Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Strange a64 3200 problem
    Mar 2004
    Had this system for a while
    a64 3200
    kingston pc 3000 (bh5)
    9800se softmodded
    gigabyte k8n non pro
    but it would never overclock very well, could get 2319mhz 3dbenchable but that was it. Today I got a new psu, tagan 480w which is meant to be very good. Rails are all fine.
    If i use the 9.0x multi i can do 261htt 213 mem and it runs 3dmark fine. But if I use 10.0x i cannot bench 2340 (234 htt)
    Also running 1:1 I cannot go above 225. This may be a ram limitation, i have no voltmods but i thought 225 would be attainable with 2.8v.
    Temps are fine 44C load @ 1.7v.
    Also (but less important) even using 2x htt I cannot go above 280mhz at all, I have read about people getting well over 300 at 2x.
    Can anyone help?
    Thanks L
    Mar 2003
    Denmark
    I´f you´re using the s-ata controller there´s your answer
    "M-I-A"
    Mar 2004
    No sata on the k8n non pro, I have nothing in my pci slots either. I do have a maxtor 40gb hdd and a WD 80 gb hdd connected.
    Jan 2003
    Molde, Norway
    I got the answer for you dude its your mobo and memory they are making a conflict, use CAS2.5 if you run 1:1 .. i got the same problem .. hf
    A64 3200 @ x - Gigiabyte K8N modded - HyperX PC3000 - Radeon 9800PRO modded - Enermax 350 modded - Vapochill BD35F r404a modded
    Mar 2004
    ok thanks m8 will give that a try,
    Jan 2003
    Molde, Norway
    yes do that, give me your result..
    Mar 2004
    Ok it passed prime 95 at 220 1:1 for 30 mins, thats easily stable enough for benching. However, if i try and use cas 2.5 and any ratio other than 1:1 the computer resets. A little strange.
    225 is completely unstable for prime but might be ok for 3dmark however i need it to go to 234 to make running 1:1 worthwhile. Im guessing this will need the vdimm modd.
    Mar 2004
    I will buy un sata hitachi 7k250 160go for my A64
    It's a problem for o/c ?
    Futur : AN50R, 3000 or 3200 core CG, 9800pro HIS IceQ, fortron 350W ; zalman 7000A AlCu
    Mar 2004
    I think i have solved another problem, by flashing back to bios f9 i can raise the htt much higher and it doesnt lock up. 293 has crashed in 3dmark however
    will keep trying.
    update: actually no it didnt help in fact is has made it worse! Cant run 9x261 any more it freezes in 3dmark, nothing has changed except the bios. I will keep trying!
    Xtreme 3DMark Addict
    Sep 2003
    you dont have pci locks, also high fsb is very hard on your mobo's northbridge. I doubt my nf7-s will do past 260fsb, thats amazing you are getting near 300MHz. you could do the vdimm mod but beware, the ondie memory controller does not have the high volt tolerance which the ram does. maybe get pc3700? it runs cas 2.5 so its not bad and you should do 240-250fsb with that ram
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    Jan 2003
    Molde, Norway
    the sata controller dont like high PCI mhz
    Mar 2003
    Denmark
    no you should be able to reach 250- 290
    buy a promise 66PCI and you´ll be on your way towards 400
    "M-I-A"
    Mar 2003
    Denmark
    Okay why is it hard on the NB
    Naa 300 isnt amazing at all G8 but not amazing
    "M-I-A"
    Mar 2004
    I have a An50r
    normall, pci/agp are fix?
    Mar 2003
    Denmark
    no the PCI is not locked... AGP is though
    "M-I-A"
    Jun 2003
    Norway
    At first i thoght you had mistaken the mobo for a nForce2 mobo, then you start talking about the on-die memory controller which indicates that you are aware of it beeing a nForce3 mobo for a A64.
    The nForce3 hasn´t got a northbridge dude
    Also, you can not compare running high FSB on a nForce2 with running high FSB(HTT) on a nForce3. Most nForce3 mobos will do 300+ FSB unmodded as there is no NB to hold you back.
    About running high vdimm i would say 3.2 is fairly safe. I have been running 3.4-3.6 the last couple of months, and everyting is working fine.
    Mar 2004
    Mine won't do 300 htt
  18. #18
    Jun 2003
    Norway
    It might be your diskdrive holding you back. When aporaching 45-50Mhz PCI speed many HD´s crap out. I hear seagate can take very high PCI-bus, and WD is not to bad either. Both my WD30BB and WD120JB are happy with 320+ FSB.
    Try another HD if you have one.. it might do the trick.
    GL
  19. #19
    Mar 2004
    I have a wd drive atm, also have a moxtor connected, i will try disconnecting that and let you kbow how i get on.
    Also which bios is best for this? I tried f9 and it didnt oc as well but it might just have been a bad night, if others have had more success i can give it another try.
  20. #20
    Worst overclocker evar!!
    Oct 2003
    Harrisburg, PA
    With SATA drives connected i can run 245, but that's about it... without them over 330.
    I used to have links here demonstrating how awesome I am, but it's been so long that they're not very relevant (and the pictures have disappeared), so I guess I'll have to get working on new stuff.
  21. #21
    Mar 2004
    Nope disconnected the maxtor, 290htt windows crashed and after it wouldnt detect any drives till i left it off for 10 minutes
  22. #22
    Aug 2002
    there's no NB on any AMD64 mobo
    You need either a PCI RAID card or Seagate Barracuda IV harddrive. The highest i could get out of Gigabyte mobo was 360fsb running 2x LDT with Speculative TLB Reloads Disabled in bios.
  23. #23
    Sep 2002
    Qld, Australia
    Clockgen locks the PCI up. I could get to 225 on my K8NNXP, but using clockgen SATA works at 260 easily.
    A64 3700+ @ 3105/258 1.85v VapoLS
    K8NNXP 12c bios K8Npro
    2 x 256 Twinx 3200LL 2-2-2-6 3.4v
    Albatron 6800GT VapoPE cooled
  24. #24
    Mar 2004
    i don't have pci cart
    i buy now a DDR mémory Geil pc 3700 cas 2 3 3 7
    Wait and see for me !
  25. #25
    Mar 2004
    what does this actually do?
