Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: OCZ EB owners on nF2, can post your highest stable speeds for me?
    Mar 2004
    Question OCZ EB owners on nF2, can you post your highest stable speeds for me?
    Stable, like 8 hours of Prime blend or Memtest. The only results I've seen are benches and whatnot.
    I got my 3500EB and have my first Prime run on an NFII 1/21:
    2.5-2-2-11 DC CPC 3.3v, and 1.7v to chipset. 220MHz 15 hours. At 225 Prime goes about an hour. That's a little dissappointing since I can bench Sandra up to 257. I like the 97% efficiency though, cause I've never seen over 95 on this board.
    I've never had to burn-in any BH-5, BH-6 or CH-5, so I'm not expecting to have to with this. But do I? I'll be doin more tests tonight.
    BTW, I've got good cooling over my board. A 172mm Papst moving about 75CFM over my HSF, NB, RAM, and AGP. NB temp shows 35 (bout 3 degrees above case temp.)
    NFII Infinity A __ XP-M 2500+ IQYHA __ 3500EB 2x512 __ XFX 6600GT __ WinXP Pro SP2
    My Heatware
    AMD Fanboy
    Jan 2003
    San Luis Obispo, California
    ill be testing on my DFI tonight. ill report then.
    ill be looking for 265+ range. hopefully.....
    Dell Studio XPS16... no desktop
    yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
    Mar 2004
    Yeah, same. I'm not interested in tight timings or high benches necessarily. I just want to see people's all-around best results.
    My Heatware
    Xtreme Recruit
    Oct 2003
    where the best place to purchase these?
    Jan 2003
    Tallinn, Estonia
    Apr 2004
    Yeah i would also like to see some results from this stuff. Most of the reviews have gotten it to some pretty high speeds, and the benchmarks outperform my mushkin lvl II PC3500 (which i sold on ebay for quite a price tag and need some good replacement ram)
    Mar 2004
    230 2.5-3-2-11 CPC DC 3.3v won't Prime even one minute. I can't get a 13MHz OC with even 0.7v added? Someone please tell me these need to burn-in..
    Fixed a typo in my first post. I meant 220 is 15 hours stable and 225 is not. So basically, these aren't overclocking. Tried all voltages and CPC disabled. Please just tell me to burn these things in. What am doing wrong?
    My Heatware
    Nov 2002
    Assuming you've tried lower? They might not like it or at least not right iff the bat. All my ram has always needed a day or two to settle in.
    Nov 2002
    california or chicago
    Dobbz
    Try 3-2-2 and 3-3-2, though some people have gotten CL 2.5 above 230 , I have not been able to.
    I would say to try 3-2-2 and bump up from there.
    The benches at 3-2-2 are far better than 2.5-3-2.
    And I can just about guarantee a huge oc improvement .
    also , lower the voltage a bit 3.1 seems to be the sweet spot
    OCZ employee and proud of it.
    If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
    I am overclocked!
    "Posted on Mar 30, 2005 at 1:35 AM by StormGod
    In soviet Russia memory overvolts you! "
    Mar 2004
    2x512 3500EB, Dual Channel CPC APIC. Day three of burn-in:
    EDIT: image hosting may be up or down. Screens are of 230 3-3-3-11 3.14v, 1 minute in Prime.
    I can't get 3.10 without my Vmod back in, just 3.06 or 3.14. Anyway, I get nothing at 230 no matter what timings or voltage, and like I said before even 220 is barely halfway stable (+3MHz ... ?)
    My Heatware
    Jan 2003
    Ayia Napa, Cyprus
    Mann that is bad, sorry to hear you aint getting decent results from these sticks of ram. I was thinking of picking some up, im definately going to wait this out a bit longer.
    Hopefully Cactus can show some better results. It is a shame, seems like the OCZ guys seem to have 'good' sticks whilst the other NF2 users are not having much luck
    mong
    Seasonic Prime TX-850 Platinum | MSI X570 MEG Unify | Ryzen 5 5800X 2048SUS, TechN AM4 1/2" ID
    32GB Viper Steel 4400, EK Monarch @3733/1866, 1.64v - 13-14-14-14-28-42-224-16-1T-56-0-0
    WD SN850 1TB | Zotac Twin Edge 3070 @2055/1905, Alphacool Eisblock
    2 x Aquacomputer D5 | Eisbecher Helix 250
    EK-CoolStream XE 360 | Thermochill PA120.3 | 6 x Arctic P12
    AMD Fanboy
    Jan 2003
    *ordered 3700*
    i didnt get it. they mesed up the order.. *sigh* 2 weeks and ill have my EB..
    Mar 2004
    I should mention that they run fine in dual channel with CPC and APIC enabled at default speeds and voltage without any wire or volt mod. Memtest #5 went over 200 passes with no errors. I'd say there's nothing wrong with these sticks cept that they won't OC at all so far.
    Sorry, I'll try and keep any other updates complete and not so disorganized.
    My Heatware
    Aug 2002
    .CA
    dobbz - sory to hear about your luck. I have the exact same sticks and I can run well above 220 2.5 2-2-2-11 on my LP-B. That is with CPC and APIC enabled at 3.0v I'm just working on getting you some screens. Gotta wait for prime to run for a while just to show that it is working and all
    If my answers frighten you, stop asking such scary questions...
    • Hush V2
    • Intel i7 4770K - XSPC Raystorm - Gigabyte G1.Sniper Z87 - Crucial Ballistix DDR3-1866 - 9-9-9-24
    • Zoltac Geforce GTX 780Ti - EK-FC780GTX Ti
    • SanDisk Ultra 480GB SSD - WD Black 1TB 64MB Cache
    • Custom Water Cooled Fractal Designs Define R4 - Antec HCP-1000 Platinum
    • EK Coolstream XTC 280 - Cougar CF-V14HB Vortex HDB - XSPC EX240 - Scythe GT AP-15
    • Dazmode Storm DDC 3.25 - AquaComputer Aqualis DDC 150 Reservoir
    May 2004
    Norway
    Ahh... Bummer, this doesn't look too promising. Was hoping for a nice replacement for my ol' 2x256MB CH5, which is doing fairly well (225FSB, 2-2-3-11).
    I was thinking about the 2x512MB PC3500 EB kit, but I've seen so many people getting pretty bad results on NF2's, that I think I'll hold on for a bit, and see how it goes.
    Abit NF7-S 2.0 btw.
    Nov 2002
    well 512 x2 on nforce 2 just wont go as high as 256x2
    I am overclocked!
    May 2004
    Norway
    Ye, and that's a shame because 1gig is kinda the minimum for a modern gaming pc nowadays.
    Still wanna see some more results before I go ahead and get something new. Don't wanna get something that won't do very good, especially with the EB's prices!
  18. #18
    Nov 2002
    right I am basically saying with any 512x2 you can basicaly bet on less of an oc than your getting with 2x256
    I am overclocked!
  19. #19
    May 2004
    Norway
    Yeah, I gotcha. Still 225FSB, as I'm running now should be achievable with the pc3500 EB. Especially since my board overvolts the vdimm a slight bit, it's close to 3.1v actually.
    If that's not enough there's always vmods
  20. #20
    Nov 2002
    yes I would think 225 3-2-2 should be simple
    I am overclocked!
  21. #21
    Jan 2004
    UK
    mong
    BigToe has sorted me out with a replacement set of EB. From what he told me it seems one of the sticks was mis-behaving which is just one of those things I guess. Hopefully I'll have more luck with the new set I recieve. Tony is da man!
    £58.73 - This is the amount of money a loyal customer is worth to Overclockers.co.uk
    Beware of buying from overclockers.co.uk, they will swindle you by abusing the consumer law if they need to refund you for faulty hardware. Thieving gits
  22. #22
    Aug 2002
    .CA
    220MHz @ 3.0v 2x512mb still testing, I'll update later.
    • Hush V2
  23. #23
    May 2003
    Sydney Australia
    I'm in the same situation as Cactus, one the the sticks does 2.5-2-2 fine @ 220 2.8v
    but the other stick could only do 209 3-2-2 w/ 3v
    Ryan's taking care of a replacement for me... fingers crossed
  24. #24
    Aug 2002
    .CA
    Unfortunately these guys can't test on every possible motherboard. Some sticks may not work as well with some chipsets. I've not had any issues yet with any boards, but thats just me. Glad to see you are keeping a positive outlook. Ryan is a good guy and I'm sure he'll look after you.
    • Hush V2
  25. #25
    Aug 2002
    .CA
    Just a little update
    @ 3.0v
    • Hush V2
