Anybody got this new stepping?
I should get my Prescott 3.2 OEM, D0 Stepping (CPUID 0F34h) end of this week or early next week.
I'll post results as soon as I get the CPU.
I thought I was sent one, but I was wrong. Its a very good stepping 3 though.
I will check Fry's today and see what they have in stock. I am in the middle of rotation again
I was hoping Opp would show us 5Ghz last weekend.
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
So I can expect high clocks? (Phase Change (R404a)) ?
What about power consumption? Less then the first steppings or the same?
Not sure yet, I hit 4.2Ghz (300FSB mobo max) on a 2.8e when they were first available. I was using R507
I was able to run benchmarks at that speed too.
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
Oh yeah, no D0 stepping at the local Fry's
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
SL7E5 is the stepping of the CPU
Should get it on tuesday next week
What cooling would u use ? Stock ?
Duron 800@1120(x140) 2.3v/MSI KT133A Vmod/192MB PC133 CL2/Sapphire Radeon 9550 128MB All Vmods 250/200@533/290
3DMark2003
Fist stock, then Water and at last PhaseChange Cooling
Fugger was that on air cooling or water cooling?
Hi,
i just got a Prescott 3.2GHz D0 stepping!
Stylist
nice, have piccy of IHS markings??
C
hows the temp?
2,8€ @4130mhz
radeon 98 pro440/380
ic-7max3 full modded
Sorry, no digital camera available.Originally posted by charlie
C
What information do you need?
It seems to be improved (a little lower).Originally posted by Huhn
hows the temp?
Just my opinion ("feeling"): approx. 5°C lower.
Stylist
complete code (likeSL6WK)
and week???
Real NICE!!! Can't wait to see more results. I'd expect 4.1ghz on AIR.
C
HI,Originally posted by charlie
and week???
C
it is a SL7E5 OEM.
SuperPi @ 3.92 = 34 sec.
I guess there would be more, but my ASUS P4C800-E is crap.
Stylist
Stylist,
This may be surprising, but with Prescott, IC7 family OC's MUCH better!!!! I had a 3.0E ES that went 4609mhz and like 307mhz. It's a stock IC7-G with the Vdimm mod and that's all...
C
Hello
What is the kind of condition Vcore with the Prescott?
1.385 i think?
and max? 1.6V?
I'll get this CPU on tuesday and test it in my IC7 (moded)Originally posted by charlie
Stylist,
C
With air and vapor cooling.
In which way does the vtt mod improve oc ability?
I would be interested, too (vTT mod)?Originally posted by jan
BTW: What the f... is meant with vTT? - I am too lazy to use the search function.
are you overclocking on air? man, I want a D0... have you done the droop mod on the asus card? my vcore is 99% stable with my prescott...
my old prescott is already pretty good (2.8e@4,3ghz max benchable) but i want more as usual![]()
2,8€ @4130mhz
Stylist: were did you buy it?
Which cooling system?Originally posted by sxs112
3.4G ES(0F34)
Aircooling, water, phase change ?
