Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: What stable speeds with OCZ 3700EB and what timings to expect?
    Dec 2002
    HELLAS
    I am thinking of giving a shot at the new OCZ 3700EB modules.
    at the mo my 2.8 is at 286fsb and i get errors in prime with my OCZ LE 3500 BH5 so i am thinking of getting some new ocz sticks
    i love low timings and i think these modules will do 2.5 2 2 5 no worries right?
    whats the expected max stable fsb with these timings and say 3.3V through them?
    what can they do 1:1 with the same voltage and what timings?
    really looking for rough numbers...just to think whether i should get some or just run my bh 5 @ 2 3 3 5 to get them prime stable instead...
    cpu does 286fsb for now prime stable and i am gonna push for more the following days...
    Nov 2003
    VIENNA
    go for the pc 3500 they do up to 280 1:1 at cl 2, not sure about the new pc 3700 though
    Overclocking made in Austria
    Dec 2002
    HELLAS
    u reckon?
    hmh lets see what ryan says too...
    dunno if i should sell this bh 5 though...
    it did 255fsb @ 2 2 2 5 turbo enabled etc but it aint stable...
    Aug 2003
    orange county
    from what ive read none of the eb ram will not run cas2. it runs 2.5, and theres no difference in performance between the two..
    heatware
    ebay feedback
    FX-55
    DFI NF4 Ultra-D
    XFX 7800GTX
    Kingston 2x512mb BH-5
    Vapochill LS
    Nov 2002
    california or chicago
    if you running BH-5 @ 286 1:1 I would hold on to what you have
    If your planing on running 5:4 (228) I see no problem with running eb 2.5-2-2 , Though on the 875 chipset ( IC-7 original especialy ) Eb seems to prefer 3-2-2 or 3-3-2 above 230
    With 3.3 volt who knows what you can do , you should be prepared to put a fan on the memory at that speed though
    OCZ employee and proud of it.
    If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
    I am overclocked!
    "Posted on Mar 30, 2005 at 1:35 AM by StormGod
    In soviet Russia memory overvolts you! "
    Dec 2002
    HELLAS
    hi buddy
    i am using the ocz 1gb PC 3500 Limited Edition BH 5 modules...
    they did 255fsb @ 3.3V @ 2 2 2 5 turbo ,enabled etc ...no cooling at all but they werent even close to stable...
    prob is now that i am running 290 prime stable and still testing higher every day but with my ram @ 3:2
    at 5/4 i was getting prime errors after 2 hours...
    so my ram aint stable at a lot lower than 255fsb.
    so what i want to achieve is 290 fsb 1:1 with some type of ram prime stable though with some good timings...i know its not doable so yeah some 5/4 ram that would do those speeds prime stable would be my target or 1:1 capable ram with the same performance of 5/4 :p
    These 3700 are supposed to do ras to cas 2 right? like 2.5 2 2 5?
    could you tell me what did those sticks prime stable at 2.5 2 2 5 for example wich is the tightest timings you can run i guess and then @ other timings their max stable speeds?
    is there any 300 fsb guarranteed ram out there prime stable?
    sorry if i am putting too much work for you...
    i have been through soooo many sticks of ram this year...people here remember me from that...5/4 issues...c**p overclocking and loads more...
    i kept these ocz cos they are the first ocz sticks that i bought and amazed me...wanna keep it like that
    The 3700EB seems like the best ram to get tbh....high fsbs @ low timings...and tight timings at low fsbs...i guess no 5/4 issues nore 1:1?
    loads of questions i know but i need to be 99% sure
    thanks in advance
    Nov 2002
    What motherboard you running
    I am overclocked!
    May 2003
    Greece,Athens
    brwmogazos we were thinking the same
    I 'm thinking to buy 3700 EB just to have 265 fsb 1/1 with my 3.4c
    My BH-5 can do 3d at 257 at other benches at 261.
    Apr 2004
    Me and a few other guys at ABX forums are having issues with the 3500 EB's and 5:4 divider on the Asus P4C800 series of mobo's.
    http://www.abxzone.com/forums/showth...5&pagenumber=8
    When I posted my benchmark results in the other big EB thread earlier at 225mhz, I compared the EB's Cas 2.5 against the BH5's Cas 2 at x-2-2-5.
    I was interested to see what impact Cas 3 would have on the EB's. So I set the timings to 3-2-2-5 at 225mhz.
    No boot.
    System refused to post.
    Put back to 2.5-2-2-6, ejoyed the speed and thought nothing of it.
    That was with 5:4 divider and a few other people have reported the same problem.
    Basically, I think the EB's are having issues with Cas 3 enabled with the 5:4 divider. 1:1 overclocking with Cas 3 is not effected.
    My 2 x 512MB of OCZ PC3500EB's are currently running along at 225mhz, 2.5-2-2-6 and 2.85v. That's with the CPU at 282mhz and the 5:4 divider.
    Dec 2002
    HELLAS
    Ok some specs.
    Intel P4 2.8M0 that does 313fsb max
    Asus P4C800E Deluxe rev 2.0 with the droop mod and Vdimm mod (max Vdimm 3.35V- 3.33V under load)
    nVENTIV Mach 2 GT
    Dec 2002
    HELLAS
    Did more progress with prime again...its prime stable at 293-295fsb so i prolly need some 1:1 300fsb capable ram thats stable or some 5/4 ram thats got good timings
    dont want to push more than 1.75V through my chip for 24/7 really but i may do so the target is about 300fsb stable really need some advice on what ram to choose now...
    Nov 2002
    sounds like your currently kicking major but
    I am overclocked!
    Dec 2002
    HELLAS
    LOL not the answer i was looking forward to but
    thats fine as well
    little more progress....297 prime stable now
    ryan what do you reckon mate?
    EB 3700 for 5/4 and 2.5 2 2 5?
    1:1 4400? with 3 4 4 8 or something? will they do 300fsb
    i really dont know what to get now
    Apr 2004
    No boot.
    This happens on Asus P4P800's as well as P4C800's.
    Athlon64 FX-53 || Asus A8V Deluxe || OCZ 3700 EB || BFG 6800GT @ 425/1200 || Audigy 2 Zs || Western Digital Raptor || Antec TrueControl 550
    Dec 2002
    HELLAS
    hmh i tried my OCZ BH 5 @ 3 4 4 8 and guess what... no boot either :p...had to clear cmos in my P4C800E..dunno if thats normal for BH 5...
    Apr 2004
    Hmmm... might be just that Asus boards don't like Cas 3 and the 5:4 divider.
    Dec 2002
    HELLAS
    dunno i tbh
    so whats the max stable speed you got the 3700EB mate?did you push more Voltage through them to see what they an do stable?
    i need like 237fsb @ 5/4 with good timings and i can push 3.3V
    the other option is 1:1 and 297fsb prime stable ram...
  18. #18
    Apr 2004
    This was at 5:4?
  19. #19
    Dec 2002
    HELLAS
    Originally posted by :PopCorn
    This was at 5:4?
    yes it was mate
    i wanted to see if i could get away with slacking my ram timings...
    so i tried the worse...
    3 4 4 8
    no boot
    nothing at all
    but guess what
    @ 2.5 4 4 8 IT WORKS....
    these were the timings of my board when clearing cmos to get it alive again...
    99% its a board issue i guess
  20. #20
    Apr 2004
    Sounds like that is correct.
  21. #21
    Aug 2003
    orange county
    your bh-5 wont do that?
    heatware
    ebay feedback
    FX-55
    DFI NF4 Ultra-D
    XFX 7800GTX
    Vapochill LS
  22. #22
    Apr 2004
    dunno i tbh
    Surely your BH5 can do that already?
    I've got 2 x 512mb of the PC3500 EB modules.
    No point spending more money when you've got ram that's more than capable of doing what you want it to do.
    You've got cracking BH5 capable of high speeds and timings.
    OCZ EB is for us peeps looking for BH5 performance that is available to buy in the shops, not for ridiculous amounts on Ebay.
    Absolutely no use imho for people with decent BH5 already.
    I'm hoping OCZ EB tech will filter it's way up through their product chain.
  23. #23
    Nov 2002
    you migth have reached the motherboard max
    I am overclocked!
  24. #24
    OCZ Product Specialist
    Mar 2004
    The 5:4 divider rarely works on the ASUS boards with most RAM. It's a good thing I think that the EB will work at 5:4 at CAS 2.5 settings. The EB really is optimized for CAS 2.5. It can work in most situations 1:1 at CAS 3.
    OCZ Marketing Team
    Email Me Here or Need Technical Support? Go to OCZ Support Forums
  25. #25
    Dec 2002
    HELLAS
    i get errors in memtest so... i dont consider that stable...
