Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 119
Thread: Radeon 9700 volt mods posted
Hybrid View
    Xtreme Legend MrIcee's Avatar
    Jun 2002
    Cambridge, NY
    Thumbs up Radeon 9700 volt mods posted
    Hi guys
    Just stopped in to let you overclockers know we finally got a pictorial guide to volt modding the Radeon 9700 Pro posted on our site. OPPAINTER and myself and many others have tested and utilized these mods for some time now..and with xtreme cooling have been seeing GPU overclocks in the 450-500Mhz range. Come on over and check it out here :Radeon 9700 volt mods
    Take care my friends,
    Randi
    __________________
    Sep 2002
    Exclamation
    Just have one question. In the pictures, each VR has 2 wires...one connecting to the designated pins, but where does the second wire go? I can only assume it's for grounding purposes (unless I'm completely wrong...), but I'm not entirely sure where it's grounded to. Yes, I'm a noob when it comes to extreme stuff like this, hehe.
    Thanks for the guide, PiLsY, Manoj, DD, and of course, Icee.
    Oct 2002
    The beach in SoCal
    Wink
    ok looks like you guys got the GPU and VDDQ/VDD volt mod correctly. BTW 454/363 zero artifacts with my 4 different volt mods and i'm using an old POS socket 370 heatsink/fan But good job with your mod so far and oops edited for political reasons lmao
    Aug 2002
    Radeon mem voltage
    Core voltage checks out ok but the mem voltage only shows 1.4 volts.This is half of the default 2.8.What am i doing wrong?
    Xtreme Legend
    Jun 2002
    Hong Kong
    Smile
    I think you have used the wrong measuring point for Vmem.
    DDTUNG
    Aug 2002
    Radeon mem voltage
    I have closely checked Manoj Mahtani's card and it looks like
    the point to check is right next to the ground wire
    Aug 2002
    Radeon mem voltage
    Can someone please tell/show me where on the card i can check the mem voltage.
    Jun 2002
    UK
    One thing that might be handy guy`s if you showed the voltage measurement points so you know how high you got it cranked
    Sep 2002
    Sydney
    Thanks MrIcee, will try it next week when I get my Radeon.
    Your Voltmod tutorial for the KX7 is excelent.
    Sep 2002
    Re: Radeon mem voltage
    ThisGUIDE includes a picture of where to measure the memory voltage.
    Aug 2002
    That guide shows core modding only,not memory
    Sep 2002
    Austin, Texas. USA
    Memory Voltage Points
    Hello All:
    Although this thread is a little old, I still believe there is a need for clarification as to where the MEMORY voltage measure point is, not CORE as the link above covered.
    Can anyone tell us where the best measurement point is for the memory?
    (The scary part is I did the mod thinking I had the correct measuring point. After the mod, it clocked up to 379 on the memory and there was nothing burning, but I don't dare make any further adjustments until I can quantify the voltage changes).
    Please help!
    -Zippyc-
    Latest: Asus K8n4-e Delux, Mobile 3400 with 1 Mg cache, 754 PCI-E goodness, 7800GT. Four other AMD rigs and a Dell notebook.
    Technician
    Jun 2002
    Merseyside, UK
    Apologies for not noticing this earlier .
    New pic posted below :
    [Edited due to idiocy - well spotted DD ]
    PiLsY.
    Technician
    Jun 2002
    Merseyside, UK
    And for the sake of completeness I edited one of Mahoj's pictures to show Vgpu measurement. Hope you dont mind m8 .
    PiLsY.
    Ritalin Junkie
    Jun 2002
    Spokane, WA
    exactly the same problem here.
    Lagwagon, i am wondering, are you using the original ATI?
    the card i am Vmodding right now is a Gigabyte,
    and while its highly unlikely, the strange 1.4v measurement might be attributed to the fact that its somehow different than the original ATI.
    any other suggestions as to why that may be?
    thanks
    Sep 2002
    Austin, Texas. USA
    V-Mod for Memory Measureing Point
    Gentlemen,
    I also get a measurement of 1.398V across that point, and I have a USA version of the ATI...built by ATI, so I do not believe that we have the right measurement point. The voltage does not change at that point with adjustment of my trimmer either, so I believe we will need further even further clarification on this matter.
    Thanks Pilsy, for the help, but I think we are still stuck. Perhaps DDtung knows?
    Thanks to all the xtreme moderators on this one!
    -Zippyc-
    Sep 2002
    Austin, Texas. USA
    Thanks DDtung et al!
    DD cleared this up for me via. PM last night, and I have taken the liberty of plagerizing the original pic. to illustrate the correct measuring point for your memory voltage. Measure the cap legs right next to the cap we were reading 1.4V from, and you'll get your readings (which DO change with the trimmer settings this time.)
    I was running 3V when my memory hit the 379.93 mark in Powerstrip.
    -Zippyc-
Name:	top layer.jpg
  18. #18
    Oct 2002
    Netherlands/Wassenaar
    I did the GPU mod and have used a 10kVR, but when I`m messured the Vgpu there is 1.7(Hercules is default already 1.6).
    The 10K is messured on 8, but when I adjust I don`t messure difference in voltage. What`s wrong??
    I also used a 8k and that give`s me 1.74vgpu(I use WC on the GPU) , what will bring me 7K. , higher voltage or lower?
    And what`s the max voltage with water temp`s 19*C ?
    Vgpu mod. @430/380 score 19863
    http://service.madonion.com/compare?2k1=5091499
    Prometeia-Li-Pro > sold
    PrometeiAopen > sold
    P4 2.8/800 Unlocked / EP 4PCA3+ / 4x256mb Corsair PC3500C2 / 2x WD Raptor / PC71 WC cooled. And Mach2-Lian-Li PC61
    http://home.wanadoo.nl/a.p.versteeg/...ometeia-Li.htm
    http://home.wanadoo.nl/a.p.versteeg/prom-li-pro
    http://home.wanadoo.nl/a.p.versteeg/PrometeiAopen
  19. #19
    Technician
    Jun 2002
    Merseyside, UK
    Ooops....
    Sorry .
    PiLsY.
  20. #20
    Dec 2002
    ok... so far my core is at 420, what do i set the 20k VR at initially for the mem volt mode?? how high is safe?
    P4 2.66 C1 @ ~3.5Ghz, Abit BE7-Raid
    1GB Corsair xms pc3200
    9700Pro @420/702 watercooled/TEC MCW-50T on its own circuit
    Audigy DVD DigiDoc 5
    VAPOCHILL PE in LianLi PC71
    2 IBM GXP75'S In RAID 0
    Antec TruePower 550
    XP PRO
    http://lisch.no-ip.com for pics
  21. #21
    Sep 2002
    Austin, Texas. USA
    Volt. Mod Adjustments
    Lisch,
    Your resistor has less effect on raising the voltages the greater your resistance is. (think of it as no connection= infinite resistance=no volt mod IE: factory voltages.)
    So in the future you can always start with whatever the greatest resistance setting is and should be safe (assuming you have the right value potentiometer or trimmer in the first place.) I adjusted a turn at a time until I got close to 7% higher voltage than factory specs and then went half a turn at a time from there. With the right variable resistor, you should quickly get a feel for how much the voltage is affected by a single turn.
    I suggest you use a 20-turn trimmer for this mod as it seems to allow me to make minute adjustments very easily compared to the round tiny pot kind that requires a phillips head screwdriver to turn.
    When my voltages were too high, the memory temperature became my limiting factor. When the memory thrermal probe read 50C or higher, I began experiencing slowdown on my scores and more jaggies, so I guess my advice is for you to be sure to monitor those temps closely.
    Happy clocking!
    -Zippyc-
  22. #22
    Dec 2002
    ok, thanks a lot!!!
    Antec TruePower 550
    XP PRO
  23. #23
    Nov 2002
    MA.
    I noticed that the x-bit labs mod has 1 more modification than this one, and was wondering why it has been left out of this one? He modded the memory at 2 different points,1 of them the same as this mod, but 1 under that heat shield...... did this get left out because it wasnt needed for some reason? Or because it was found out that it wasn't worth the effort to include it. I noticed the he uses fixed resistor values ( which for obvious reasons is not as tunable), like he did on the 8500 mod.
    The mod page is here:
    http://www.xbitlabs.com/video/radeon...-overclocking/
    Zen2 Has brought AMD back!
  24. #24
    Ritalin Junkie
    Jun 2002
    Spokane, WA
    appearantly, the one under the shield is for increasing voltage of memory I/O circuits,
    as opposed to increasing the voltage of "inner circuitry of the graphics memory", that we all know about.
    interesting, this may be the reason why only few people got decent memory overclocks with only one of the memory mods--the I/O circuits couldn't handle the speed, while the memory may be capable of more...
  25. #25
    Nov 2002
    MA.
    Yeah I saw what it was for, I was just wondering why DD and Randi didn't use it........ interesting. If it will make a difference, and/or make it more stable( I should say no mem tearing) at higher clocks, then it is as good as done.
    Thanks for your input dimitri.
    muzz
