Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Project Divine Finished
    May 2004
    Stockholm, Sweden
    Lian-Li PC75B, plexi shroud.
    Aquacomputer's 3.360 Radiator
    Whitewater CPU, Swiftech MCW20 and MCW50
    Eheim 1250 and DD Bay-Res reservoir. Sleeved cables.
    System spec:
    Abit IC7-G vdimm mod
    Intel P4 2.4C @ 3.5GHz
    Radeon 9800PRO vgpu mod
    Mushkin High Perf. Black Lvl2 PC3500
    Antec TruePower 430W
    PM me for more pics.
    Xtreme Mentor
    Nov 2003
    Nice work, looks good, might I suggest at least a few Zip ties to secure the hoses...
    May seem as they'll never come off, and they may not, but it is cheap insurance...
    Xtreme Gamer
    Jan 2004
    Europe
    nice shroud
    what kinda temps. and OC are u getting?
    that rad. is huge ...u cud upgrade to TEC np later on
    Intel i7 930 @ 4.2Ghz 24/7
    Asus Rampage 3 Extreme
    Asus Radeon HD 6990
    Corsair Dominator GT 6GB
    Corsair AX1200, 600T
    Intel X25-M 160GB
    Dell U3011 30" Monitor
    May 2004
    Stockholm, Sweden
    Originally posted by a5h
    nice shroud
    The shroud is home made, perhaps not so very sexy, but it works well. =D
    I have a delta of 4-6 degrees between Idle and full load (dual prime). No use of numbers since they differ alot between different mobos.
    The 2.4C goes to 3.52GHz, did 3.2 with Zalman CU7k. The board is holdning me back, hitting a FSB wall =/ i hope to get my hands on a nice SL6WU, tried crotale's, it did 3.9GHz with this cooling and 1.65v.
    the gpu goes to 480 now, did 438 with stock air, pretty good increase imo.
    I have a MCW50-T laying around, might try it on and see what happens to the CPU temp, dont wanna sacrifice to many megahertz for lower temps on the 9800p.
    Havn't done any benching yet, waiting for new hdds to do a fresh winxp install on. also trying to find some time to voltmod the mem on the 9800p, the vgpu is done aswell as vmod for ram on mobo. think i need ramsinks for the gfx mems.
    peace!
    Nov 2003
    I saw your post at the Watercooled Case Gallery
    Nice Rig
    Nice work, looks good, might I suggest at least a few Zip ties to secure the hoses... May seem as they'll never come off, and they may not, but it is cheap insurance...
    I second that.
    Mine only does 450/375 ( I say only because I expected more, but It's not a bad O/C) I didn't get a very good core on my AIW 9800P
    think I need ramsinks for the gfx mems.
    Do you mean 9800P ? If so, then I would definitely agree.
    Haven’t done any benching yet
    Post them when you do
    Oh! and where is your CD-Rom?
    P4C800E DL,P4 2.4c @ 3.4(droop mod),1G Mushkin 3500 II 2,2,2,8 @ 3.1v,AIW 9800 Pro (450/370 @ 1.9v core),Audiology Platinum,2xDiamonds 8mb Raid0,Lian-Li Pc70,PC P & Cooling 510D,Plextor 708A,Plextor 52x32x52...water cooled...
    Mar 2004
    netherlands
    behind those lian-li bezels (two of them look different from the others) offcourse [edit] damn im stupid..... sorry is was wrong there, didnt look inside the cas --> to me [\edit]
    BTW i've got exactly the same case it rules!!
    [edit] i already see some zipties btw gpu-nb hose [/edit]
    May 2004
    Stockholm, Sweden
    I have zipties on the inlet and outlet on both the pump and radiator. I don't think it's needed on the other connections but I'm constantly checking for waterdrops around all connections, no sign of it yet.
    REDKEN, I forgot to mention that I've raised the vgpu to 1.77 (1.7stock), that might be the reason I'm higher than you (or perhaps you also have done vgpu mod?)
    The CDROM will be placed above the reservoir, just havn't done that yet. Who needs one anyway?
    Nov 2003
    Yep, done that too. Actually I have it at 1.9v (and won't raise it any more) I have done almost everything except Bios flash my card but there aren't any "optimized" Bios for the AIW's so I'm stuck at were I am, but that’s OK.
    Jun 2002
    New Zealand
    Very nice rig there nCrusader, I was just wondering if your Rad came with 1/2" connectors because all of the EVO series Rads i've seen only have 1/4" inputs??? or so you have 1/2" to 1/4" converters on there??
    thanks
    SyNtH
    Xtreme 3DTeam Member
    Jan 2004
    Dresden
    very nice!
    Xtreme Gamer
    Jan 2004
    Europe
    thanks
    i dont think its an EVO rad. but i might be wrong.
    Asus Radeon HD 6990
    Intel X25-M 160GB
    Feb 2004
    texas
    ncrusader - youre rig looks very awesome! congrats
    ive got a question, whered you get the vent on top? i really liek it
    May 2004
    Stockholm, Sweden
    thanks
    No, it didn't came with 1/2" connectors, I bought them separate. You can get 3/8" connections when you order
    Actually it is a Evo Radiator.
    Aquacomputer have them for sale, pretty expensive (€22) but it's worth it:
    May 2004
    Stockholm, Sweden
    A better picture of my own designed sleeved cables:
    And an ever better one (before the WC was installed)
    Xtreme X.I.P.
    Nov 2002
    Shipai
    very nice case! too bad you only hit 3.5ghz
    Nov 2003
    Br!ban3 / Aus / State: St0n3d
    Nice case, looks great.
    Ripping it up on old technology
    i4memory.com
    May 2004
    Stockholm, Sweden
    That's prime stability speed.
    I can run SuperPi @ 303FSB (3636MHz)
  18. #18
    Mar 2004
    netherlands
    own designed??? i've got exactly the same stuff, whut did you mean??? And the ATX cable comes this way with the power supply innit?
  19. #19
    May 2004
    Stockholm, Sweden
    I'm not saying that I was the first and only person in hole world who have sleeved the cables this way. What i mean is that I came up with the idea myslelf, not by seeing anyone else sleeve the cables the same way I've done it.
    Yes, the ATX cable is not modded.
    Please show us some pictures of yours!
  20. #20
    Mar 2004
    netherlands
    i've got no digicam, sorry........ but it is like this, only way neater cos this is just rolled up, it makes no sense(the guy who made this just shot a quick pic i guess). I have got all the excess wire behind my mobo backplate, and with my harddisk 'n stuff(not visible anyway ).This stuff is hard to get in Holland btw....
    (this i stole from a review )
    (it's called nylon sleeving, yours 2?)
  21. #21
    Apr 2003
    That's one nice looking shroud... does anyone know where I can buy them in the US? arrrg I want it! and your case
    Rig Specs:
    Current Rig Shot
    E4300 @ 3.2 GHZ
    ASUS P5B-Deluxe BIOS 1004
    OCZ Powerstream 520
    2x 1GB Crucial Ballistix PC8000
    2x 1GB OCZ Gold VX PC6400
    WD 160gb Raptor
    Gigabyte 3D Mercury - Black
    EVGA 7900GS KO
    2x Dell 2001FP 20" LCD
    Creative X-Fi Platinum
    Logitech Z680 6.1 Speaker Set
  22. #22
    May 2004
    Stockholm, Sweden
    ri3eboi, It's a homemade shroud.
  23. #23
    Dec 2002
    Nice case but still I would get some hoseclips or zip ties on there....
    - LL V1000 - GA965P-DS3 - Intel C2D e6420 3.22GHz - 2GB OCZ 6400 Plat Rev 2 - GeForce 8800GT KO AC S1 - 500w Enermax Liberty -
  24. #24
    May 2004
    Perth, Western Australia
    or worm drive clamps.
    nice setup nCrusader. so intel mobos do actually benefit from water, cause there running at a higher fsb generally?
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
  25. #25
    May 2004
    Ames, Ia
    Looks good, I love clearflex 60
    AMD FX-57, ATi EXPRESS 200 Motherboard, 1GB TCCD, 74GB Raptors in 0-Raid, RADEON X850 XT Platinum PCI Express, Logitech Z-5500 Speakers, Samsung 191T+
    Phase-Cooling
