Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: 2500+M stinks....
    Dec 2002
    2500+M stinks....
    argh, I got my 2500, hoping it would do 2.5ghz on air, but it wont
    right now I am at 232x10.5=2.45ghz
    It need 1.95 Vcore for that
    seems to max at the same speed as my old Tbred JIUHB
    phooey
    PII X6 1055T 14x272
    Gigabyte 890GX
    2x4 GB Gskill DDR3@4890
    XFX 7870
    X. I. P.
    Jul 2002
    Sioux Falls, SD U.S.A.
    My 2400+M maxes out at the same, 2450 stable @ 1.925. I can push it to 2550 but it's just asking for a BSOD, freeze or crash. More volts does nothing, 42c loaded temp.
    The plural of "anecdote" is not "data."
    Xtreme X.I.P.
    Nov 2002
    Shipai
    what cooling? my 2400+ m crashes if the temps rise to ~40°C, if i keep it cooler than that i can get it to 2.6ghz+
    Dec 2002
    well.under load it goes to 52-53c
    I really need an SLK-xxx
    Is an SLK-700 for $15 worth it?
    PII X6 1055T 14x272
    Gigabyte 890GX
    XFX 7870
    X. I. P.
    Jul 2002
    slk900a here. Perhaps I should switch to water...
    Xtreme 3DTeam Member
    Jul 2003
    Mason, MI... USA
    I just got a new Little Giant 475gph and switched to an auto radiator (from a truck) and got 2800MHz stable finally with mine. They sure do seem to like better cooling.
    GA-P35-DS3L no more than 450fsb w/1333 chip
    E6550 stuck at 3150
    V-DATA 2x1gb
    MSI 7900GS 512 3Dmark score in near future
    Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
    Feb 2004
    York, PA
    My mobile 2500 can do 2.8 on air (not stable of course)
    Jan 2004
    Belgium
    didnt those mobiles like to be fed +2vcore?
    They are supposed to get a nice boost when gogin over 2V vcore...
    Orther then that, are your rails nice and stable?
    Vcore stable?
    Dec 2002
    all stable 12v at 11.95
    PII X6 1055T 14x272
    Gigabyte 890GX
    XFX 7870
    Aug 2002
    my 2500+ Mobile so far is 2.6GHz stable at 1.9v on air. going to try 2.7ghz in a bit. So maybe you just got a bad one?
    Intel Core i5 2500k @ 4.7GHz
    Gigabyte Z68X-UD3H-B3
    8GB Corsair DDR3-1600
    MSI GTX 680
    XFX 750W Black Edition
    Corsair Carbide Air 540
    Feb 2003
    Illinois
    Do you have any pictures of your cooling setup Poki? I would like to see how your rig looks.
    Raybo
    DFI CFX3200
    Opty 180 at 2730
    XP-90C W/92mm Tornado
    2X1024 G.Skill HX
    Silverstone 520
    Powercolor X1900XTX
    Feb 2004
    York, PA
    Check this:
    Mobile 2500 (2.5GHz, 200x12.5)
    Feb 2004
    York, PA
    Another:
    Mobile 2500 (2.6GHz, 200x13)
    Apr 2003
    USA Tampa FLA
    hell even at 2500mhz i wouldnt say you got a dud? i mean look at the older bartons you were lucky if you reached 2400mhz! these mobiles seem to all hit 24-2500mhz and somtimes alot more! i am going to try one thats for dammmmmm sure! just dont know what one yet? my luck ill wait too long and they will all be gone!
    peace perc,
    Aug 2003
    Chicago InsaneTek.com
    Why the low fsb?
    Aug 2002
    cause the Crucial sticks dont like the 2.7v thats the lowest option on my Albatron board.
    MSI GTX 680
    Jul 2003
    Mason, MI... USA
    Raybo
    It's not pretty by any means i just wanted to use a larger radiator because my old one wasn't allowing the water to cool properly. It was fine with my old 175gph pump but this new one really pumps it through too fast.
    I used the room next to my workspace which has an unfinished bare concrete floor which only houses the sump pump and computer parts. I drilled 2 holes through the wall for the 1/2" tubing that feeds the waterblock.
    I wanted to use the radiator as a resevior also but after testing the new pump as a inline unit it got way too hot. I knew i had to run it submersed so thats how the resevior ended up being part of it.
    Anyway, the loop starts at the pump and goes to 1/2" tubing to the waterblock then 1/2" back to the radiator. It passes through and comes out a 3/4" tube to resevoir which i change the height of in relation to the top of the radiator to insure the radiator is flooded at all times. I also use the pressure relief cap to purge the air on fillup as it's on the discharge side of the radiator.
    This is far from the way i wanted to do it but when i do get a true inline high pressure pump i'll remove the resevior from the system and use the radiator for one.
    The main cooling nipples on the radiator were plugged and epoxied and then sealed with silicone after a day. I removed the pet:banana::banana::banana::banana: and drilled and tapped 1/2"NPT for the input and used the stock heater nipple for the return to the res.
    E6550 stuck at 3150
    V-DATA 2x1gb
  18. #18
    Xtreme X.I.P.
    Nov 2002
    Shipai
    bartons usually get a boost above above 2v, even tbreds actually, but bartons are very sensitive to heat. high volts and cool temps is what good bartons need to shine.
  19. #19
    Feb 2003
    Illinois
    Looks "pretty" to me Poki, actual radiator and not a heater core.............. YIKES!
    What kinda fan is that, Panaflo, Delta?
    Raybo
    DFI CFX3200
    Opty 180 at 2730
    2X1024 G.Skill HX
    Silverstone 520
    Powercolor X1900XTX
  20. #20
    Aug 2002
    yeah it seems if i put 2v or higher, i always get a blue screen before windows loads
    MSI GTX 680
  21. #21
    Feb 2003
    Illinois
    I also like the bungie cord, nice touch.
    Raybo
    DFI CFX3200
    Opty 180 at 2730
    2X1024 G.Skill HX
    Silverstone 520
    Powercolor X1900XTX
  22. #22
    Jul 2003
    Mason, MI... USA
    This is the second full sized radiator i've use... The other one was a monster but the last thing i uesd was an AC evaporator from my miata... Dang AC never did work well in it anyways.
    E6550 stuck at 3150
    V-DATA 2x1gb
  23. #23
    Feb 2003
    Illinois
    No wait!
    Galvanized bucket, empty milk crate, box fan and a radiator from a truck, this is what overclocking is all about!
    Kudos to you Poki. I guess it ain't pretty but I'm sure it's cooler than the other side of the pillow.
    Raybo
    DFI CFX3200
    Opty 180 at 2730
    2X1024 G.Skill HX
    Silverstone 520
    Powercolor X1900XTX
  24. #24
    Jul 2003
    Mason, MI... USA
    YEE HAA! Backwoods kewlin! LOL
    E6550 stuck at 3150
    V-DATA 2x1gb
  25. #25
    Feb 2003
    Illinois
    Thank you for the pictures Poki, much appreciated.
    Raybo
    DFI CFX3200
    Opty 180 at 2730
    2X1024 G.Skill HX
    Silverstone 520
    Powercolor X1900XTX
