Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 125
Thread: So has anyone actually got their EB to work?
    Jan 2004
    UK
    Edit: Got my EB to work, big discovery inside.
    I've solved the problem, can a mod please amend the thread title?
    Significant find inside.
    (edited to remove rant factor, sorry guys - Gaz)
    £58.73 - This is the amount of money a loyal customer is worth to Overclockers.co.uk
    Beware of buying from overclockers.co.uk, they will swindle you by abusing the consumer law if they need to refund you for faulty hardware. Thieving gits
    Nov 2002
    The 909
    Maybe you got a bad stick? Does memtest give you errors at stock?
    Jan 2004
    UK
    Sorry guys.
    Jan 2004
    Is this ram in beta ?
    Jan 2004
    UK
    Sorry for ranting.
    Nov 2002
    california or chicago
    cactus can you list your setup.
    I am curious becuase your BH-5s were incompatible also
    try not to be hasty in making calls , I have had pretty good luck with what playing I have done
    OCZ employee and proud of it.
    If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
    I am overclocked!
    "Posted on Mar 30, 2005 at 1:35 AM by StormGod
    In soviet Russia memory overvolts you! "
    Jan 2003
    Cactus, Iam running the same stuff on the DFI NF2 Ultra without problems up to ~255 MHz.
    Can you list your latency settings, frequencies and voltages as well as the complete system specs?
    I am sure we can get to the bottom of this pretty soon.
    for starters, I would think you should try with a single DIMM only in slot #3 with changing the DIMMs to make sure that it is not one single DIMM that screws you up.
    OCZ Product Specialist
    Mar 2004
    Hello Cactus Jack. Seems you are having issues. What motherboard are you running?
    I have spent many hours testing the EB RAM and I assure you that if it was $hit we would not have released it. All of the benches and post I made were the real deal.
    Email me off my sig for some one on one, I'll give you my IM and we will get you running. Otherwise give me some more system info and we will do it here.
    Lets get it ON!!
    OCZ Marketing Team
    Email Me Here or Need Technical Support? Go to OCZ Support Forums
    Dec 2003
    texas
    hope it was a bad stick i was goin try this stuff out guess ill wait.
    Nov 2002
    Well ,
    I did find a guy whos having good luck on his Nforce 2
    over at DSL reports forums http://www.dslreports.com/forum/rema...8764~mode=flat
    Also Megahurtz , rember cactus had issues with Bh-5s also
    I am overclocked!
    Dec 2002
    Jersey City, NJ USA
    Ryan I was just going to post Podunks results. He actually got them after seeing most of my results
    Cactus lets not be hasty. Possibly you got a bad stick, and I am SURE the OCZ guy's will work with you.
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
    Dec 2003
    texas
    so it should be okay with intel? which would benefit me the most at 250fsb? 3200eb, 3500eb, or th3700eb i want the tightest timings. voltage not aprob. ive had my 3.3 rail to 3.90 w/out probs
    Dec 2002
    Jersey City, NJ USA
    I don't think there will problem on any platform. Cactus more than likely has a bad stick.
    As far as what's best, prolly the pc3500 or pc3700 if you can get it. For 250 the 3700 might be best. Ryan??
    HeatWare
    Nov 2002
    I had great luck with the Asus P4C
    at 3.3 volts 500mhz I would guess 3-2-2 is a sure bet but you might want to stick a fan on the ram
    My guess is that cactus since he had problems with bh-5 also
    probably has some other issues .
    I am overclocked!
    Mar 2004
    I've ben testing the bejeesus out of NF2 boards and had great luck. The really cool part is that the 512mb modules work great and overclock just fine. I'll get stickers out of Cactus' behind when he comes on tomorrow.
    OCZ Marketing Team
    Dec 2003
    texas
    so which ones 3200,3500,3700 would you recommend? im about to order but would like your opinion?
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    megahurtz-oc,
    for 250+ on the 875P, try the 3500EB (or 3700EB) and shoot for 250, 2.5-2-2-5. Let us know!
    C
  18. #18
    Nov 2002
    I am doubtfull on 2.5-2-2 @ 500 , unless you guys have seen people doing it
    I see stability issues @ 460and above 2.5-2-2 on 875 boards at normal voltages ( 2.85 )
    3-2-2 seems more realistic
    trying to be helpfull
    also keep in mind , while I was able to run 500+ pretty easily that even the 3700 is only speced at 3700 ;-)
    My opinion on 3500 vs 3700 , is definetly get the 3500 and save yourself some money
    I am overclocked!
  19. #19
    Jan 2003
    well, the EB stuff really works great at low latencies, that is the main thing for me.
  20. #20
    Dec 2003
    texas
    thanks ryan just ordered some 3500. ill keep ya guys posted. hopefully ill get this stuff at same time as my new 3.4ee.....
  21. #21
    Oct 2002
    Field of Battle
    nice...keep us up to date.
    C
  22. #22
    Jan 2003
    I'll push it a bit more tomorrow... time to hit the sack but I am running rock-solid at 2.5:2:2 and 220 MHz, what else do you want?
    255MHz is no problem either but I have to relax the latencies then.
  23. #23
    Nov 2002
    Mega -
    When you get it , drop me a pm , I would love to get involved in helping you take it to the max :-)
    I am overclocked!
  24. #24
    Jan 2004
    Hmm..this EB ram gets hot enough that it needs a fan right on the mem to get higher? Seems like even with 3.3v my hyperx doesn't get hot enough to need a fan, and even with a fan I don't think the difference would be that dramatic.
  25. #25
    Dec 2002
    Jersey City, NJ USA
    a fan does help. I have seen a few ° drop with the fan on than without.
    HeatWare
