hell of I run completely stabe at 2.6Ghz with 2.04 Volts with a C0 stepping, maybe a CG will get me 2.7 ?
    Mar 2004
    Toronto, Ontario Canada
    Damn, that's kinda weak, only 2.6Ghz @ 2.04v?!? With a prommy I assume?
    Get a new chip!!!!
    Mar 2003
    Holland,MI-USA
    You relize that no one has gotten a DTR 64 to run in any board other thaen the AN50R with the 10/30 bios
    GL let us know how it goes
    Cooler Master 110 case w/window and cold cathode/Sony E540
    I7 920@4.4Ghz 210x21 Megahalems
    Gygabyte GA-X58A-UD3R
    OCZ 6Gb DDR3 1600
    XFX ATI 5770 960/1400
    Seagate Barracuda 1.5tb
    Lite-On DVD RW iHAS220-08/Sony Optiarc AD-7190S
    PC Power & Cooling Silencer 750
    That's my 2008 Street Glide.
    Feb 2003
    Asus K8V-D with a 3400+ DTR here
  18. #18
    Nov 2002
    Welp, I got totally sidetracked, (damn frisky women ) but the darn thing doesn't wanna go. I can't even get into the BIOS screen, just get the voice genie (which is HELLA cool btw), telling me there may be a problem with my CPU or there may be a prob with my mem. I spent about an hour looking for something I missed, switching DIMMs, and clearing the CMOS, as if that would help. Only guessing, but it sounds like someone fried the mem controller? Or the BIOS is just not able to recognize it? I'd kinda like to keep the chip, to try in the Abit when it gets here, but I think I only have 7 days to RMA. I think I'll call the egg on Monday and see what kinda options there are.
  19. #19
    Mar 2003
    Holland,MI-USA
    Ok, kool Thats the only other board that I've heard running a DTR. What bios are you using? Does it work with all the bios's? The shuttle will only work with the 10/30 bios if you update to a newer one you get no post just a blank screen as spaceman has described.
    OCZ 6Gb DDR3 1600
  20. #20
    Sep 2003
    NY
    I would buy 10 KV8 Pros if they had it working right I can sure use the locked agp/pci bus plus the 1.8vcore/3.2vdimm out of the box for customers rigs
  21. #21
    Nov 2002
    Heh heh, get out your checkbook, bro. Read this... http://forum.abit-usa.com/showthread...125#post333125 Notice I'm also tryin' to get some ideas planted for DTR support.
  22. #22
    Sep 2003
    NY
    Sounds good! But what about the 255fsb oc limit?
  23. #23
    Apr 2004
    Berkeley, CA
    thats weird, 225FSB was exactly what I got out of my KV8-Max3.
    Pissed me off that the processor didnt even get hot before I reached my OC limit.
  24. #24
    Nov 2002
    Well, supposedly they had the reference board runnin@270FSB.
  25. #25
    Aug 2003
    England, UK.
    if abit sort this board out, it could be the one to have.
    Rebuilding
