Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: AN7 no modify FSB 250
Hybrid View
    Apr 2004
    Indonesia
    AN7 no modify FSB 250,.... (no prime, no benching),
    Rock solit at FSB 240
    so... AN7 is better than NF7, let's try AN7 Bro...!!!
    Jan 2004
    Halifax, Nova Scotia
    nice oc mate now lest see with some vmods
    Oct 2003
    Sweden up north!
    This is exactly what I have been waiting for! I knew there were boards out there capable of that! Very nice mate! Looks like im of to see if my board can do that too did 230 last time I tried, and that was the mem setting the limit
    | AN7 | Barton 2500+ @ 212x13 AQXEA 0330UMPW "Z" | R9600Pro FireBlade 400/300 @ 560/413 NO vmods! | Tyan G9800Pro 492+/390++ Still testing |
    | 24/7 | 230x10.5@1.82v and 1.75vdd | G9800Pro Tyan 470/380 For day to day use |
    Apr 2004
    Indonesia
    XP 1700+ at FSB 248x10 with air cooling (Zalman 7000CU + 2x9cm 7000rpm FAN, => amb temp 28 cel), PSA 450W Augem, DDR Adata Vitesta at 11-4-4-3, Rad 9800SE, VCore 1.875, VDimm 3.2, VAGP 1.65, VDD 1.75, all thing Disable
    AN7 is rock solid at FSB 240 out of box (with no modify at all), I use the stock BIOS,... but VDD just hold me back, I can't go more than that... needed VDD mod soooooo bad...
    Jan 2004
    Israel
    that's one mobo out of something like 10K that cross the 200fsb ... wow ....
    Abit Mobo's Are piece of S^#T !!!!!
    and the HELL N 7 is one of the worst ever ... - great job out there , A BIT WORKING ....
    Jan 2003
    Molde, Norway
    i got a AN7 v1 with the cut brige.. maxfsb is 219.. sucky
    A64 3200 @ x - Gigiabyte K8N modded - HyperX PC3000 - Radeon 9800PRO modded - Enermax 350 modded - Vapochill BD35F r404a modded
    Apr 2004
    Indonesia
    Orak, I don't know about ur problem there, but I 've try some other AN7 board, and work the same just like it,... no modify, no Vmod,... but I need it, Vmod to take more than 250FSB,..
    AMD Fanboy
    Jan 2003
    San Luis Obispo, California
    mine did 220 stable. 225 SORTA stable. more than that corrupted hdd and didnt work.
    Dell Studio XPS16... no desktop
    yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
    Oct 2003
    Sweden up north!
    If you only want to barf, do it elsewere! Give the guy some credit instead of vomiting all over his thread! And the AN7's aren't that bad, remember NF7-S rev1? The newer ones are actually pretty good, I've seen atleast 5 over 240 stable single channel and about 10 well over 230 stable dualchannel so just keep quiet!
    hyem: The VDD mod for the AN7 is the same as the one for the DFi Infinity. good luck with getting 250 stable
    EDITED BY: FUGGER - keep it clean
    May 2004
    my nf7-s v2 does 230mhz with no mod except cooling. ive got a zalman passive cooler with 40mm fan on each bridge.
    e6320 @ 3.2Ghz 7x458 1.38v
    DS3 rev. 1.6
    Diamond 2900 XT
    G. Skill 2X1GB
    250GB WD
    X-530 5.1 Speakers
    NEC 16x Dual Layer DVD-RW
    Turbo-Cool 510w Deluxe
    Vista 64
    Apr 2004
    Indonesia
    @S&M thanks I've take it as a compliment,... I'll go for it,..
    @Dominos Thanks bro, I'll try it soon (DFI VDDmod) and post some update, hope it's goes better,... Thanks,.. and I'll try to do Dirty-punk VDimm mod for my AN7 (as NF7 way)
    Why did you stuck at 220 ? I have the same board here I guess, and I've try to do it with some other 2 AN7 board, and it's all rock stable at 240,.. Have U guys try to update AN7 tictac BIOS... ?
    btw, my NF7 Goes prime at 240x10 but it was full of Vmod (waiting for VTT mod to go more) :-)
    Prime again and again for hour my XP 1700+ It's totally Rock at 243x10 on AN7:
    first boot at 232, I use clockgen to mak it 243 (real time clock) and it's still prime until now,..
    Oct 2003
    Sweden up north!
    Which one of Tictacs BIOS's are you using? Tell me!!!
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    hyem
    Why the heck are you using small FFTs to test high FSB? Select Custom and select FFT size from 1024 to 4096. This tests RAM/Chipset only.
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Apr 2004
    Indonesia
    Dominos => I use ver 14 tictac BIOS, btw to day I've try use 14 ABIT bios and it's work just the same,...
    IvanAndreevich => sory I use Prime95 version 22.12.1,..... but I've prime it almost one day, and there is no eror on it,.. maybe ur right i'll update my prime95 software and test it again,.. thanks,..
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    hyem
    The old prime you have only tests the CPU. The small FFT size DOES NOT test any ram as it fits into L1 cache of the CPU. You definetely need to update your prime if you intend to test memory with it
    Apr 2004
    Indonesia
    thx,.... I've update my prime to day and it's work the same,.... Still Rock solid,.....
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Excellent.
  18. #18
    Jan 2003
    Molde, Norway
    but im happy for you with 250fsb I use mine as a "server" so it dosnt matter anymore
  19. #19
    Bulletproof
    Jan 2003
    Shun low, K?
    240 prime stable single channel loose timings isnt that impressive.
    Hell, dual channel tight timings can be done on infinities @ 240 pretty commonly.
    Only the stupidest humans believe that the dogma of relative filth is a defense.
  20. #20
    Apr 2004
    Indonesia
    Lithan,.. I'll try Dual chanel and agressive timing, but what can I do,.. I haven't got my BH-6 Back (my friend borow it) and VDimm Voltage only 3.2V, mine here only ADATA Vitesta PC4000,.. I'll try BH-6 soon,... with Vmoded AN7,.. hope it can prime 250 and more,.. (btw, I do prime at 248) and it's all with air cooled,...
  21. #21
    Banned
    Dec 2002
    it has not yet verified.......
    so I take it you are running the Adata PC4000@ cas3.0-4-4-11@ SCDDR@ 249FSB. Nice FSB oc'ing. Obviously your board is liking the Adata memory stick a lot. The member "Dirty Punk" also achieved very high FSBs with his Adata stick at lose timing.
    plizz post superPi or hexus piFast and let's see the performance.
    I don't know if you're looking for the FSB oc'ing pleasure or you are looking for the pure adrenalin-pumping performance of the system. I personally go with the pure performance, not high FSBs with weak settings. I don't mean to rain your parade but I feel the need to say this. Some newbies will come in here and read this. They gonna think the Abit AN7@ 250FSB is achivable and really perform like a 250FSB 128bit DC FastDecode 2-2-2-x performance. It's not misleading for me, but could be very misleading for new commers(no i'm not talking about you, but others)
  22. #22
    Pha_Q
    Guest
    still gotta give propsto that AN7... but i like my dfi infinity, 240fsb Sync 100% stable, i've gone as far as 255 but my bh-5 needs more volts past 240, and i cant give it any more without a vmod.
  23. #23
    Nov 2003
    Çégh hyem nice oc. Very good indeed. Unfortunately the CPU interface is Disabled, so your benchmarks want give u any good performance
  24. #24
    Apr 2004
    Indonesia
    Thanks,...You're right guys its just a high FSBs with a weak settings cos it was the only one Ram that I have, I have no BH-6 that time,... btw it's still surprise me, coz I don't think that AN7 can do that,.... without any mod, but it does,... soo I just take my board off and continue do some test again with NF7, my AN7 just take a rest for some vmod now,... wait for me to take a ride with AN7 Vmoded,... I'm still workin on it,... thanks guys,...
  25. #25
    Fused
    Dec 2003
    Malaysia
    Mr Henry Benchmark result
    AXP-M 2500+ (No L12 mod)
    2x 256 Twinmos PC3200 BH-5
    Radeon 9800SE @ 9800 Pro.
    Wizzard Catalyst 4.5
    WinXP SP1, DirextX 9.0b
    Abit AN7 (CPU Interface Enable, 11-2-2-CL2, N24AAC18 bios)
    no volt mod, no L12 mod.....
    just bios mod .... by enduracell
    Not bad at all
