Results 1 to 16 of 16
Thread: AT7 Max2 & KD7 info.......must read
    Sep 2002
    Someone posted over at Amdmb.com about the issues with Abits new KT400 boards.
    http://www.amdforums.com/showthread.php?threadid=158656
    We can all sleep better know.
    Asus P5W64WSPro/Xeon 3060 SS 9x467/TeamXtreem 667 2GB/Patriot PC28000XBL 1GB/Sapphire X1800XT/w PE bios/OCZ PowerStream 520w/150gb Raptor/CPU cooled by AquaXtreme MP-05 Pro Limited Edition, BI GTX 240/MCPSwiftech655/Masterkleer 7/16IN
    Xtreme Mentor
    Jun 2002
    New bios works. No 1/6, but at least you can post at 200+fsb now.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    Sep 2002
    Israel
    Not really, if it's made by ECS we can't sleep at all
    "There is no hunting like the hunting of man and those who have hunted armed man long enough and liked it, never really care for anything else thereafter."
    - Ernest Hamingway
    Xtreme Mentor
    Jun 2002
    214fsb now.
    Sep 2002
    Want ram are you running? Any Sandra shots for us.
    Xtreme Mentor
    Jun 2002
    Sandra is 3040. you would think it would be higher at 214 2.5-2-2-6-1T 4way, dram enhance, but still not bad considering cpu fast decode is off. The person that posted the bios said that cpu fast decode couldn't run aboev 166. Seems a bit low for that limitation.
    I'm running twinmos 512mb ddr400 with -5 winbond afetr a long burn-in. Still has room to go, but I'm afraid of drive data loss without a 1/6th. the good thing is not one bit of bios tearing that was so common above 200 on the epox and some on the KX7 as well.
    I tried to put the second stick in but it wouldn't boot into windows with 2 sticks, so 1 512 is it.
    edit: I also backed it down to 2T because it wouldn't complete 3dmark or Prime, but it does at 2T.
    Sep 2002
    For the hell of it try the serial ata. I know your transfer rate is limited by your hdd but maybe it copes with the higer FSB speeds and data corruption.
    Xtreme Mentor
    Jun 2002
    I have 3 drives and they only give you one sata cable, so I could try the Raid connectors for 2 and the sata for one and the cdrw's on the regular ides's . Do you think that would help?
    Aug 2002
    London,Uk
    well finally after 7 hour rebuild of comp, unlocking t-bred, relapping waterblock, cleaning out every compontent(very dusty), re-arranging everything to chuck in new raid array. etc etc. Oh and spiral wrapped every single wire in here(long!).
    ANyway, got my old maxtor and chucked it on the serialle thing to see if it works. Makes lamost no difference, need to test it with proper bench before i decide though. I think the score is slightly higher TBH, but that's probably down to the vlink8x giving better bandwidth to the hard drive.
    But anyway, it works well and saved a little cable trouble.
    At the mo i can't get it to overclock well at all, gonna try the new bios in the next hour or so. Hoprfully will give me some good fsb overclocks.
    I'll update if and when i have anything useful to say, but i have serious doubts about this board already.
    Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
    Xtreme Mentor
    Jun 2002
    The board is broken without the new bios. Try it and see. World of difference.
    Aug 2002
    London,Uk
    where did you download it from , amdmb?? i got it but its a .boo file not .bin which i assumed it would be. Is that the same one you used?
    DO all abits bios's come in that form??
    Also did your onboard sound install properly(assuming you use it) and same goes for the software and the hardware monitering software. My sound won't work, i get a Code 10 reason for it not starting up, whatever that is(says that in device manager.
    the hardware stuff jsut won't install from cd, corrupt files, just wondering if all the cds they sent out were as bad.
    Aug 2002
    London,Uk
    OH and am i being really dense or is there no agp 8x option, how can i check what agp speed i'm running at? I cant' tell at all. Also with the 2.3cat drivers the control panel is borked and won't show agp speed correctly.
    Sep 2002
    Hey guys couldn't resist the new bios. Unpacked her and away we went.
    Heres's some memory benches to look at.http://www.amdforums.com/showthread.php?threadid=158968
    Xtreme Mentor
    Jun 2002
    You can rename the bios to .bin. I'm not using on board sound.
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    So buying these boards..... are they worth it or not? Basically they're volt-modded KX7-333s.... that's what it's turning out to be.
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
    Xtreme Recruit
    Jun 2002
    Seattle, WA
    Seems to be that way...
    Without that 1/6 divider...*sigh*...picked a refurb kx7-333r up today from newegg for 60 bucks shipped. Patience only stretches so thin, and I've read enough about the KD7 to stay away for a while.
    T-bred B 2100+ @ 200x12.5 Aircooled
    Abit NF7-S 1.2 @ 1.85v/1.7vdd/2.9vdimm
    2x256 Corsair PC3200 2/4/2/2
    1 80gb WD HD (8mb)
    2 120gb WD HD (Raid 0...thank you Abit!)
    Leadtek Ti4400 @ 318/697
    Pioneer 16x Dvd
    Optorite DD0203
    To be considered a country, you need to have a beer. Sure, it helps to have an airport, or nuclear weapons, but at the very least, you need a beer.
