Results 1 to 16 of 16
Thread: My cascade.... MK7
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    Talking My cascade.... MK7
    Hello
    What can i say, she's finnaly made. Maybe a short story...
    I started making her @ 11.06.2003 (9 months ago), and was supposed to be a quick project made out of a A/C unit and my thrusty Danfoss SC10b. Well, the A/C leaked on the condenser. Later came the "mk2" part where the condenser was changed with the old A/C's evaporator, also a bummer (leaks). At that time i made a preety nice heat exchanger, made of 16m 8mm OD pipe and 16m 5mm od pipe, soldered by their sides.
    Later i started making the "tower" version, after i got a Tecumesh RK5510 a/c compressor in my hands. After a first failed revision i decided to water cool the condenser, the system was supposed to be dual head and everything was supposed to be nice. It even didnt leak... well, than i had to change the oil in the compressors. The system was completelly disasembled, it took me a while to drain the oil from the compressors.
    Now it was some time for miniaturisation, the MK5. It was supposed to be a small system, fitted inside a 50x30x50cm box, dual stage compressing in the II stage. Then my bad luck reached its top: a brand new condenser leaked like hell. After that i had a lil depression and wanted to throw that project away, during that time i made a gas turbine (jet engine) beacause i didnt know what to do with myself. After some time i was ready to start the project again.
    The MK6 was almost a succes. Dual stage compressing worked ok, non of the compressors overheated, the injector worked flavlessly, the vacuum inside the evaporator was huge. As i said it ALMOST worked... the oil separators didnt work.
    And now... finally after so much pain and misery comes the MK7...
    Theres no insulation on the II stage yet, exept that everything is finished. The 2nd pic is a little outdated near the 2nd stage compressor (in the II stage) beacause the oil separators outlet leads directly to the accumulator.
    But from the begening, the I stage:
    How does the whole I stage look like...
    The I stage compressor.
    The condenser and fan assembly comes for my almost first refrigeration system wich i bought as a water chiller.
    The filter is preety oversized but it also serves a accumulator purpose during startup
    The hx is made of 16m 5mm OD pipe and 16m 8mm OD pipe... soldered together by their sides..
    View on the filter + txv assembly
    The suction line on the I stage....
    The TXV is a ALCO TIHW, for R22, no mop..
    Ok, now the II stage.
    Lets start with the 1st stage compressor:
    You can see the interstage deasuperheater and the SC10B...
    Its oil separator
    A sideshot
    Now, the 2nd stage compression:
    The assembly...
    Its oil filter
    And now, the evaporator:
    The parts the evaporator consists of
    The base
    How its fitted
    Almost made:
    The injector assembly...
    A hole for the temp probe
    And after brazing:
    Any comments needed ?
    I use a almost identical evaporator in my friends system and works PERFECTLY!! So far its the best one i ever made/used, its only limitation is the way it can be mounted (only 3 possible positions)
    Temps... Cant really tell the temps right now, i only tested it with R22. A cascade, with a 5psi condensing pressure, dual stage compressing is "a bit" of a overkill. To see what happens with higher head pressures i filled the system with some argon. The suction pressures remained exacly the same (about 20-22hg), the middle section pressures increased slightly (from a preety deep vacuum to a little less deep) and a 20 bar head pressure... The injector still throtelled properly @ 5V (nominal)....
    Further tests this week with R23....
    berkut
    ***edit*** changed the server, pics should work
    Dec 2003
    gona leave it for the night to load the pics ^_^, looking great so far
    Jan 2003
    Dayton Ohio
    OMFG i cant wait for the pic. I think something is wrong with them, it just never stoppes loading. If i had more than 5mb of space i would host them. Anyone have some free space?
    EDIT is spoke too soon. Looks amazing for a first time job by an 18 year old lol
    Temps?
    Xtreme Legend
    Nov 2002
    Sweden
    The images are on the heavy side.
    You should be able to reduce them to 1/10th of the size using ImageReady, or something similar. Just a tip.
    Looking really good BTW!
    "In mild doses, ethylene produces states of euphoria, associated with stimulus
    to the pleasure centres of the human brain."
    Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
    Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
    Nov 2003
    Br!ban3 / Aus / State: St0n3d
    Lol good untill the second stage images §§§§d up.
    Ripping it up on old technology
    i4memory.com
    Xtreme Recruit
    Nov 2003
    Nice work
    Abit IC7-Max3
    P4 3.0C @ 4.0Ghz
    Corsair TwinX-Pro 3200(1GB)
    Radeon 9800XT
    2 Raptors in RAID-0
    160GB SATA
    Mach I
    Oct 2003
    The Netherlands
    Can't view all the images. Please resize 'em
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    The pics should work now preety fast
    Oct 2003
    The Netherlands
    Indeed, now I can see them all. Damn man, this looks more like a complete chemical plant than a cascade...
    But pictures are always less clear than a real 3D view. My finished cascade also looks more like chemical plant on photo than in reality.
    You're also brazing the stainless hose now?
    How did you cap the MAPP bottle you're now using as oil sep?
    One remark: the way you hooked up the temp sensors will give you an inaccurate reading. Use thermal paste, wrap with a piece of aluminium(foil), then insulate.
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    I always brazed it
    I drilled out the safety valve, and the acces valve, sealed shut the safety valve and brazed everything up nicelly...
    Damn i need R23 right now...
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    Load tests.... of course treat all the frost as the heatload... Gary please dont die
    Ill give you the temps + pressures on the I stage in a moment.
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    I use thermal paste
    Yes, i will insulate it in a moment when taking measurements for Gary
    Nov 2003
    Loooka mada, whats that things on the evap?
    i4memory.com
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    what gas is in you'r 2nd stage ...and what is the evap temp's for 2nd stage.
    R22 currently... didnt have any time for playing with R23 as i have test exams in my highschool tomorrow... learning, learning.... polish + biology
    Im importing ethylene from germany, a 2l bottle costs 100$
    Gtg and learn
    Dec 2003
    England, south east
    HOLY.... Thats quite something, I can't wait for temps!
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    berkut
    Ïîçäð:banana:âëÿþ! In other words - cool! I am looking forward for some tests.
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
