how high can they go?
How much volts can they take?
at 3.34v Vmem 1.63v Vtt
250 2-2-2-5 1:1(on air right now.)
Is 3.34v safe for 24/7
I whould say 3.6V safe for 24/7 w/ resonnable cooling....
And do you have the 250FSB wall?
I don't think there is a wall. 250 is 3.5ghz i think my max on stock air.
But I've heard that sometimes they even go to 270FSB.
I just hope I dont have that wall on mine.....
I didn't even know it's possible for ch-5 to do 250 at 2-2-2-5...
my XMS3200LL did do 240.
NFII Infinity A __ XP-M 2500+ IQYHA __ 3500EB 2x512 __ XFX 6600GT __ WinXP Pro SP2
My Heatware
My CH-5 CANNOT do 2-2-2 timings. Even @ 2.9V it doesn't do 200 FSB.
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
Actually ivan with the newer batches of CH-5 Thats no longer true. Theres a couple screenshots of 2-2-2 at something like 230. It takes a lot of voltage though, something like 3.3 or more.
Edit, sorry didn't notice the my at the start of your sentence.
-Phenom2 x6 1055 @stock
-8gb ddr3
-Gigabyte UD3
-Geforce 7900Gt 755/1863 1.562v vgpu
-OCZ Powersupply 600w
over 3.3v 1.6v for me and then they started doing something. ps holding me back now. can only go to 3.36v under load.
I have some noname CH5![]()
(Ithink i have a 250fsb 1-1 wall
It runs 3D01/03/Spi/Hexus @ 249fsb 1-1 5-2-2-2 (3.3v)![]()
But @ 250fsb 1-1 5-2-2-2 i get HD corruption
Also does 283fsb @ 5/4 >5-2-2-2 (3.3v)![]()
245fsb 1-1 5-2-2-2 >pc3200
V's
260FSB 1-1 5-4-3-2 >pc4000
5-2-2-2 @ 15fsb less won in everytest i ran:smileysex
Conroe Q6600
Asus P5W DH Deluxe
Asus 8800GTS 512mb
4x1 gig SuperTalent 6400
All Air Cooling
you need more Vtt and or Vmem and maybe Vdd.
wow I need to get some of that ch5 ram thatll own bh5! mine isnt too bad, 220fsb at 2-2-3-11 at 3 volts(cant go lower, dont want to reverse the mod) I can do up to 3.25v on my nf7-s whats the odds of me getting some corsair value for 240+ fsb at 2-2-2-11 dual channel goodness?
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!![]()
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
it will never own BH-5. Didn't you know that BH-5 can do 290fsb+ at 2-2-2-5-9-16 and 3.5-3.7V?wow I need to get some of that ch5 ram thatll own bh5!![]()
stestan: The wall is that it CANT pass 250FSB not MHz. ex: Like that they cant do 250FSB at 185MHz....
But my CH5 are new and can do AT LEAST 236MHz, 2-2-2-6, 3.2V
But I dunno about the wall(CPU was maxed out). Now I have my 2.4C M0 and vid card so I can test it in 2-3 days....
skate, the 250 FSB "wall" is only on intel systems![]()
But stestan is an Intel![]()
but Illicit Tweakin isnt![]()
I think theyres no XP CH5 wall coze they cant go up to 250FSB![]()
Here is my Ch-5
It was bought in early 2003, think the date is 0309.
This is at 3.2v and in my dfi.
I do seem to have a 250 wall.
i dont think all BH-5 will. my Corsair has a hard time staying at 260 with 3.6v.Originally posted by QuadDamage
it will never own BH-5. Didn't you know that BH-5 can do 290fsb+ at 2-2-2-5-9-16 and 3.5-3.7V?![]()
that stick of 3200LL CH-5 i had seemed to perform almost the same as the 3500C2 BH-5 stuff i got now. both take about 2.8/9v to get to 220 tight, 3.1v for 230 and 3.3v for 240. i didnt have any Vmods with the CH-5 though. it may have done 250 with some more volts.
My Heatware
Mine are 03/11. And I think the CH5's can pass the wall w/ alot of volts....
ive seen people run 3.6-3.75 on these forumsOriginally posted by Illicit Tweakin
dunno if thye use active cooling lol
freind of mine had them running pretty nice on 3.4v, and then woke up one day....DEAD. CH-5 cannot handle voltage as well as BH-5. just remember that and be careful unless you could care less![]()
[17:03] Geoff- In Tech: "Oh, I know..and you are a suitable weenie for that."
I am now just haven't changed sigOriginally posted by enzoR
but Illicit Tweakin isnt (on intel)
I've got some CH5 that did 240 11-2-2-2 @ 3.3v
I didn't try further...
I now have a locked Barton that won't "even" do 11.5x240lol
I hit the wall with the cpu @ 11.5x229
Anyway, now running the memory 24/7 @ 3.3vno problems whatsoever
lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
*phone rings*
Friend: Do you have a spare PSU lying around?
Me: No why?
Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
Me: what PSU was that again?
Friend: Antec 480w
Me:........
