I have a Antec 550W Truepower, i noticed it has the sence line running to one orange (3.3) wire, One red (5v) and one yellow..12v
Dose that mean i can just connect my 20k pots to them to pod all my rails?
how do i do it?
how do i do it?
No, for the Antec you have to solder a fixed resistor inline first.
Grab either some 47ohm or 60ohm fixed resistors (or any value close to that), then snip the sense lines where you want to. Cut out about a good inch or so out of the sense wires after you snipped them...be careful not to take out to much. Then solder a fixed resistor between the cut lines. Now, add a wire to the top of the fixed resistors leg...that wire will go to the middle leg of you 20k VR. The top leg of the VR should have a wire that is going to whatever ground you are wanting to use. You dont use the bottom leg of the VR period...just snip it off to be safe.
Be sure to set each VR to the max resistance before soldering it on. That is a very important step. And, you can use 10K Vrs here as well....and most likely 5k would be fine also...but use whatever you want.
Just do that for each sense line and you are in business.
Dont forget the Search link at the top of each forum as there is a wealth of info here.
Here is a thread with pics of mods on the exact power supply you are asking about.
I like my women the way I like my processors...naked.
I am not the HellFire that writes bios files. I work strictly on voltage modifications.
Hell-Fire,
Just wanted to check wit ya on what you set the VR's to before doing the soldering for the 550w Antec mod...
I know I can look up the original Antec PSU mod thread but I thought I'd ask you here as I'm hoping for a quicker response...
I've lost all my write-ups for my old 550w TP & can't remember what to set the VR to before doing the mod...Especially for the 3.3v rail...
I remember setting it to something like 220ohms & then doing the soldering, am I right??
If you can spare the time, please let me know what your VR's were set to for each of the mods...
Set all VR to max resistance & then adjust/lower the resistance right??
I got meself a replacement 550w TP to do the mods & have totally forgotten the mod...silly me
TIA,
Minnyboy![]()
Cheers,
Minh
Mine:3770k @ 4.6Ghz @1.25v, Corsair H80, Asus SabreTooth Z77, 4 x 4GB Corsair Vengeance 1600C8, XFX 7870DD, Corsair HX850w, Sandisk 240GB Extreme SSD, Corsair Graphite 600T
Kids: 2500k @ 4.6Ghz @1.368v, TRUE120, 2 x 4Gb Corsair Vengeance 1600C9, Gigabyte Z68X-UD4-B3, Gigabyte HD6870, Sandisk 240GB Extreme SSD, 850w Thermaltake 850w PSU, Antec P182 Case
Kids2: i3 3225, 2 x 4Gb Kingston HyperX 1600C9, ASUS P8Z68-M PRO, Sapphire HD4870 1GB, 128GB Samsung 830 SSD
Server: Core2Quad 9450, 2 x 2Gb Kingston HyperX 1066, 2 x 2Gb Corsair XMS1066, Gigabyte EP45-DS5, Corsair HX650w, OCZ 120GB Vertex 2E SSD, WD 1TB Black, 2TB Seagate 5900rpm, 2TB Seagate 7200rpm
Yeh, you are on the right track pretty much.
Set all the VRs to max resistance before soldering then into the loop is the standard practice. You can of course set them to any value you choose, but that may keep the psu from powering on due to overcurrent protection kicking in.
Correct, lowering resistance will increase the voltage across that power rail.
