Page 1 of 3 123 LastLast
Results 1 to 25 of 54
Thread: Geil PC3500 4.5ns Platinium
    Sep 2002
    NY
    Has anyone tried This?
    http://www.ocsystem.com/oc51pc43ddrs.html
    No doubt this is the fastest DDR memory available!
    GeIL is leading the way toward superior performance DRAMs, representing the fastest and most advanced DRAMs available on the PC market today. Innovating on the existing solid position among the world's top DRAM suppliers, our customer base is expanding beyond the top businesses of performance computing and consumer PC's around the world.
    GeIL PC3500 433MHz DDR is the first memory in the industry surpasses 400MHz DDR barrier!
    Tin Coated Copper Heat Spreader
    GeIL GL2000 4.5ns Chips
    CL 2.5 6-3-3 2T Timings
    CL 2 6-3-3 1T @ DDR400 PC3200
    433(217)MHz
    184 Pin Dimm
    6 layer ultra low noise PCB
    GeILmanufacturer direct, hand picked chips
    Royd
    Jun 2002
    Garanteed commerically available DDR yes, fastest DDR to date, no. Until one of the regulars here, or a review shows up, Winbond 5ns Rev B holds the crown
    Not that its much use being faster then 220mhz on an AMD system
    Set me free.
    A64 3200 @ 2250mhz (10x225 @ 1.6v) | Chaintech ZNF3-150 | 2x 256mb Corsair 3200LL TwinX @ 2.5-2-2-7-12-16 | 256mb Albatron 5950 VIVO | 80gb DiamondMax 9 | Pioneer 106 | APC 2200RMI3U UPS
    Aug 2002
    Belgium
    I might want to inform you that the new Mushkin PC2700 Level 2 rated cl2 2-5-2 1T is even better than the Winbond 5ns in my AMD rig
    Banned
    Jul 2002
    what chips are mushkin using in there pc2700 ram? more than likly samsung CTL chips right?
    Aug 2002
    Belgium
    I have absolutly no idea, I know their Level2 is brand spanking new. I have a stick it performs great (much better then their PC3200) And i don't want to screw it up by getting those heatspreaders of.
    Mushkin makes its own PCB for shure, don't know about the chips.
    Doubt that it's samsung.
    Heck I don't care, But it beats a original Samsung stick with CTL chips I had. Wich was beaten by Winbond 5ns and now that Winbond gets it from the Mushkin. Not by much but it beats it
    In the quest for optimal performance every mhz @Max. timings and settings makes a differance on an AMD rig
    Xtreme Relic
    Jun 2002
    Hilton Head, S.C.
    And I just ordered a stick of xtreme corsair 3200 cas2
    Banned
    Jul 2002
    I can vouch and say the pc3200c2 corsair rocks hitting 207mhz at 2,2,2,5,1 with enhanced and fast decode on my rig tho it needs 3.05v but it still rocks. But for me anything over 190mhz at fastest settings is a work of art :p ..
    Aug 2002
    Belgium
    Corsair C2 did between Samsung and Winbond 5ns on my rig.
    Jun 2002
    That sucks arse. Of the 4 TwinMOS sticks i had shipped to me, all did 215 aggressive settings @ 2.85v, and three of them did 220.
    Entuscan, My CTL samsung did 2-4-2-5-2-1CMD rate-Fast CPU Decode up to 195mhz. What Mushkin has is nothing new.
    Xtreme Mentor
    Jun 2002
    PA, USA
    I take it twinmos is not available in the US?
    E8600. EP45-UD3P. 500FSB 24/7. Still WinXP. Heatware
    Banned
    Jul 2002
    215 at 2.85v at 2,2,2,5,1 4way 4q using fast decode and enhanced on the kx7-333 or at7?? Ok if ya say so you must get the best PC parts in the whole world
    Aug 2002
    Belgium
    Wel overhere Samsung did 198 with most agressive timings
    The Mushkin does better at 202 In my Old KR7A with only a /4 divider
    Samsung did 198, Corsair C2 did 200, Winbond 5ns 201 and Mushkin 202
    But my board is getting maxed out with only a /4 divider
    That PC2700 rated 222 from mushkin is deffintly new (about 2weeks out) But don't know about the chips on it, can't say due to heatspreader.
    Xtreme Relic
    Jun 2002
    Hilton Head, S.C.
    Thanks guys,
    Looks like the Corsair XMS3200cas2 I just ordered will be ok on my heavily modded Abit KX7 then. If I hit at least 200FSB with tight timings..I will be happy!
    Xtreme X.I.P.
    Jun 2002
    Denmark
    Hi Dude
    I have tried Corsair cas2 v 2.1 for some time. It goes 226 cas 2.5/7/3/3 on my IT7 at 2.8 V
    On AT7 it can go fastest settings over 200
    You can take the alu of, an put some cobberheatsink with eproxy-silver on. Then it can go 228 cas 2.5/6/2/3 at 2.9V
    Sometimes I bench, to follow OPP then It goes 230-232. But after 10-15 min it becomes unstable (to hot)
    Corsair3200 v 2.1 don't like so high volt as the old Corsair3200 v 1.1
    Best OC regards
    Tom Holck
    Denmark
    Sep 2002
    Israel
    OT... is the new WinBond 5ns are 0.13 micron?
    "There is no hunting like the hunting of man and those who have hunted armed man long enough and liked it, never really care for anything else thereafter."
    - Ernest Hamingway
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Hey guys...you really do belive that GEIL Memory can do this.....If you do believe it then go and buy it....
    This is a 512Mb Corsair XMS3200 C2 at 253MHz(506MHz DDR) with Cas 2,5 - 2 - 3 -7 T2....
    INTEL PWA FOR EVER
    Dr. Who my arss...
    Sep 2002
    Los Angeles
    Ahh you guys seem to know alot, Just a question which memory will do 200 Mhz/ 400 FSB at cl 2.0-2-2 t1 and should I get 512 mb in one stick or 2X 256 mb for that FSB? Right now I'm going to buy it and stick it in my dragon + but for the future investment in a few weeks if the MB guys get off their a**es, xp 2600 at 2200 mhz @ 200/400mhz fsb with a nice little pci/6 divider just need a board where /6 works! Let me know ok
    terramir
    terra= (lat.)world mir=(russ.) peace
    BTW that girl is my version of muddflap on my stacy common artwork not obcene (for the censors out there)
  18. #18
    Aug 2002
    Belgium
    Mushkin PC2700 level2 Rated 2-5-2 running @3.2V should do the trick. Corsair XMS3200 CL2 can do to
  19. #19
    Sep 2002
    Los Angeles
    What about the geil 3500 Platinum?
    It's rated 4.5 ns and pc 3500 with that I should be able to at least reach cl 2.0 -3-3 t1cmd. @ 200/400 fsb
    These chips are rated 2.6 to 3V and right now before I upgrade to my new bed which won't be until these guys get off their butts with the /6 multiplier and a good kt 400 baord coming out, will this memory work at 2.48 V 133 to 150 Mhz CL 2.0-2-2 t1 on my soyo dragon plus? also One more question one 512 mb stick or two 256 mb sticks that is here the question(s).
    terramir
  20. #20
    Aug 2002
    Athens---Hellas
    terramir
    I think this one is good for you.....512Mb Corsair XMS3200 C2 at 227MHz(454MHz DDR) at Cas 2 - 2 - 2 - 7......
    INTEL PWA FOR EVER
    Dr. Who my arss...
  21. #21
    Xtreme X.I.P.
    Jun 2002
    Denmark
    Hi Hipro5
    Your tweaking of the corsair are great...
    what volt do you rekommend.
    have you special cooling on the ram?
    Best OC regards
    Tom Holck
    Denmark
  22. #22
    Aug 2002
    Athens---Hellas
    Re: Hi Hipro5
    Best OC regards
    Tom Holck
    Denmark
    The maximum Vmem can hold(I'm talking about Corsair XMS3200 C2 only),is about 3,4Vmem....I recoment the 3,2Vmem(after of caurse of a lot burn-in) to stabilize it and for falsefree working....
    You can't give it more that 2.9Vmem or 2.8Vmem(depents on every Mobo) unlles you Mod your Mobo....
    I do have special cooling of the ram cause I had almost 43C temp on the heatsinks of it.....
    INTEL PWA FOR EVER
    Dr. Who my arss...
  23. #23
    Banned
    Jul 2002
    hipro I just noticed your sig states you run your memory at 250mhz i just want to bring to your attention about false advertisement. first a 2.8ghz AMD cpu now this... come on come clear tell the truth, lol.. J/K very,very nice does that mobo have the option to go to higher fsb or memory speeds with future modules??
  24. #24
    Aug 2002
    Athens---Hellas
    This Mobo I use , has fsb to chose till 400MHz......In fact had worked(to me) Max 227MHz......
    INTEL PWA FOR EVER
    Dr. Who my arss...
  25. #25
    Sep 2002
    Norfolk, England
    lets get back to the subject, im very intersted in getting some of this Geil PC3500 4.5ns Platinium ram but does any one know what chips it uses and how good it is?
