----------!!!!!!!!!!!!!!!Bios settings!!!!!!!!!!!!!!!---------------------------
(Standard Cmos)
Acces mode: auto (på hddn)
(Advanced bios features)
APIC mode:Enabled
Delay for hdd:0
(Advanced chipset features)
Expert
Aggressive
Expert
11
2(2 if you have bh5 sticks)
2.0(2.0 if you have bh5 sticks)
9(13 most stability )
12(15 most stability)
Enabled
Enabled
Fast
Enabled(Disabled if you have ds sticks"512 mb sticks")
---Alpha settings"Fastest and highest fsb"--------
T(DOE):1 (Maybe 2)
T(RRD):3
T(W2P):3
T(W2R):3
T(REXT):3
T(R2P):3
T(R2W):4
Auto
128-256Mb
Enabled
Enabled
Disabled
(Pc Health Status)
Disabled(If you have cooling for lower temp then -0c)
(Genie bios settings)
Disabled
200Mhz t.ex
Auto
x10 t.ex
1/1(Use only 1/1 if you don´t wana kill the bios chip)
1.850v
Auto
1.70v
3.00v-3.30v
Disabled
---------------------Best os+drivers+Tweaks"more will be added"-----
Os:Win2K
NF2 Drivers:Morpeus Remix Extreme video driverset
Gfx drivers:Cat 3.2"If you have R9800Pro"
"Bios settings info":
http://www.rojakpot.com/default.aspx?location=9
---------------------Link to bios "BETA"---------------------------------------
LANPARTY NFII ULTRA B 2004/1/21 BETA BIOS
http://myweb.hinet.net/home8/oskarwu...s/N24LD121.zip
NFII ULTRA INFINITY 2004/1/21 BETA BIOS
http://myweb.hinet.net/home8/oskarwu...s/N24ID121.zip
LANPARTY NFII ULTRA B 2004/1/31 BETA BIOS
http://myweb.hinet.net/home8/oskarwu...s/N24LD131.zip
NFII ULTRA INFINITY 2004/1/31 BETA BIOS
http://myweb.hinet.net/home8/oskarwu...s/N24ID131.zip
---Links to alpha bios"Try this only if you have money to a new board"--
Use 1-31 or 1-21 bios first....Sett up your best settings..vcore and all another settings...Save it in the bios"bakup settings" . Make @ stock settings and flash to alpha 2-17.D01 . Load saved settings..from 1-31 bios...the board will maybe not post after that..press reset button and the board will post...know you cane change settings in bios "it worked for me but i don´t know if it works for you"
LANPARTY NFII ULTRA B 2004/2/17 ALPHA BIOS
http://myweb.hinet.net/home8/oskarwu...4LD217.b01.zip
http://myweb.hinet.net/home8/oskarwu...4LD217.b02.zip
NFII ULTRA INFINITY 2004/2/17 ALPHA BIOS
http://myweb.hinet.net/home8/oskarwu...4ID217.b01.zip
http://myweb.hinet.net/home8/oskarwu...4ID217.b02.zip
----------------------------NF2 Drivers-----------------------------------------
http://www.techconnect.ws/modules.ph...ds&cid=1&99239
"Morpeus Remix Extreme video driverset"
Are best for me.
------------------------------MODDS!-------------------------------------------
------------------------------V MODDS-----------------------------------------
Vcore modd!
Vdimm and Vdd modd! , "VAGP,VDIMM,VDD" there cane you see the real v for "VAGP,VDIMM,VDD"
Sb Vdd modd!
vcore drop+vcore overcurrent modds will be added soon.
-----------------------------CAP MODD----------------------------------------
Cap modds..i don´t know if they will help you to get higher fsb..but i use them 24/7 and in max fsb clocks.
----------------------------MOSFETT COOLING AND MORE------------------
I know my english is not so good but..you get nice info from me so why complain, I only want to help you to modd this board and more..Info is good
, And help is good
If you need help ask me then..maybe i cane help you![]()
