Results 1 to 16 of 16
Thread: VoltMod for GeForce 256 (Asus V6600 deluxe) ???
    Apr 2004
    Germany
    Who can help me? I'm searching for a voltmod.... i wanna practise these things before i try to mod my 9800 Pro
    Feb 2004
    Here we go
    Can you read the part numbers of all the chips circled+numbered? There is nothing on the backside of interest.
    Apr 2004
    Germany
    1)
    D1802:
    T 9K
    2)
    96BV
    LM431
    ACM
    3)
    LT928
    1144
    4)
    TL072C
    97M
    AXDF
    5)
    431AC
    98M (last letter not sure)
    D61D (last two letters not sure)
    6)
    KTN
    K7
    Feb 2004
    Originally posted by LeChuck
    1)
    D1802:
    T 9K
    MOSFET, not particularly of interest
    2)
    96BV
    LM431
    ACM
    LM431ACM = 2% accuracy SO-8 linear reference diode <-- Voltmod candidate
    3)
    LT928
    1144
    iuno....
    4)
    TL072C
    97M
    AXDF
    Dual Op-amps - possibly feedback control mechanism? Datasheet
    5)
    431AC
    Same as LM431 but from a 3rd party manufacturer
    6)
    KTN
    K7
    iuno - probably not voltage related
    Now what you need to do is get your multimeter and measure the voltage across each of the large can-type capacitors and post them - just put the voltages on the pic. If there aren't leads through the PCB then you have to get up close and personal on the other side. There are usually two solder pads that you can put probes on.
    Apr 2004
    Germany
    Do you mean the 2 black capacitors near the GPU?
    Feb 2004
    These caps, if you can
    Apr 2004
    Germany
    I will try on saturday!
    Thx for your help
    Apr 2004
    Germany
    Here they are!
    Feb 2004
    Apologies for not replying in a while.
    Chips 2 and 5 are the ones you need to mod. Both are SO-8 packaged LM431s, even though they are made by different manufacturers they should still have the same pinouts.
    Modding these should be easy.
    http://www.national.com/ds.cgi/LM/LM431.pdf
    First, check that the reference pins on both are ~1.25V. Then with the card off, measure the resistance from the ref pin to the EDIT: ANODE! pin. It should be a steady value less than 1k ohms.
    To mod it connect a multiturn 10K or so pot between pins 8 and 2/3.
    Chip 5 controls the VGPU (due to the many caps around the MOSFET) and chip 2 probably controls the DDR voltage, but I don't know about VDDQ. It may just be powered from the 3.3V line.
    I would hold off modding chip 5, do 2 first and see if the core speed increases.
    Apr 2004
    Germany
    I hope you still wanna help me .....
    I measured the voltages and the resistance of both chips:
    No 5: 2.50 V and 0.097 kOhms.
    No 2: 2.50 V and 1.074 kOhms.
    I measured between pin 8 and 2 or 3 .. always the same values.
    So i need to connect the 10k multiturn between pins 8 and 2 or 8 and 3??? Or between 8 and 2 and 3???
    Jun 2003
    Portugal, Lisbon
    Any news on this mod...???
    I will try do the same on a asus v6800DDR.
    Thks in advance!
    "God...i know she's dead :'( but keep her soul alive because in my heart she will never die :'(" VoRtAn_MaDgE
    Nc te eskecerei avó! :'(
    c[_]
    Nov 2002
    Alberta, Canada
    I just bridged the mosfets with wire.. 3.38v core and 4.0v mem
    Mine isnt the deluxe model though, and only came with 2.0v on the core stock according to mosfet left of capactors in pics.
    All along the watchtower the watchmen watch the eternal return.
    Apr 2004
    Germany
    Which pins you used? 8 and 2 or 8 and 3, or both of them?
    Apr 2004
    Germany
    I didn't find any solution yet that is working... is there someone who can help me?
    Apr 2004
    Sweden
    has anybody got a guide to modding the winfast leadtek geforce DDR? Looks almost like the same card
    AMD Turion MT34 @ 250*9=2250MHz 24/7
    ATI X800PRO
    MSI K8NM FISR BIOS Rev 1.5 My first BIOS modification
    2x80GB Maxtor drives @ RAID-0
    1x160GB Seagate
    Everything in a mATX case.
    Sep 2004
    Sweden
    I have mod chip 2, the card start but I don't know were the monitoring point is, one of the caps? If the mod dosen't work I probably ingrease the 3.3v rail and see if that help. Or mod chip 5.
    Sorry for my english
